Everything posted by marshian
it’s connected and it sort of works - just haven’t documented that section of the wiring on my schematic sort of works………. I currently have to turn the boiler off to stop CH - it leaves the pump on 24/7 even if the controller says all good house up to temp lets wait for the call for more heat flow temp of 32 deg C today and all rooms are at target temp on trv’s so all the flow is going thro the bypass right now so I’ve stopped the boiler in the ViCare app
Current state of wiring centre orange now located in bottom right and linked to HWD box grey is now in the live lot (top row left side) Reminds me - all the grey cables at the bottom were clamped before the install after none were clamped and the clamps were gone….. as a result I bought another L16 wiring centre to get new clamps and screws because I was less than happy about unclamped wires in a traffic area (SWMBO) keeps her ironing board and irons on the floor and shes a bit heavy handed Remember this is a Viessmann trained installer - only one in 50 mile radius I hate ending posts negatively - shat’s done is done I’ve clearly reached a point where I need to do this myself and any help or advice in this direction is appreciated and I can move forward positively
Just to repeat - I asked for X plan - I got S plan (2 NC zone valves) with weather compensation (turned off because I like HW not CW) and set it up with a 55 deg flow temp no HWD box no wifi interface (was on back order) Installer came back with one new NO zone valve, HWD box (after I told him the part numbers for both) and said will you order it or shall I?) and the long awaited for wifi module he’s had two opportunities to get it working right on x plan DHWP and hasn’t really got it right - I still have issues with control on CH side so I revert to what I often have to do “If I want a job doing properly I need to do it myself’ DIY means starting from scratch working out what all the wires do and drawing up a schematic that makes sense to me - Electrics are not my strong point but so far no fuses have been sacrificed to my electrickery knowledge quest
you’re a very clever chap but either I am really rubbish at explaining stuff (and I can accept that criticism if I am) or your reading and comprehension skills are a bit poor and I’m going to assume it’s the former rather than the later for now As I said in earlier post CH side is not fnished in the drawing - I’ve just managed to get the HW side working as it should along with the transfer from CH to HW and back to CH having completed HW - not finished would account for some missing wires OK
You do realise "my drawing" is of all the wiring centre (well when I finish it) and what you have posted is a diagram of how the HW demand box integrates with the boiler 😞 I must admit I've borrowed the base drawing from an S plan which is what the gas engineer set the system up to work as despite being asked to set it up as X plan!!! 51011_01-mBox-L32-S-Plan-connection-drawing-FRAMELESS.pdf
I must have watched that video a bunch of times and I've not spotted that element Annoyingly the only video that Syzmon has done that featured a Viessmann 100-W B1GA turned into a little whinge fest about how he wasn't impressed about the fact the HW demand box and wifi module were add on units and the boiler front cover didn't have a sound insulation panel in it like the system or combi boilers did. He was making a valid points The HW demand box is a bit of an add on The Wifi module is hard to fit in the space and route nicely - if the ribbon cable was 2 cm longer it could be routed away from everything and look much neater than crossing the PCB at 45 deg When heating HW at 100% modulation the 16kW rated boiler I have is throwing 19kW and 80 deg flow temp at the HW circuit and it's nowhere near as quiet as it is when it's doing CH at 3.2 kW and 37 deg C I didn't want to convert to a 4 pipe system for all the disruption that caused and I wanted a boiler I could hide in a 300mm dept cupboard because SWIMBO wants to change the kitchen from white to black/dark gray and a white boiler on show would look crap Sometimes we have to compromise to someone else's needs/wants
But tying the two browns together does that too doesn't it?? Not being confrontational here - if I'm not doing the right thing then I'm happy to learn why I need to do it a different way but to my mind both ways achieve the same result I used the orange to power the HW demand box so I could have that in it's own section on the wiring centre because it's Viessmann thing to have an additional HW demand box.
I need a feed to go to the HW Demand box Putting Brown to Brown works and keeps the HW demand part simple CH in normal operation the NO valve is consuming no power and idle When HW is demanded - NC HW Valve and NO CH Valve share the Brown so both effectively energise CH Closes from Open HW Opens from closed Why wouldn't that be OK?
