kandgmitchell
    3
Everything posted by kandgmitchell
  1. Well one has to admire some Build Hubbers aspirations! We just stuck to two floors and a bit of timber cladding......... Interesting question though. One has to ask are the plants "materials" for the purpose of the regulations or "decoration" if they aren't actually incorporated into the structure of the building. That could branch out in all directions and sprout lots of discussion......
  2. and probably in the forum as it's under Ventilation.......
  3. I'd always use my PD rights wherever possible - after all they are your "rights" to develop your own property without having to apply for specific planning permission from your local authority.
  4. So you filled in the inevitable application form and no doubt paid a fee to the Council (who are responsible for road naming and numbering). If the address is still not appearing then I'd go back to the Council and ask why...... We found RM were quite quick but it took a while for some suppliers to have the house name turn up on their auto address filler in thing. I presume they pay to have it updated and some update more often than others.
  5. And I would agree - if there is no new circuit then there is no need for notification just compliance with the BS. I find that since you rarely get the entire circumstances explained in a post, it's more appropriate just to clarify the legislation and then let the poster decide if it applies to them or not.
  6. Well the regulations are quite clear. An electrical installation in a dwelling should comply with BS 7671 : 2008 (plus amendments). Said installation becomes notifiable to BC as follows: 12.—(6A) A person intending to carry out building work in relation to which Part P of Schedule 1 imposes a requirement is required to give a building notice or deposit full plans where the work consists of— (a) the installation of a new circuit; (b) the replacement of a consumer unit; or (c) any addition or alteration to existing circuits in a special location. —(9) In this regulation “special location” means— (a) within a room containing a bath or shower, the space surrounding a bath tap or shower head, where the space extends— (i) vertically from the finished floor level to— (aa) a height of 2.25 metres; or (bb) the position of the shower head where it is attached to a wall or ceiling at a point higher than 2.25 metres from that level; and (ii) horizontally— (aa) where there is a bath tub or shower tray, from the edge of the bath tub or shower tray to a distance of 0.6 metres; or (bb) where there is no bath tub or shower tray, from the centre point of the shower head where it is attached to the wall or ceiling to a distance of 1.2 metres; or (b) a room containing a swimming pool or sauna heater. So presumably if this is a new circuit then it's notifiable as even extra low voltage installations are covered (<50V ac or 120V dc).
  7. Well I found this with a single search. It seems to be the same logo but is only suitable for pedestrians and cyclists.... https://www.bes.co.uk/concrete-cover-and-polypropylene-frame-13425/
  8. In all cases the system was up and running normally, the last two events were 27th October and 18th November so about 3 weeks apart, the first was back in the summer. Whatever is releasing the pressure must re-set itself as you can top up and get everything working again. Currently working normally since the 18th. No obvious water anywhere. It doesn't take much filling from the loop to get the pressure back up. I've got a horrible feeling this is going to be like one of those odd noises in a car that the mechanic can never find.....
  9. Hi, I've a Vaillant Arotherm heat pump system that's been in and working for about 18 months. During that time we have experienced 3 cases of total loss of pressure in the system. The last was whilst we were away abroad last week and I had to talk my daughter through topping up the system using the filling loop, and re-setting the pump- isn't WhatsApp wonderful! There is no water in the tundish and the loss is sudden not a gradual creep. This suggests there isn't a leak in a loop because one would expect the pressure to degrade over time. It's almost as if the system is initiating an irregular process that involves using a particular valve or suchlike which when used, dumps the pressure and causes the system to shut down. I am about to start the process of taking this up with the installer but thought I would put the problem out there so I can approach them with a bit more knowledge.
  10. If the planning approval for the barn conversion has a condition removing the permitted development rights then you will require planning approval for the siting of the caravan post completion of the works to the barn. A caravan act licence (which I doubt the LA will issue as one is not required for a caravan within a residential property) will not override the planning requirements. The caravan act is more about operating a site in a proper manner than the principle of whether a caravan should be there from a land use point of view. A lot of the act has been repealed now anyway.
  11. My wife's laundry room when we were in the static was a cheap 6'x4' shed with just the cold water supply insulated. We went through a full winter including some snow with no issues other than a bit of complaining about going outside to visit it.
  12. Congratulations - worth sticking with it.
  13. Done properly, making sure the pipe is protected and the foundations are kept clear and founded below then the pipe should be at no more risk than lying quietly in your garden. Hence why the likes of Wessex and other WCs regard these things as low risk.
