Dan F
    2
Everything posted by Dan F
  1. Depends what you'll use garage for, but if the floor is reasonably flat swisstrax is an option worth considering. It worked out cheaper and easier than epoxy for us (in part because we didn't need to grind/prep the slab), and it looks fantastic too. There are a couple of caveats you have to weigh up with it though. - Doesn't need much cleaning because of how it's designed, but dust does accumulate underneath it. - You don't want to drop anything very small on the floor! Also water goes through it (which may or may not be a good thing) - Not that confortable walking in socks (there is another models which this isn't an issue with though, although it accumulate more dust due to flat surfaces). On the flip-side, you can pull it up to clean underneath it you want,change the design or replace damaged tiles, things don't bounce off it etc.
  2. That's probably the passive one i was quoted just over £2k for. That's £5k for a bit of paper. quite a racket! Lathams got the fire safety certificate for me, that shows the "smoke tightness classification" from Moralt in Germnay. It was all in Germnay but building inspector accepted it.
  3. We used lathams. Model was "Moralt 68mm Ferro Firesafe EI30 door kit"
  4. There is one kind of exception to to this is; MVHR, as if it's not certified you have to deduct 12% efficiency. Correct on other components though, it's the overal peeformance of the house, not compliance of any given component. U-value of our was 1.02 (vs. passive version 0.72), but it all comes out in the wash when you have good insulation and windows elsewhere, Also door blanks (with no glass) with such low u-value can be a bit too thick and a bit of a pain to handle. And to @JohnMo point, if you are using PHPP the garage can be configured with it's own temperatue zone, making the impact of u-value on this door even less important.
  5. They are expensive, but you shouldn't need to pay anywhere neer 7k or 8k. Other threads have details of much more modeatly priced Moralt ones. Also, remember you don't need the ones marketed "passiv" as long as u-value is good, and it is airtight and FD30 rated. We paid £1685.00 a couple of years ago for full doorset. The "passiv" version was £2206.00 for minor improvement in u-value.
  6. Yes, during the day downlights are 3000k and LED's 6500k. I could have it set up so LED's never go past 3000K, but in some rooms it's nice to have more daylight color temperature during the day. Depending on the need for task-lighting, and if the light-level, I have just LED, just downlights of both on during the day. Most rooms have evening/night mood which is just LED, or mostly LED with downlights on min filling in shadows, but this can all be adjust based on what works best based on room and preferences.
  7. I started out wanting to do everything CCT, but then when I i) saw the limited availability (and cost) of CCT downlights ii) read a bit more about the theory, I decided it made sense to stick to 3000K for direct/task lighting and CCT for indirect lighting. I then simplified this to 3000k for downlights/uplights and CCT for just LED's. However, I also wanted to ensure that I had high enough power LED's so that these could be the sole light source for low-light evening/night moods if required so chose 33W tape (only 16.5W once driver is programmed for linear output) and most rooms have full length of one wall. There was an issue with the tape I sourced and it doesn't fully dim correctly, but overall really happy with combination of downlights plus CCT LED's and overall flexibility.
  8. @Alan Ambrose I installed tunable white LED's in all rooms 2200-6500K all controlled via Loxone. I have moods etc and use the different temperatures with these, but they also adjust with the time of day on automatic moods. I used EldoLED DT8 Tunable white DALI drivers and meanwell power supplies. Anything else you need to know?
  9. Actually a lot of manufactuers have really good public information including mitsubishi/lg/panasonic. Sometimes it's in a seperate "databook". The Vailant marketing documentation and manual was always very confusing as it wasn't clear what the values represented. This fustrated me so much that i spend hours going to every european vaillant website looking for the actual data until I hit on the now infamous "czech tables" which I shared with Mick and online before Vaillant could take them down. I since found the english version, but I know Mick likes to keep referring to them as the Czeh table given it gives them a bit more mystique 😉 These tables however, don't seem to include defrost apparently (even though they quote a standad that says they should), so you need to be careful using these for sizing. Various issues where installers have installed 7kW units based on ~6-6.5kW heat-loss, and then ASHP can't deliver enough heat when temp is around 0C and moderate->high humidity. This seems to impact 7kW bit more than others.
