andyscotland
Everything posted by andyscotland
As far as I know, the build cost for the warrant application is supposed to include a proper value for labour even if you're going to DIY/call in favours/whatever. Although it doesn't have to include the value of work not strictly relevant to the warrant (internal finishes etc) but there's very limited guidance on what exactly should/shouldn't be included. So I suspect a lot of people's figures are pretty notional. It does seem a fairly unreliable way of valuing/costing the work involved - if you specify £10k of high performance windows rather than £2k of cheap PVC that doesn't really make any difference to the council checking they meet the appropriate BS/u-values/whatever...
How crucial is BBA certification?
andyscotland replied to andyscotland's topic in Building Regulations
Thanks - yes, u values and fire are all ok and it's a warm roof. -
A warm roof has the vapour control and insulation on top, hard up against the covering. So the rafters etc are "warm" as they're inside the heated space. A cold roof has the insulation between/below rafters and requires ventilation below the roof covering to prevent condensation. -
I did a full plans submission, but the (approved) spec just says the GRP system and substrate needs to meet fire rating AC or better. I didn't mention a particular manufacturer or anything more specific, though there is a general line at the beginning that all works and materials to comply with relevant BS and EN standards. So I could assume that if they wanted to require BBA that would have been flagged already - but just a little cautious as my council (who will be inspecting) are known for being stricter than the council they subcontracted my warrant application to. -
Thanks all, helpful comments. It's only a fairly small area (30sqm) relative to the rest of the house and we do not expect to sell. It's a warm roof, and actually low pitched rather than flat (around 8 - 10 degrees) so no issues with fall. Unfortunately building control have to date refused to engage with the project at all - don't want to hear from me until I'm ready for completion certificate and on a couple of things I've attempted to confirm their approval of ahead of time they won't say any more than it's for me to ensure that I can demonstrate at completion it complies with the regs.... I guess basically I just want reassurance that if I put a non-BBA-but-fire-certified product on there the building control inspector won't make me replace it at completion... -
For my garage conversion / extension I'll be laying a GRP flat roof covering (on new OSB). One of the products I'm looking at (from a supplier previously recommended to me) has a 20 year manufacturer's guarantee, and a third-party fire test certificate - but it doesn't have a BBA (or other third-party) certification. My approved warrant documents don't specify it has to be BBA, and I don't have a structural warranty so no requirements there. The supplier has advised that the only thing Building Control will want to see is the fire rating document, and I shouldn't have any problems (practical or paperwork) using their system. Does that sound right - am I safe enough to go with that product? Or would I be better using a BBA system (which appear to be more limited in choice, and more expensive)? Thanks, Andrew
Oh really? That's not good. To be fair it's a long time since I've used the provider-supplied router/modem for anything bar the final network access where necessary, I've always installed my own WiFi and cabled router(s). Had so many bad experiences in the past with the variety of rebadged cheap boxes that come by default.
Indeed. My post was mince from start to finish, with the possible exception of the bit that it just makes the timber good enough to avoid it being a thermal bridge through the surrounding wool.
That's basically an entire sequence of units I have no concept of apart from the hours! And perhaps the ft2 if I picture it as a ruler by a ruler ?
@JSHarris ahhhh thanks - I had no idea the US R values were different! Though of course it makes total sense that they are...?♂️
R is 1/u and vice versa. So R20 is a u value of 0.05 (against 0.13 for standard timber). I don't think he was saying that's all you need, you still have e.g. wool between studs at 0.039 but the studs form much less of a thermal bridge. So you can get a good overall wall u-value without having a secondary continuous layer of insulation in front of / behind the studs. Edit: this post is nonsense but I'm leaving it as an example of what happens if you come on here before your morning coffee.
I'd second the advice to look at Virgin, if you're in an area that has it. Their network is consistently miles better in terms of stability and performance. Also because the whole network was installed more recently than most housing, and is less sensitive to cable lengths, it tends to be installed in public areas e.g. under the pavement where BT often takes shortcuts through back gardens. The problem then is that if - as happened to my mother in law - there's a fault on the line it relies on the engineer being able to get onto people's property to fix it. If they're no longer BT customers themselves they have no incentive to arrange access. Cue 3 months of Openreach arranging visits for the engineer each time to confirm that the fault was somewhere between her and 3 poles away but the other gardens were all secured and nobody home. Eventually the engineer marked up they were unable to service her but it still took another 2 months to the call centre before they'd agree to cancel the 12 month contract. Or, the reverse where a neighbour down the hill wanted a new connection to the pole in our garden. I work from home, engineer popped round and took a look but needed to cut back some of the neighbour's tree above our fence. Said they'd schedule a tree surgeon to come, then 2 months of an appointment being set, nobody turning up, then an engineer turning up to finish the install and going back to base to arrange a tree surgeon. Eventually we got a snippy note from the neighbour that we were blocking her connection so I had to pop round and show her on my calendar that I had so far blocked out 7 days for openreach and their contractors, and had essentially been in all day every day the rest of the time. A week later the tree surgeon turned up unannounced and did their thing. But no engineer. I bumped into her a couple weeks later and she said she'd cancelled the contract the day she spoke to me! With virgin they usually just have to get from the pavement outside your house up to your property. Obviously if you're in the countryside you probably don't have options, but if you do - take them!
