Conor
    12
Everything posted by Conor
  1. Turn flow rates of your ufh zones down a bit.
  2. Is your heating system working as expected / adequately?
  3. Drill a couple small diameter holes through the door frame on each of the three sides then insert something like a small Phillips screwdriver until you hit the masonary to determine the depth, and therefore the true width. The holes can then be easily filled and painted over.
  4. You won't be able to claim the VAT back on this work unless it's on your planning drawings. Go back to planning and get it added in, if you want to keep it. Otherwise it'll have to come down. So you have your planning passed yet?
  5. BC and other parties were happy that the concrete in the ICF constituted adequate type B. I dont think I'd trust it in a full basement with hydrostatic pressure. In a partial basement, the tanking is more like a glorified damp membrane, as you SHOULDN'T get any hydrostatic pressure for any period of time.
  6. You don't need the internal membranes or drainage. Money for nothing. If it's a partial basement, with perimeter drain and clean stone backfill, then the external membrane and continuous, consolidated concrete are enough. Our partial basement was 200mm ground bearing slab (300mm ring beam) with tanking membrane underneath and on top of compacted type 3 (permeable) stone. So same as your details above but without the internal systems. We've had zero issues in the last four years. We used Koster. We than had 200mm insulation and 50mm screed with UFH on top of the slab. Our SE couldn't get a insulated raft to work as would have needed EPS300 throughout which was cost prohibitive. We've 2300mm head height in the basement. The absolute key thing here is, you've two sides open, which means as long as you've a proper drain, and loads of clean backfill, then the tanking won't reply come in to play.
  7. All sorted in the end. Two idiotic moments turned it in to a bigger job that nesecarry. 1. I missed a second isolation switch for the control module on the tank. 2. A sticky valve on one side of the pump that I didn't fully open. All Woking good. I've a potential tiny leak tho on the Flexi pipe to the ASHP. I need a bigger spanner.
  8. You want an architect on board BEFORE you go to planning. Are you going straight for full planning, or just outline (if it's an option?) What's the circumstances of the plot?
  9. Take it back to the supplier, get them to cut it to the right size. Though you might find somewhere in the small print saying their tolerances are something like +/- 5mm....
  10. Perfect John, thanks. @dpmiller have you done this before?
  11. Standard working hours are normal in construction, so you are not alone. A few points. 1. Is there anybody close enough to you to be disrupted by work outside of normal hours? 2. Are they the type of person that would be annoyed and make a complaint? 3. Be considerate and don't take the piss. E.g I waited until hearing the church bells on a Sunday before doing anything noisy. If that lot can make a racket, so can I. 4. Speak to your neighbours, give them your phone number, ask them to say something if it's disruptive. Our neighbours both had young babies when we were building, so we were very conscious of that 5. Dust and smoke. Manag dust effectily, e.g. wet cutting. Don't burn anything on site. Ever. 6. Don't give people any other excuses to get annoyed - keep your site tidy, put up proper signage and contact details. 7. Use quiet methods / equipment when possible. E.g. hire an electric Tele handler, use a transformer rather than generator, electric con saw rather than two stroke petrol (biggest noise on any site). So cutting /machining inside. I used my shipping container for cutting timber as much as possible. 8. The council really don't care unless there are repeated breaches, only then will you get a letter / visit.
  12. I had to disconnect and partially drain down our system to move our ASHP to allow renderers access to the wall behind. The best isolation I could do was at the buffer, so the only pipework drained was the mono block, and the 10m of flow and return pipework. All in, just a few litres of water. There's a air valve on the flow from the ASHP to the buffer. Nothing else. I'm going to take the opportunity to fit one on the flow at the first floor UFH manifold. What's the process for refilling / purging the air? Can the two bottle valves handle it? Do I just open all the valves I've isolated (buffer in and out valves, all manifolds), fill to 1bar and see what works it's way out? My concern is how do I get the air out of the ASHP itself? Just start up the pump?! I don't have a filing pump, so will be using the mains fill loop.
  13. Yeah, but how much material is it? 20g? it's not going to be in contact with anything hot either?
  14. When you go to an architect, don't give them any drawings / sketches. Just list out your needs / wants in the project brief and let them use their imagination. Keep playing around with your own ideas tho. Scrap that plan and start again, you've a huge amount of space to play with. Think of the size a room needs to be, then drop it into your floor plan. E.g. GF bedroom should be about 3.5x4m ex storage. Accessible shower room about 1.8x2m. utility/pantry the same, kitchen 6mx4m. Etc etc. word / PowerPoint is great for this. Just draw scaled boxes and move them around, like Tetris.
  15. I filled a bin bag with wool and wedged it into the hatch space. Pull it out when you need access.
  16. Dont use foam. Just use a length of pipe insulation.
  17. Yes, we used it. Great job, we chose it due to our very uneven floors and not having the time to put down PIR. Costs were similar at the time once you factor in labour. But these were our intermediate floors, (50mm pour depth) we didn't use it on the basement floor. Need more depth to get the right U value, and it becomes more expensive the deeper you go (as in PIR becomes cheaper per mm) UFH was stapled / clipped to tracks directly on to it. Not as easy as going in to PIR, we mostly used self adhesive strips and left staples for the bends.
  18. You don't need to screw in, you can fit bolts and plates into the lifting points at each corner and hang it off. You can buy bespoke kits, but I just chopped up a few pieces of left over RSJ, a large bolt, washers and nuts. Handy enough.
  19. This is ours. Stud frame, hung with bolts on the lifting points, 100mm EPS, wrapped in roofing felt, and clad using ripped fencing boards. About £2k. Wish I'd just bought a shed instead. Not worth the expense and time.
  20. For the brick vents, just nothch the timber around it. You can put a stop of dpc between the wall and timbers. What are you doing for insulation? Assume just 200mm mineral wool between joists?
  21. Give Kelly Landscape and Stone in Ballymoney a shout. Good range, and good prices and delivery by tipper lorry. We got our stone for £45/tonne. They'll have a self compacting gravel.
  22. I wouldn't go speaking anybody about this, because you are then forced to follow a route. Forget you saw it, if it crops up in the future for whatever reason, deal with it then. The work is good, the roof is doing what it needs to do. Persuing it now will cost you time, money, and stress. It'll likely never be noticed by anybody else. If a surveyor picks it up during a house sale, deal with it then. Fyi builders say "building control not needed" all the time, as makes their life much easier.
  23. No, no permission needed if they are effectively like for like replacements. If they are bigger, or in a different position, then yes, permission would be required.
  24. Keep them all the same way, left to right.