  10. Enthaphy exchanger also doesn't need a pre-heater to protect the heat exchanger against frost (at least not in UK temperatures). Ours was supplied with one anyway though
  11. Does your trace heating still work in power cut? You'd want it off all the time, but only on if power cut of ASHP failure. How do you trigger the trace heating when power/ashp fails, and what powers the trace heating when you have no mains?
  12. The risk is only in the case of power-cuts in below freezing. With power the ASHP itself keeps things from freezing. I don't disagree with you, but manufacturers clearly can't recommend that instalations don't either either anti-freeze valves or glycol.
  13. Mine for reference, same model, hits 4C minimum. I don't have it set that low, but because it cycles the flow temp drops beyond target temp before compressor turns off. My install has the Caleffi valves.
  14. Mine works fine with cooling and anti-freeze valves. What anti-freeze valves are they? Have they been switched out? They should only open at 3C +/- 1C. What temperature does your flow temp drop to during cooling?
  15. We used a designer. Yes, there were fees involved, but not very high vs other professional, and was money well-spent I think. Depends what you want to do though, only makes sense to invest in a designer if you want something more than standard and are happy to pay for the fittings. We also used Loxone. Went with DALi for all fittings, so have full control over mood creation with no limitations based on how circuit were run. Not a must I know, but satisifies my desire for programmable flexibiliy, and have used in on a couple of occasions to: - seperate downloads into different zones (center downlights vs wall-washers) - disable downlights near TV in tv-viewing mood, while leaving those above table on.
  16. That is a solid choice for indoors if you not deperate to get on the wifi 7 bandwagon. Outside the U6 Mesh is a significantly better option in terms of wifi standard and coverage, but it depends on your requirements. If you just needs a basic AP wifi-5 AP without too much coverage UK-Ultra would work.
  17. What information specifically? I have a 7kW which is quite a bit oversized. Yes it cycles, but having adjusted the integral settings I have minimized this. Also, 7kW heats DHW faster than 5kW would. Cycling is to be expected and not something you should try to avoid at all costs, that said you clearly don't want to significantly oversize and you want to ensure you have enough system volume to minimize frequency of cycles.
  18. This is nonsense. All the aroTherm+ models modulate down. 10/12kW models don't modulate down as much as 7kW though, and 7kW doesn't modulate down as much as 5kW can. There isn't a single value for miniumum kW output as this depends on flow/external temperature, but you can find this info in the data tables. You don't need an additional circulation pump(s) unless you have hydraulic seperation (buffer, HEX etc.). There is a preference to avoid hydraulic seperation in most install currently as an "open loop" approach is simpler, cheaper and generally gives best efficiency also. That said, there are cases where a buffer may make sense, this depends on how many circuits you have, what they are used for etc.
  19. Carpet cleaner might have worked, but it would need to be one with fairly strong water jets to list the fines out of the tarmac pores before sucking them up, rather than just brushes which wouldn't reach the fines. In the end we had our window cleaner have a go at it with a pressure washer and gutter vacumn (two guys, one on each). Took a while, and didn't give a perfect result, but I think we probably got 80% back to as new cleaniness/permeability. Enough to lay resin without being concerned about pooling anyway. That said, we did go for a thicker 30mm resin system on a plastic grid, vs. the intial plan which ws 18mm bonded directly to the tarmac, to mitigate risk further.
  20. Control cable is often used to connect a CT clamp of some kind and allow the EV charger to do load management. Some EV chargers also have ethernet connection. Don't think load management is required, but depending on your main fuse size and expected load may be a good idea to have in place. This can be a seperate cable, as @Alan Ambrose said, doesn't have to be special all-on-one EV cable. 25mm2? Is this 50m+? Seems overkill otherwise..
