marshian
    6
Everything posted by marshian
  1. Any update @richo106?
  2. I guess depends on the speed you run it thro the PIR - I didn't investigate it any further than ouch £400 that's not gonna be a cheap bit of kit for a single usage If I was doing a complete house suspended floor and warm roof I might have considered it
  3. I'm trying to keep it simple because I am!!!
  4. It's not the nicest material to work with - I think If I invested in a hot knife/wire cutting system it might have been better but using a sharp fine saw to cut 56m2 of 75mm PIR sheeting into individual joist filling slabs wasn't much fun
  5. I'm sure you are right but my brain can't grasp that. What my brain can deal with is that the skimpy roof trusses are well supported by the wall structure underneath so any load is spread across a wide area
  6. Thank you but I've discounted that as an option - you really do need T&G boards to make that even half decent and I would like to reuse the existing board that aren't
  7. Having insulated the suspended ground floor with PIR from the crawl space below I really don't want to have to deal with PIR again Cutting it down so it fits thro the loft hatch fills me with dread........... I considered removing some roof tiles and battens so I could post it thro in full sheet size to avoid cutting it and then making good but removed it from my thought process........ I do like the walk way idea for access but I need a storage area even if it's capacity is limited
  8. Was an option - last year when I was thinking about it - got as far as costing it out and got to £500 without any insulation cost - it's good but it's expensive and I'm not sure it's going to be any lighter
  9. Considered it but felt it was probably not the best place to put any load
  10. Oh and a picture might help - this one side of the loft from when I was moving the Cold water tank to a location that wasn’t overhanging the loft hatch It’s the same length behind me and there are two legs of the roof going out left and right House is a T shape so a lot of the roof structure is bloody hard to negotiate
  11. Bit of background - 33 years ago we bought the current house - it was built in 1982 and insulated to 1980 stds - Loft had 25mm of blown fibreglass loft insulation in the 75mm truss depth When I looked up in the loft it was clear that it was getting blown around - so some of it I replaced with roll style loft insulation in 75 mm and other areas I boarded out to stop the existing insulation moving around. I had an abundant supply of free euro pallet sized 22mm chipboard so it was easy to do piecemeal and they went up thro the loft hatch easily. I got power sockets and lighting up there as well as a decent loft ladder because I've moved the cold water store and CH header tank to make better use of the space (Well and to stop my back hitting the framework every damn time I went into the loft because it overhung the loft hatch) That's how it stayed for many years - a few areas of the loft got extra insulation laid across the roof trusses another 100mm so at best in some areas I have 175mm in other areas it's just 75mm - so pretty poor by modern stds I considered getting rid of the boarding but having the central area boarded out gives me good access to most of the loft without sicking my feet where they shouldn't and whilst it's only really got a few empty suitcases, Xmas decorations and a few sailing bits finding homes for them out of the loft would be difficult. I'd really like to increase the depth of insulation in the boarded out area and replace the loft hatch with a modern one with better seals and now the weather is starting to turn this is my opportunity to plan and execute I want to re-use the existing boarding where I can because it's already up there I had considered 8 x 2 Joists but they works out at 9 kgs per metre and that sort of weight plus the boards already used is going to build up quite fast - then there is the cost of wood these days........ I looked at loft legs but meh......... sorry they just look flimsy and well I'm not convinced. I'm not a lard arse but I wouldn't trust them Then I saw another thread on here where I-Joists were being used on a build - a couple of quick searches and it seems 220mm I-Joists are 3kg per metre They'd be a heck of a lot easier to man handle up thro the house and the loft hatch and it would get me much closer to the 300mm insulation depth I'd like to get to. All the internal walls of the house are thermalite blockwork and ground floor is replicated on the first floor so the roof trusses are very well supported but I don't want to put too much additional weight up there. If I-Joists are prohibitive cost wise I could probably cut sheet OSB down and tile batten and my my own Daft Idea or does it have some merit?
  12. It's actually quite a long border Suffolk literally surrounds my town and the next town from me Norfolk almost surrounds it - it's like no-one wanted either which is probably true!!!
