sharpener
    1
Everything posted by sharpener
  1. I have an OSO cylinder fed from a rainwater harvesting system and it suffered from low pressure which I thought was the crap Stuart-Turner pump. Turned out the inlet reduction valve spring had been corroded away by the acid rainwater and was providing no counterforce for the valve. OSO could only sell me a complete valve block but a 3rd party dealer had a replacement Reliance cartridge which was a lot cheaper. The next fault to come along was the pump, cracked plastic impeller shroud. S-T regard them as unmaintainable but I had the bits of a previous pump which had failed with a leaking shaft gland so was able to fix, no thanks to S-T. Will buy DAB if it fails again, you can get replacement glands for them. Other house has an Ariston cylinder with ?their own valve group which has a mesh debris screeen in it, MIs say to check this annually and I do this though I have never found anything significant in it. +1 for always giving the knobs a twist when I am up there and it is always reassuring to hear the water gurgle away proving the D2 pipe is not blocked with spiders.
  2. All sound advice. Should last for 5 years without probs. Have just taken an expansion vessel out of service as too small for new heat pump. Originally installed in 1995 and still in good working order. As well as the checks outlined above if you get a new one fitted make sure the precharge level is adjusted properly. Mine was left at the factory setting which like yours is 3 bar. This is too high for a system pressure of 1.5 bar and will mean the pv does nothing, the precharge needs to be about 80% of the working pressure as said upthread by ?@Beelzebub.
  3. Yes but unfortunately the 7kW Vaillant unit has a poor reputation on account of the defrost performance, the others are much better. ETA @ectoplasmosis might not agree.
  4. Vaillant data is all available in the Czech tables, easy enough to read without knowing any Czech.
  5. 3-phase is common in even small houses and flats in Germany so they would need to. Delta connection, no neutral. I had a Belling Lee cooker made in the '70s that for the export market had an elegant arrangement of busbars so the loads could be split onto the three different phases if required. Sadly expired 3 years ago, best cooker I ever had. Could do little things like use the top oven on the timer which I could not find in a replacement. All modern cookers seem to have fans to keep the controls cool which annoyingly run on for ages, maddening if you have a kitchen/diner. /reminiscence
  6. Well there are ppl on the FB forum who are heavily into numerical performance stuff and HA (notably Mick Wall who has published many helpful articles e.g. this) and they don't seem to have raised any big issues about the Czech tables. And many others e.g. @Dan F who is active on this forum (and the Victron forum as well) who is technically qualified and talks good sense. Of course there are also the usual contributors of misinformation and general nonsense but hopefully I have got to learn the difference for the most part. I would be interested in further detail of how the UK market is viewed by Vaillant. I can see it must be a bit odd viewed from Germany particularly the shambolic regulatory setup involving the MCS. I have also to say as an experienced electronics designer they do not help themselves. Example: the internet gateway is mostly sold in the UK with a power supply card intended to plug into a boiler not an HP, rather than the one with a 13A power brick which is more expensive and needs a power point. Since the main controller can be and is powered off the low voltage ebus it would seem obvious to do the same with the gateway, which would remove the whole compatibility problem. Also the current generation of HP products has no way of receiving s/w upgrades in the field short of swapping out the main pcb, it is now 2025 fgs. Will be interesting to see if the new range has this.
  7. Glad you found them. Even Vaillant SW Field Sales Manager did not know they exist. Have no idea why they do not seem to be available in English - or even German. For others here they are https://www.facebook.com/download/367541079323119/kl-06-e2-verze-01-18012023-2564719.pdf BTW I can confirm the 12kW is extremely quiet at less than about 80% output and not exactly noisy above that. Data seem to be accepted as accurate for the models sold in UK.
  8. Vaillant FB forum has the famous "Czech" performance charts in the Files tab, shows turndown of all models (which is pretty good). The 10kW is a software limited 12, you might as well have the latter as the min o/p is the same but it would give you faster HW warmup if that is a concern.
  9. Yes, the 10 and 12 are essentially the same. I have never understood the marketing philosophy behind this, maybe there is a max of 10kW or the corresponding max current draw in some particular market. As I recall there is some other special version for Spain. https://www.theheatpumpwarehouse.co.uk/wp-content/uploads/2025/06/Multi-Comm-M-Series-1-compressed.pdf data sheet not very helpful but shows the 9 kW dims are the same too. Google AI comes up with a forum snippet mentioning a min o/p of 4.5 kW for the 12 (which is a plausible but not very good turndown ratio). Some mfrs publish the refrigerant charge quantities for their various models, which might be illuminating if you can find them.
  10. I thought the received wisdom was that defrosting is worst near zero but below that humidity falls off again so efficiency lost from that cause is not at the lowest OAT and so you don't have to account for it separately. Mind you my system is sized for Plymouth (-0.2C) so there is not a lot of difference, OTOH I have never noticed it defrosting either.
  11. My money is on the PRV in the outdoor unit. It is a known weak component and you would not see the outflow.
  12. I wonder does it just let the pressure down to zero, or does it dump a substantial quantity of water beyond that and so need a lot to refill? Might be a clue in how much air you have to let out afterwards. A pressure relief valve when tripped might not re-set and continue to let by. There have been quite a few reports of the PRVs in the outdoor unit being faulty and replaced under warranty, you might not notice that as IIRC the outlet goes into the condensate tray and thence to yr soakaway, that is where I would start looking. Unlikely IMO, in that even if your system is divided into circuits the return pipework will go to a common point so everything will be at the same static pressure irrespective of which valves are open.