  21. We had 70mm open-graded tarmac laid on our drive just before we moved in 3 year ago. Since then, we've completed landscaping works and one of the few remaining things to complete things is to lay some resin. The result needs to be permeable and shouldn't pool. Permability after it was installed was great, with only a very small amount of surface water for a short period of time if there was heavy rain non-stop for a week. However, duing landscaping work, getting MOT and topsoil on the drive was pretty much unavoidable, and while it is still somewhat permeable we do have significant pooling in a number of areas. I haven't wanted to rush into getting resin put down as we don't want to proceed with resin only to find that the resin doesn't drain. The resin supplier has suggested a few things to mitigate this: - Drill holes in the tarmac, especially in areas we see pooling currently. - Use 10mm vs 6mm aggregate to increase permeability of resin. - Use 35mm resin on a grid, rather han 18mm directly on the tarmac as orginally planned (so resin layer can hold more water and water can distribute within resin layer). There are all great suggestions, and probably ones that we should follow, however I'd feel more confident if we could restore the permeability of the tarmac first. Pressure washing just move the fines around and doesn't improve things, so we need a different approach. According to Tarmac: However, the only versions of this that I have found online as large road-sweeper machine and charge £1000's day rate. Given drive is only 120m2 or so this does't make sense, yet I can't find anything smaller/cheaper or any self-hire options. I may well be looking in the wrong places though. I've wondered about hiring a higher power/capacity wet vaccum and then trying to do this myself and have also seen a product call "rotaryvac" [1] which I thought about trying to hire somewhere, but thought I'd see if anyone here has any experience of advice before I start experimenting..? [1] https://equip2clean.co.uk/products/kiam-rotaryvac-21-rotary-floor-cleaning-tool-with-fluid-recovery-vacuum-system
  22. As I said, mine may have stopped at 80rps because it had already drosted enough, hard to tell, but even when mine is running flat out at 100%, defrost only reaches 80rps. I graphed this via ebusd/emon: I also experimented by setting NR mode to -50% (limiting compressor to 60rps), and defrost compressor still rose to 80rps. I'm can't say for certain that NR doesn't impact anything related to defrost, but it certainly doesn't constraint compressor to NR setting on mine. IGNORE THIS. FORUM WON'T LET ME DELETE IT FOR SOME REASON..
  23. On my system, compressor speed on defrost only seems to reach 80prm (67%). It may go higher if needed, I'm unsure, but I haven't seen it go higher recently. Defrost compressor speed appears to ignore any noise reduction or eco modes, so AFAIK there is no way to limit defrost compressor speed or noise. My 7kW allow for -30%, does yours not? (I know the manual only says 40-60%).
  24. 80% was DALI or LED, and it was easier for electricians to use same cable everywhere and avoid any mix-ups. If you drivers are local to fitting you going to need more than twin-earth anyway, unless control is wireless or you have a seperate dali/dmx/tree/control cable. One example of where having this 5-core in place was handy was bedside lamps. We ended up choosing some wall lamps that have a wall light an a reading light, by using 4 cores were were able to give it a permannt live for the reading light (locally switched) and have the wall light on a loxone-controlled dimmer. We couldn't have done this otherwise once everything was boarded. It also meants that, when we finally source and install pendants we have option to use mains dimmed or DALI etc. You're right re: tree via 5-core. The scenario I was thinking about was a pendant in the hall, where we only decided later to use the Loxone pendant. What we did in this case was use the 2 cores (of the pre-wired 5-core) to supply 24v to the pendant, and then brought tree from the closest light switch.
  25. We used 5-core in most places for lighting unless we knew that the lighting circuit was definitely going to be i) single-color ii) use a cabinet-based dimmer. Wtih 5-cores we could then: - power RGBW or tunable strips from with central LED driver, - send 230v + DALI to remote drivers (all our downlights and some other fittings are DALI) - send dimmed 230v - could even send 24v + loxone tree if needed. (albeit overkill core area)
