Everything posted by Pocster
This seem ok ? https://www.superlecdirect.com/6242b-1mm-twin-and-earth-wiring-cable-lszh-50m-reel/
Thanks The down lighters will be permanent I.e be treated as “ fixed “ . The lights do have in/out connectors for looping - so no 2 cables in 1 hole . Does it matter if cable is solid or not ? . Prefer non solid core as flexibility is easier .
Erm 🫤. Socket on wall . Plug from that into wireless dimmer unit .Dimmer into a chain of LED down lighters . Any idea what those 2 reels of cable might be used for ? The 1st one ( pink box ) sparky said I would need - got about 5 reels of that ….
Link to correct/better cable would be appreciated say on Screwyfix ....
Experimenting with stuff . Got loads of reels this wire. Tried to use it but it's solid core , stiff, tricky to cut as it's flat not round. Assume it's not for lighting; what would it be for? Got just a bit of this - which I used for lighting experiment. This ok? Is there a better type of wire I should use for lighting circuits?. All 240v but low wattage LED lights. TA!
Not installed it tbh . The reolink app seems pretty good . Can’t see an issue with it linking to bluiris I.e my equivalent to an nvr . For the money real good - much better than over priced doorbird I have .
WiFi repeater over ethernet
Pocster replied to Carrerahill's topic in Networks, AV, Security & Automation
+1 for ASUS. Tried bt discs , netgear , tplink , others - only ASUs did it for me -
But control them how ? I’m leaning towards the ‘square ‘ arrangement
Nope ! Lights MUST be centre of tile …. 😁
Or do I put the lights anywhere within the 600mm tile so I can space them exactly . Look pants yeah ? . Light has to be centre of tile no matter what ?? More 🍷; will help ….
Actually as I sit here sipping ( guzzling ) my Chablis here’s a photo . I lined the ceiling centre with the sliding doors ( though they are not central of the room !! ) . With these things I think it’s how it looks rather than it is an exact symmetrical measurement I.e from each wall either side .
About to do a test ( about means within the next few weeks ) . Lounge area has down lighters dimmable . I’m assuming though I won’t want them ALL on ( maybe as many as 20 ) . As I’m linking it to my HA I could wire so that I control a row or column . Maybe control the edges like a perimeter of a square with a smaller square inside . Not sure what would be best . As I have a suspended office style ceiling - for sake of ocd a light would be positioned dead centre of a tile . As tiles are 600mm that means a light width wise every 1.2 metres . So width would be 4 lights ( though it means exact centre of room lights would be further than 1.2m to maintain symmetry) . Length I reckon ( if one every 1.2m ) would be maybe 10 . If none of that makes sense - ask for a drawing 😁
Well it’s been around 15 months - no leaks ( from the shower or bathroom ) . Regarding the face plate I didn’t put any silicone under the bottom part . Logic being I should be able to slip a razor blade under there and cut the silicone around the other 3 sides . How practical that is remains to be seen 🙄
I got my arse b*locked for it . Still sore from the rapture / rupture .
Offensive language should not be used in a public forum . You have been warned .
https://www.superdrug.com/electricals/hair-stylers/hair-crimper/babyliss-the-crimper/p/810703?gbraid=0AAAAADp4mz-DVFHIKpLCmbFPTFASrmt0w&gbraid=0AAAAADp4mz-DVFHIKpLCmbFPTFASrmt0w&gclid=CjwKCAiA9NGfBhBvEiwAq5vSyxmO5brbauJNyiQ_ij7H_4Lf02I2rKOUydKNFJulzE61vR7_-vdrQhoCiQsQAvD_BwE&gclsrc=aw.ds
My underground hole always welcomes you .