  13. Both inside the cover of the outdoor unit and elsewhere e.g. at the highest point of any loops, the furthest point of the rad circuit, the top of any buffer tank, near the expansion vessel, all manner of possible places. I even have one in the void where the HW cyl is, at the top of the feed to the coil.
  14. Sorry for delay but this sounds more like it, can you give me a link for yr steriliser please @JohnMo ?
  15. Have just come from a lecture/film about the chalk streams in Cambridgeshire and water use in new housing of which there is a lot. [Apparently the water abstracted from the aquifer lowers the water table so much that 20% of it has to be re-injected elsewhere to preserve the flow in certain chalk streams]. There is a big new development at Eddington on the W edge of Cambridge equipped with SUDS serving 8000 dwellings, the water is treated to render it suitable for non-potable uses (flushing loos, laundry) but the Drinking Water Inspectorate won't allow it to be brought into use. I asked what the underlying reason is, I thought such systems at household scale had been available for many years, what is the real problem? No-one seemed to know. Again, I mentioned our whole-house rainwater harvesting system citing 3 reasons it was not very practical for widespread introduction at the individual householder level: to get even the lower target of 80 litres/day per occupant you need about 50 sq m of roof per occupant where the rainfall is only 500 mm per year you need space for an underground tank it needs quite a lot of maintenance - filter changes, chemicals, UV lamps but these issues should be addressable at the scale of a whole housing developments. And again, I was told the DWI and/or Building Regs do not allow its adoption citing the difficulty of preventing erroneous cross-connections in individual houses. Can anyone shed any light on the truth of this and what might be done to improve the position?
  16. Certainly worth doing, I have read on the FB forum several instances of leaking PRVs (IIRC related to a change of supplier, no doubt chasing a few p). While you have the covers off there is a cable run where my Vaillant service man put a drip loop to stop water sliding down on to a pcb, apparently this is an undocumented mod. I topped up to 1.5 bar 10 days ago and it is back down to 1.3, seems to go down by a further 0.2 in use (sensor is on suction side of main pump) but have not been able to find a leak so just put up with it.
  17. Maybe I am not understanding your description but won't a few handfuls of fibreglass stuffed up the exposed bottom end of the boxing make a massive difference?
  18. They bolted down mine, rawlbolts into a concrete yard area. I was happy to see this as the twin-fan Vaillants are quite tall and machinery can creep about with vibration - my bench grinder is a bugger for this. Actually they had to do it twice! They pulled the unit forward to do the rear connections (rear clearance is only 200mm) but forgot to push it back. I made sure they put epoxy grout in the old holes.
  19. ATM it is exceptionally cold esp as it is still only November. Normally you would have a lot of spare heating capacity for most of the year. You can use this in different ways, for instance to limit the output during the evening peak by using noise reduction mode or setback. The difference between the 3 Cosy rates is I think much larger than the reduction in CoP from restricting the output in this way part of the time.
  20. Original FIT scheme we signed up to cost £14k for just 3.7 kW but the rates on offer were so high the actual payback was under 7 years - which sounded good then and is still the gift that keeps on giving. I.e. it has paid for another 3.2 kW capacity plus the battery inverter system, and is now making a contribution to the cost of the HP. Well in a sense you can bc you can do all the laundry and run the dishwasher on cheap rates, which with e.g. Cosy is under 15p for 8 hours in every 24. It took some negotiating but the DNO finally agreed last year to an unlimited export capacity. So with a nameplate capacity of 6.9 kW we have exported about 5.3 MWh in the last 12 months and imported about 5.5 so we are more or less in that postition. That is the fly in our ointment, the Pylontecs stop discharging when the SoC gets down to 10% so effectively we only have 90% of the capacity we paid for. Then there is the little matter of the inverter/charger efficiency. When the battery current is at 70 amps everything gets quite warm and this accounts for losses which are possibly another 5% in each direction.
  21. Housing Associations seem to be very active in putting in HPs for their tenants. Accounts for a large proportion of my installers business. And to judge by what is written on the Arotherm plus FB forum their contractors are amongst the worst for bodged installations, poor configuration and abysmal handovers (luckily was all OK in my case though).
  22. Loans/2nd mortgages for home improvements are long established (think double glazing and conservatories). There are also dedicated finance schemes for solar panels (we receive the junk mail as they seem to be able to get our details from some public register). And for HPs as well, IIRC some installers have links on their web sites. So you don't actually have to have the capital. And plenty of ppl seem to blow what they do have on expensive holidays and weddings, it's largely a matter of personal choice.
  23. Battery is now a sunk cost and depreciation not a consideration as it will probably outlast me! I cannot be doing with chopping and changing e.g. to milk Octopus Agile (even though I have an EV). So am on Cosy and charge battery to 100% every cheap period. This means I do not have to guess what the next day's PV will bring in order to leave enough room for it. (Havenwise might do a better job of this but is not compatible.) Also means we can do laundry/dishwasher at any time without penalty. With a buy price now 14.xx p and sell price at 15.00 I am still probably losing a bit bc of the round trip inefficiency but it is totally set and forget.
  24. Don't quite understand where your 5p comes from, 125 - 75 - 20 = 30 not 5 which is an appreciable saving. But in the real world you might need to sacrifice more like 6 or 7 kWh in exports to get 5 kWh out of the battery again which is starting to make it a very close run thing.
  25. Yes I get the depreciation calc which is often forgotten, but to arrive at the true cost of night-time usage you still have to add the cost of exports foregone which (with Octopus) is 15p/unit, and also divide that by the charge/discharge efficiency which might be as low as 0.8.