It is a good video But "Ideal Vogue" use 2 switched lives
I can't work out how to split up a long list of questions into individual responses so see below Yes (EB4 TRV bodies) and flow rates are suitable for lower flow temps When all rads in circuit - flow rate is about 1.1 m3/hr When TRV's start to cut in it drops down to around 0.5 m3/hr I'm not looking for 20 deg drop across any of my rads at a flow temp of 37 deg C - it would be impossible - the return temp would be less than the room target (or actual temp) Using heat geek table is a better guide to expected drop across the rads (or diff between flow and return) Flow Temp Return Temp Diff 55 38.5 16.5 50 35.0 15.0 45 31.5 13.5 40 28.0 12.0 35 24.5 10.5 Rads are sized to the rooms and all but one room they are oversized for the flow temps currently being used I'm not blaming anything on the boiler - I'm seriously impressed with the Viessmann 100-W "Heat only" - But I do have some control issues which I am working thro Done IR wall floor and ceiling checks - this thread is not about heat loss or improving it - I know what I need to do there and it comes after boiler control issues are sorted
Indeed it is - thank you sir One issue I see is that it uses a relay arrangement which I'm trying to avoid as I think it's not needed with a NO CH valve and a NC HW valve That diagram uses 2 NC Valves for CH and HW (hence the linking of the two oranges to energise boiler and pump) But It gives me a start that is slightly easier for me to get my head round than the Viessmann diagram (which I find really complicated) Not sure the world is ready for how far I've got (not complete) drawing up the X plan with crayons (to the same format as the std Wago (L16 wiring centre) but I'll share it so you can laugh
Right I'm resigned to sorting out the control side of the boiler myself HW demand is now working fine - ramps up temp and modulation and tops up a tank of water to 55 deg in 15 mins so no issues there The problems I have are I can't find a wiring diagram where a NO valve is used for CH and a NC valve is used for HW Often X plans are on boilers where HW/CH selection is done with 2 switched lives Closest I can find is However whilst it gives some valve wiring options it doesn't cover the X plan set up I don’t have an NTC sensor (Shown as Cylinder limit Thermostat) so ignore that The HW tank supply has the 2 port Normally Closed valve NC Valve has 5 Wires Live (Brown), Neutral (Blue), Earth (Yellow/Green), Grey (Live feed for the internal Switch) and Orange (240V output when valve is fully open) The CH supply feed has a 2 Port Normally Open Valve NO valve has 3 Wires Live Brown), Neutral (Blue) and Earth (Yellow/Green) I've set that side up so when the Cyl Stat calls for heat the brown “Live” powers up the Normally Closed Valve to Open (the grey wire has permanent power but it only goes to an internal switch that makes when the valve is fully open and puts 240v to the Orange – the power from that goes to the Cylinder demand box to tell the boiler it it’s doing HW – it ramps up to 80 deg C and modulates as high as it can based on return temps to heat the HW cylinder (coil) to the target stat temp in the shortest time possible The same signal Live also powers the Brown for the Normally Open Zone valve for heating so it closes stopping elevated temp HW going round the CH circuit As soon as the tank stat is satisfied the live circuit to the zone valve is removed, the HW zone valve closes, the CH zone valve opens – the Live feed to the HW demand box is removed and the boiler reverts to weather compensated flow temps The only other issue on the HW side is if the HW tank stat picks up a significant drop in temp (the hysteresis is quite broad) then without anything being on the HW valve will open and the CH valve will close and the pump will start so I think I have a wiring issue in either wiring centre, Heating controller or very possibly Boiler.
And the best bit tonight I've established that in the current configuration giving the boiler control of the pump means it runs 24/7 regardless of a call for heat!!!
most radiators get hot first at the lockshield valve
marshian replied to Question's topic in Central Heating (Radiators)
When it was all we had to control the flow thro the rads you had one at each end of the rad -
And back to a dumb boiler again Pump wired directly to the boiler (so it has control) still getting 75 fault codes so that was a lot of effort for no gain HWD box reactivated - worked brilliantly - fired up the boiler and ramped up the power - tank of HW generated in 25 mins Switched over to CH in weather compensated mode - and the bloody boiler thinks it's still doing HW so instead of a 37 deg flow temp it goes straight for 80 deg........... On the positive side new pipework for flow and return to the airing cupboard is all done so at least I can put the floor back down
Does the water circulate thro the HW coil in reverse too?? Easy to check if TRV bodies are bi-directional they have a double headed arrow on them -
Anyway system now drained down (again........) I'm ready whenever he finishes his current job Might turn off the water and replace an iffy isolation valve (been on the list for a while)
Sounds like that would screw with your head!!!
I've just looked at the curves for the boiler at 0.2 slope Outside temps and boiler flow temps is in the table below Outside / Flow temp 20 - 20 15 - 22 10 - 23 5 - 24 0 - 25 -5 - 26 Mighty impressive - I'd have to rebuild the house to achieve that - I think I'll be doing really well to get down to 1.0
What's your heat loss at -2?
Update time Friday afternoon the gas engineer is making another visit - hopefully we will have the system running as it should by the end of the day........... FLW!!!
As I had to have the floor up in the room above the kitchen (where boiler is on an external wall) to run a 3 core cable from Circ pump in the airing cupboard (centre of the house) I looked at the flow and return pipes and decided now was the time to break up the twins so to speak (roughly 2 x 4m of 22 mm copper pipework run bang along side each other (with the traditional nails bent over to hold them in place) New pipework is far enough apart to allow 19mm of insulation around them - annoyingly I don't have enough spare 22mm lagging so that'll need to get ordered asap - just waiting on the gas engineer to come and connect up the pump to boiler wire. Still waiting on a resolution for the HWD/Weather comp situation so running it manually as temps start to get colder. I am absolutely amazed at how stable the flow temps are at 30 Deg and the length of the burns at very low boiler output. SWIMBO is less inclined to comment about the "cold rads" if the house is a comfortable temperature Bodes well for for my estimations that 1.4 slope would probably be a bit high but if I adopted a 24/7 approach I could go as low as 0.8 - but I think we will end up with 1.0 to 1.2 bearing in mind we heat intermittently as the house insulation overall isn't good enough yet. Hopefully the process can move forward again soon - I am mildly miffed that I'm still having to manually change boiler temps for HW and CH but I feel it's moving in the right direction
Week 2 Trench foundations and starter blocks
marshian commented on Susie's blog entry in The Old Cow Shed
FF = Ferguson Formula - A 4 wheel drive system that was applied to quite a few marques back in the day (Jenson and Opel) I've got more knowledge on the Opel side (as they are what float my boat) that and the fact a Jenson is out of my budget