A little confused on SWA sizing for mains supply
andyscotland replied to scottishjohn's topic in Power Circuits
Generally speaking, a 200A 3-phase supply is effectively 3 x 200A supplies - in other words caters for 600A of connected load. If you have a possible peak load of about 200A, then you would install either a 63A (which is very slightly under) or 100A 3-phase supply. Your installation circuits would then be split over the three phases, aiming to get the loads fairly evenly spread. So for example: The PV array would be connected as a three-phase "appliance" - so 1/3rd of the panels connected to L1, etc. If you've a main house that'll be used fairly consistently and has some big loads (heating / cooling etc) then you might give it a 3-phase supply of its own and split the various circuits across the phases. This adds a bit of complexity / cost compared to a standard single-phase domestic install which is why you usually only see it in commercial. If you had e.g. 3 holiday cottages that were fairly similar you would probably just connect one to each phase. This is essentially how the utilities connect up standard domestic properties. Note that on a properly-designed three-phase supply a lot of the current in the neutral is cancelled out - the electrical waves are all offset to each other, so one phase is high while another is low. Therefore the neutral still only needs to be the same size as the phase conductors, even though it's connected to all the loads. At 130m you'll be primarily sizing cables for volt drop, from a quick look at the tables I think you'd be looking about 35 sqmm c.s.a. SWA for a 63A supply, or 50 sqmm c.s.a for 100A depending on install method etc. Though as above if the utility run it in they won't use SWA. Might be more complex if you're going to be installing anything industrial / specialist (large motors etc). -
@AliG yes I was surprised about the drain test but they were not at all interested in coming out. Perhaps they'll want to do another at the end, the ones I did were perfect passes - barely any leakage at all - so hopefully they'll still pass now they're under concrete / buildings / backfill... When I've actually been able to speak to anyone, they've been good - but don't know my project and have been fairly non-committal. It's just I've heard horror stories from others, so it seems like it may depend who you get.
Thanks - I don't get the sense Edinburgh is that sort of council, reckon it's extremely unlikely I'll get to speak to the HoD. They've been helpful a couple of times when you chat to the duty officer, more of a mixed bag by email. @Triassic @ProDave mine has never been on site, not even to look at the drains. The original paperwork they sent said they wanted to see the drains, structure complete and insulation in. Wasn't expecting them every week, but thought they'd do at least one of those. That's very true, guess I'm just nervous there'll be some small detail that's not on the plans or that the surveyor who does the final inspection doesn't like. A neighbour had plans approved but then the BCO on a site visit felt one of the details was not compliant and shouldn't have been signed off and he made them change it. Fortunately was early enough in the build it wasn't too much of a drama. If that happened at completion it'd be hellish... That's what I'd heard, but also part of my nerves. I don't even have a named officer on the warrant, it was issued still showing "Argyll & Bute Council" as the named officer. To contact them I have to email the neighbourhood team, who eventually reply signed off "Building Surveyor North West". Appears to be different people each time. There were a couple of small things came up with the drain alterations once we excavated and it was a nightmare getting any sort of opinion. When I've tried to phone or on one occasion visited the counter they just tell me to email. I think the problem is the fees are set Scotland-wide based on what it should cost to run the process, but unlike e.g. parking the income isn't ringfenced so with all the pressures on council funding the BC department is an easy place to make cuts without losing revenue. I used to work with Edinburgh BC years ago on theatre/event licensing and from what I can tell the team is massively smaller than it was then despite the increased building activity in Edinburgh. The people I mostly worked with have retired and not been replaced. It is annoying, it's not like I've had a discount on the warrant fee to reflect minimal inspections etc.