  14. Presumably the diversion costs are less than adding a 0.75m-0.8m strip of extension to the build?
  15. I'd say there's quite a lot of difference between diverting and building over. Building over - depending on Water Company if you meet their standard criteria you may not have to contact them for a formal build-over agreement. Wessex for instance lists six criteria, meet them and you just carry on (subject to BC) keeping photographic records. Diverting - you will need to submit a design, pay a fee, have the sewer CCTV'd before and after. Build manholes on the change of direction ensuring there is still enough fall between the two diversion points. Do it all within your property and have it inspected by the WC. If the sewer is less than say 1.5m deep and you can extend to at least 500mm beyond the furthest point out from the house my vote would be for building over for simplicity ( assuming no internal manholes). This is subject of course to the limited information provided.....
  16. How far out were you expecting to extend?
  17. Really? We had the choice of two Marley types. We found Danwood were very good at dealing with all the snags at the end of the year defects period. We haven't so far needed to make a warranty claim but I guess being Poland based any visit has to fit in with current builds nearby.
  18. Surprised that a bathroom door is catching on the floor. There should be a decent clearance under it for MVHR airflow into the bathroom and out via the extract duct. Are you the first owner or a later purchaser? Could someone have re-tiled the floor? Either way they are a European composite door with a rebate in the edge of the door itself that closes against the face of the lining rather than sitting inside it like UK doors tend to. If I recall the hinges look like this but on a larger scale. Perhaps they are adjusted by screwing in or out either of the two parts? Others may be able to help.....
  19. All the OP needs is an email to the adjoining owner saying " is it ok to deal with this matter by email and is this the email address you want me to use?". Then use email. That will satisfy the requirements of the order. As for witnessed signatures and using registered post, therein lies it no longer being a sensible negotiation between neighbours and becomes much more of an issue leading to involvement of expensive professionals. The OP needs to cover themselves by following the requirements of the PW Act properly but in a way that does not encourage the adjoining owner to become over concerned about what is after all, minor work. As for using post over email it would still be available to an unscrupulous person to post a letter the Friday before their neighbour goes on a two week holiday and still claim they didn't object, although of course a dispute occurs if there is no actual agreement to the works within the Act's timescales. The benefit of email is that you can check it from all over the world and I'm afraid it is being for everyday correspondence rather than just being confined to the workplace.
  20. So this is a new dwelling that replaces one that is now demolished. Who prepared your building regulation drawings for the new dwelling and what did they propose in order to satisfy the building regulation requirements which say: (3) Rainwater from a system provided pursuant to sub- paragraphs (1) (roofs) or (2) (paved areas) shall discharge to one of the following, listed in order of priority: (a) an adequate soakaway or some other adequate infiltration system; or, where that is not reasonably practicable, (b) a watercourse; or, where that is not reasonably practicable, (c) a sewer. That is the starting point. If building control have approved your proposal then provide those details to the planners as your surface water strategy. It would be unusual for planners to say "aha, we don't agree, we think you ought to be doing x" because they know nothing about the technicalities so should go along with what building control thinks is suitable.
  21. So first things first. What is your proposal for dealing with rainwater from the dwelling? If work is underway what did building control agree?
  22. If the adjoining owner consents to your proposals then there is no "dispute". If there is no dispute then no party wall agreement is required. However, you are obliged to act in a reasonable manner and not cause undue inconvenience. If you do then a dispute can arise during the works and then it all kicks off. Be aware also that the adjoining owner may have rights to support from your land in common law which are above and beyond the Party Wall Act so don't undermine his foundations or garden. Since the Electronic Communications Order 2016, email is an acceptable way of dealing with party wall matters. Negotiation is the key here and for all such small works otherwise you are just pouring money into surveyors pockets...
  23. That was in reference to your trial holes not the main works - although if the garage founds are ok you wouldn't be excavating for the extension I guess.
  24. From your sketch I can't see how you are not going to be excavating within 3m and below the neighbour's foundations. You will need to notify a minimum of a month before the work. You only need a party wall award if the neighbour either objects or fails to consent within 14 days of your notification. For such small work therefore you need to get them on board. Fully explain what you want to do as most people are reasonable and only want to be re-assured that their property isn't going to fall down. Explain that you need to formally notify them (but would have out of courtesy anyway) and when you do could they please just confirm back that they have no objection. If that happens then get on, do no more than you said you would and get the holes back filled asap.
