Pocster
    29
Everything posted by Pocster
  1. Guys , problem isn’t fitting to the wall - problem is a decent fitting off the unit .
  2. Ah well ! Now I could smash the wall out and do that - not an issue - just sounds like work .
  3. I got vertical timber studs so it shouldn’t be an issue to find a fixing . Its the shitty cardboard type back that pisses me off . As my kitchen runs into the lounge it would require osb / ply across the entire wall ( assuming I like it level )
  4. If I cut that pipe short . Weld a 135 . Go along a bit 🙄 ; then do another 135 into a 135 - that’ll work yeah ? ( because I haven’t got a (expletive deleted)ing clue )
  5. I could indeed - that’s a good plan . I did forget to mention it’s a studded wall - so naturally I want to fix to that not pb .
  6. Yeah it’s a grey water macerator . Unit on left is the sink where macerator has to go . Next to that on the right will be washing machine . As you can see my waste pipe angle is too tight - by the time I get inside the sink unit I’ll be on the floor . You’re not meant to use 90’s ( I can cut that 135 off the end if need be ) . Can’t reposition vertical pipe due to wall and lesser ceiling height . Just stick a 90 where that 135 is and hope for best ?
  7. If there’s a timber there 🙄😊
  8. I could but it's still the cardboard back screwed to the batton. Not much strength there - the back of unit would flex.
  9. These are low units. What you suggest is their recommendation for tall units - which I do have. My issue with those is I've only got about 5mm from unit top to ceiling.
  10. Yeah I know . But I’m happier if all bolted to the wall .
  11. Instructions suggest cutting a hole in the ‘cardboard’ back and inserting a L bracket . Seems a bit crap too me . Really want to screw the unit through the back direct to wall . But as back is cardboard - no good . How do I fix this rock solid to the wall ? . This is a corner unit so obviously could fit if the adjacent wall - but what about a row of floor units ??
  12. Very similar to my heat miser wiring - not tricky
  13. That’s what I would think . But your system is undoubtedly different setup to mine .
  14. Yeah - got you . My ASHP operates ( when it needs ) rather than I control it . ufh ( via uvc and ASHP ) it is determined by flow I.e when relevant pump is on for which ever manifold . So I don’t control ASHP directly - all off the ufh pump to effectively operate uvc / ASHP .
  15. Just the manifold pump request then ?
  16. Hmmmm Mines like the other way round . Actuator opens which turns on pump which inturn requests ASHP if needed .
  17. Motorised actuators . ( salus ) Simple control box for them ( heat miser ) . WiFi type relays hooked into that . You can then easily add to whatever HA you need later Or ignore 😊
  18. I know . Wish @Thorfun would listen to me ! . @Conor it worked really well - you’re a legend like me 😊👍
  19. SWMBO wants to stick plants in there . In winter it’s unsurprisingly cold . In summer it’s an oven . Whatever she puts in there will die 🤣
  20. Care to link ( say on screw it fix ) to what you mean by ‘fine’ ? Appreciated ! 👍
  21. Circular of jigsaw ? Does it matter ??
  22. Yeah - there aren’t any off cuts ( yet ) . I did Google but it seemed a bit random on what’s recommended .
  23. Yeah I’d use a guide for either saw . It’s the chipping that worries me . I presume someone will recommend some mega blade for either that doesn’t chip …. 🫤🙄
  24. Actually laminate probably more accurate description of material .