I'm self building a garage conversion/small extension. It includes new drains to new inspection chamber, new ensuite, door openings in existing walls, new rooflights, etc. I did the plans & spec myself (with a lot of research and a structural engineer who provided a Certificate of Design for the structural elements). I have a building warrant but the council have said (in writing) that they have assessed the project as low risk and won't be allocating me a BC officer or inspecting until I'm ready for completion certificate. I'm to take photos as I go to demonstrate compliance with the approved plans / regs. I'm pretty confident that my plans are compliant, and that I'm building what I drew. My application was pretty comprehensive, included detail drawings of most things as well as the basic plan/section/elevations. I'm taking photos of basically everything along the way, and have a selection of 5 minute videos of nothing at all changing on a drain test which will make riveting viewing... All the same I have an occasional nagging worry that there'll be some small detail that doesn't quite show on the plans, or isn't quite clear in the photos, and they'll make me open things up at the end to inspect it. It's further complicated because I'm not sure anyone at Edinburgh council has actually ever looked at the plans : they contracted the assessment out to Argyle & Bute. The officer there said he reckoned they were to a high standard, but I've heard Edinburgh are known for being quite picky. I'd feel more comfortable if it was inspected in stages in the usual way. Part of me wants to try to persuade them at least to do one visit once the structure is all up. There's loads of (bigger) builds near us so they must be in the area fairly often. But I don't want to make a big drama and seem like I'm not sure of what I'm doing and then get someone out who's actively looking for something to be wrong. What would you do?
Anyone know how how to compare insulation values?
andyscotland replied to gwebstech's topic in Heat Insulation
You could also look at sheep's wool insulation - I've used thermafleece before but there are other brands. It's totally non-itchy and really nice to work with. Much less messy than cutting PIR too. Not only is it breathable but unlike a lot of synthetic insulation, it doesn't lose insulating value when damp. In fact as the temperature falls it absorbs moisture from the air and releases heat, then as the temperature rises again the wool releases the moisture which has a cooling effect. So it helps to balance out moisture and temperature changes over the seasons, and sucks any condensation away from the timbers (up to a point, obviously). As I understand it, the heat-release properties aren't accounted for in the u-value so it actually performs a bit better than the figures suggest (where a lot of man-made actually perform a bit worse than the lab-conditions tests). It's also fire-retardant and very eco-friendly - low embodied energy to produce and a lot of it is made in the UK. -
Ah, that hadn't occurred to me. Seems a bit harsh to include it in GIA if it's actually external, even if the roof does overhang it! Not saying that's wrong, I know very little about those rules, just commenting. Sounds like a reasonable plan.
If you wanted to keep the balcony as-is, one possibility might be to build the external walls as though that was just a big window opening if you can picture that? So you'd have a lintel over the top of it in line with the downstairs walls carrying the roof load, with the roof overhanging the balcony a bit. It would potentially be most economical/feasible with a corner post to support it. Then the inset wall dividing the room and balcony would just be a stud wall, still insulated and weatherproofed, but lighter than a full structural external wall. You might still need a little bit of steel below the balcony wall especially if there's a lot of glazing, or you might get away with it on the joists/any steel that might anyway be needed for the balcony cantilever. But it should be quite a bit thinner than if it had to carry all the roof loads as well. Making it cheaper and easier to hide in the ceiling downstairs. I think could well be worth a short consultation with an engineer at an early stage to get a sense of the possibilities so you have the option to shape your design round them.
Yep. The mortgage we had trouble with was just to move an existing mortgage to a bigger more expensive house without any extra borrowing (added some savings, inheritance etc). So no change to the payments we'd been making successfully for years, and a lower loan to value so lower risk for them. Still had to jump through hoops and nearly couldn't get it. Definitely wouldn't have been eligible with a new lender and if we'd not been able to speak to a sensible underwriter at the lender who was able to see the big picture we would have had to stay in the old flat till I had enough accounts.
Have checked and I'm fairly sure that is indeed unlawful. This page mentions specifically mortgages when pregnant - but if not yet pregnant it'd still fall under gender/age discrimination. It's illegal not to provide services to a woman just because she's theoretically the right age and gender to have kids. Now of course people do unlawful things all the time, so maybe some lenders do consider it on the quiet. Maybe even just if there's a judgement call, it might swing the mind of an underwriter one way or the other. And yes if that happens you'll probably never know that was why. My point is just that you advised "unless you can prove your wife is not going to have kids". If the mortgage company accept that proof they will be admitting to illegal practice. Therefore, either they do it across the board and there's no evidence you can provide as an individual to change their mind, or they don't. They will not want a trace audit to turn up a doctor's note showing infertility in one of the files with a positive decision...
