Everything posted by Pocster
Yeah , like your (expletive deleted)ed up bathroom saga
The solution for all self builds from BD
Pocster replied to Pocster's topic in General Self Build & DIY Discussion
But you can't do (expletive deleted)ing anything else. Just the one simple benign task.... -
I'm going to order it when available. Also a Tesla sex bot. Wonder how the two would get on? -
Watch and learn how not to do it!
Just spoke to them. Stupid (expletive deleted) ; the trim goes the other way round. I did actually check this and assumed the trim visible width was the same as the struct width. But apparently not. (expletive deleted)ing Friday!
This trim is SO flimsy shit!. Also when the 'structs' come across to support the tiles how do they fit to the trim??? (expletive deleted)ing rubbish - gonna email the company now and rant .. A FRIDAY RANT!
Suppose once skimmed and painted - could trim over the trim ffs !
The plan was a suspended ceiling ; that office block look . The perimeter trim is so flimsy it bends under its own weight and deforms when a screw goes in . This why these ceilings always look crap ? At edges I pack it out as it can’t possibly bend . It still wobbles around . Im doing this in the wrong order I.e walls not plastered ; because waiting on a plasterer will hold me up . Intention was he will skim up to the trim . Then I will caulk along the edge as it’s bound to crack . Am I just being crap ? ( rhetorical question ) Thought the perimeter trim would be easy ! 😞
On my site it would get promoted to site manager ! . I so want one ! -
Title is rude . You should always respect other people’s boundaries and where you wish to discharge .
Yeah I always have things mains powered . I think newer z wave is better - but I do have some older z wave legacy components in place . Going to do a simple test once zigbee stuff arrives . 2 lights in a room , one z wave controlled other zigbee . Both triggered by the same Method at the same time . Both just 1 hop away from corresponding usb stick . Be interesting to see the ‘delay’ on either . But as you say ; time to probably move away from z wave .
My HA is all z wave . It’s pretty reliable . All powered no batteries . Can be slow responding for non obvious reasons at random intervals . Walk in a room , light turns on within a second . Other times 2 or 3 seconds . Occasionally 30 seconds ( once I’ve finished swearing ) It’s hard to know the issue . Z wave can only do 4 hops max and the amount of data is going to be small . A 30 second delay seems ridiculous. Anyway . Decided to get some zigbee stuff as a test . Christ is this stuff cheap if you get it direct from the land of the rising sun ! . Makes z wave seem very expensive . Anyone had zigbee for a while ???
I connected 1 at a time . Turned it on and wait ( maybe a leak maybe not - some times forgetting the other end of the pipe is open - which guarantees a leak 😁 ) Grow a pair and do as I say . This is the proper way . Not faffing with some air test kit to give you a false sense of security . I want water - and I want it now !
Nah . Do like me . Stick ‘em on the wall . Water on . Soon find out if there’s a leak 💪
Self-centering internal pipe-cutter - for plastic
Pocster replied to ToughButterCup's topic in Tools & Equipment
Expanding foam has just so many uses … -
Fill it with expanding foam . Then once cured poke holes in it to get required flow 👍 -
In Cornwall you don’t . The reason being is you are detached from the modern world .
Extra sockets for pumps 😉
Amateur list !
Careful where you stick that nossle
Can’t you just get a nice round plastic disc with a grill and use that as an outlet ? A flat ‘vent’ effectively -
No one commented on my studwork . I must be getting better 😁
Yeah I did think that . Not much timber against floor though . ( might do that anyway )
