Pocster
    29
Everything posted by Pocster
  1. I’m guessing this even though it doesn’t sound like it . Hoping the fan comes out easy ( bet it doesn’t)
  2. They are apparently enclosed I.e not serviceable . It doesn’t actually sound like the bearings failing tbh - but clearly a fan issue
  3. Apparently bearings are sealed so no wd40 . Will take it apart tomorrow
  4. Hard to explain . Like a vibration / whoosh and then settles so not constant . Assume fans dying . If I open this up ok to just wd40 the bearings ??
  5. Why do I want moisture resistant plasterboard ?
  6. Tanked
  7. Nope ! 3 times I’ve seen raw sewage pouring over various gardens due to wet wipes .
  8. Chat has now changed its mind 🙄 . Won’t bother with ct1 . Simply tanking slurry over the lot . There are no gaps it’s just porous material.
  9. Slurry ordered and more ct1 👍
  10. Oops in wrong group ! 🙄🙄🙄😂
  11. https://m.uk.investing.com/news/stock-market-news/tesla-recalls-10500-powerwall-2-battery-systems-due-to-fire-risk-93CH-4369300?ampMode=1
  12. Chat suggests . Clean it all up . Ct1 the joints I.e block work on the concrete - water gets through the mortar at this point . Then ka slurry the lot .
  13. Chat suggests sika 1 waterproofing Or this
  14. Hairline cracks in the concrete also I want to fill . Did assume some concrete / brick sealer waterproofing was the thing to try . So a small number of drops did get the floor . Didn’t put a bucket to collect . But it is a small amount . Just checked it now - whilst not dry it’s clearly drying out . Considering how much rain we had and how quick it’s drying does kind of confirm it certainly isn’t a lot of water .
  15. Avonmouth is a shit hole
  16. Entire day of rain - storm so lots of rain . 15:30 - finally get a drop through . You can see it’s been building up to that . I’m going to leave this as is until spring . But if I were to seal the concrete I.e to prevent water coming through what would I use? . I guess I should be happy as gone from half a bucket to just this .
  17. Yeah that’s what I think . But , everything looks like leak 🙄 Might just foam the (expletive deleted) around there - effectively insulating…
  18. Only thing I notice is ‘ condensation ‘ on the inner part of the glazing frames .
  19. Lots of rain over the last few weeks . Most at night so I don’t “ count it “ . Wee’d down today . Went out to look at my low profile drain . Certainly doing its job ! - small river coming out the other end - draining away from the property . Still can ‘feel’ some moisture inside ( I think ! ) but zero water drops . Paranoia causes me to check the room with the leak a few times everyday…. 🤪
  20. We’ve all been there also 👍
  21. I’ve got another project using water proof ultra sonic transducers linked to an esp32 - works really well . The device you link to might be worth a punt . Be keen to know how you get on .
  22. I know what you mean “ Swindon office “ look . It doesn’t have to look like that . It is subjective of course .
  23. All done . Decking board just to protect cement from rain . If nothing else it will direct water away from property .
  24. A "Man O Meter" ......
  25. Where’s the friggin cinema room ??