  13. @Alan Ambrose I was hoping it would
  14. Amen to that - general knowledge base is poor and the general view is the UK doesn't need or want the benefits of DHWP / X plan - it's S or Y plan and that's your choice........... I my case I specified DHWP and "X plan" and I got a weather compensated S plan because the Gas engineer didn't know what X plan was - I should have got him to fit the boiler and commision it and done all the rest myself!!!
  15. Really nice work and great joinery too. Well done I'd be bloody happy with that for £4K I think we spent 4K last time we refurbed our bathroom 7 years ago but it was all off the shelf stuff
  16. I had my 100W (Heat only) fitted by a Viessmann trained Gas Engineer at the end of July I was really specific about what I wanted and how I wanted it set up (not specific enough in hindsight) Hopefully the HW demand box, the Wifi Module and the NO CH zone valve (to replace the NC zone valve that was fitted) will all get fitted very soon then I can turn on the weather compensation and the CH can do it's CH thing based on a the WC curve and the HW I can set up to do it's thing at an elevated flow temp in a reasonable time frame. Once it's all sorted I might do a little thread on it. It does amaze me how low the Viessman can go in terms of flow temp and output.
  17. Reminds me of my neighbour - He had a Viessman 100W Heat only boiler fitted - with weather compensation but not DHWP - consequently his flow temp is fixed for CH at 68 deg (Because any lower than that and his HW is not heated in a reasonable time) totally negates the point of weather compensation because the boiler isn't actually using it despite there being an outside temp sensor on the north facing wall. At the end of the day he's got a nice boiler but he's not taking any advantage of what it can do when the temperatures aren't -2
  18. I'm bang on the Norfolk/Suffolk Border but I'm Suffolk born
  19. This was my solution We never had a problem with pigeons on the close I’ve lived for 33 years till recently….. 3 years back English Heritage repointed up a local church ruins - all the nooks and crannies were filled up and all the ledges covered in spikes - so the population of pigeons and doves decamped 50 yards to the nearest houses Each house got 4 to 5 new roof top occupants The first year they decimated all the fruit trees and so we pruned them back the second year they destroyed every single young plant in the veg patch the other half does every year The other half tried feeding them to save her veg patch this year - they pulled the young plants up and left them The territorial males constantly fight for the right to f (party) - they s (defacate) over everything - windows cars patio decking it’s everywhere and I have one modern car with water based paint and the laquer coat is utterly ruined in places The doves I leave alone - the feral pigeons unfortunately I don’t - there is a “bird table” in the garden now that has a substantial back stop (6 inches thick) They soon get used to feeding from there They get a weeks worth of free food then they get despatched Downside is that as they seem rather territorial more move in But numbers are going down…… about 4 a fortnight
  20. I think that tells you all you need to know - they are working to a one size fits all script and complies with the BUS grant criteria I’d find someone who actually will design a system that meets your criteria which I don’t think is impossible at all No local “heat geek” trained installer???
  21. That is the value for the wall but for the section below it looks like averages the wall Window and Door area by the U value for each by area then divides it by the total area
  22. I honestly think you need to find another supplier - if they aren't listening you are almost certainly going to get what you don't want I am assuming here that you are going for the BUS grant?
  23. 330 m3 is a big house - are you really going to replace all that air in the house every hour? Seems a bit high? 21 Deg for all rooms also seems a bit high - if the house is relatively well designed and sealed then a target temp of 19 is fine for me
  24. 3.1 Oversize factor (from the Heat Emitor Guide) They are trying to improve the Heat pump efficiency by ensuring the operational flow temp is 45 deg is my guess so 3.1 x oversize for the room heat loss https://zlcenergy.co.uk/wp-content/uploads/2013/08/MIS-3005-Supplementary-Information-2-Heat-Emitter-Guide-v2.0.pdf
  25. That expansion pipe is full of water until it rises above the level of the cold store (Funny story I know this becuase I wasn't thinking straight one day and cut into it to change it's route without drain down - luckily I had a bucket nearby and some self amalgamating tape to temporarily cover my error) Anyway heat rises and it will be a source of losses (I am very tempted to fit a london loop in mine to see if it makes any difference)
