Adam E
Personal Information
  • Location
    Scotland
1983 profile views
Adam E's Achievements
Member
Member (3/5)
7
  1. I went with Scotframe their engineers specifies straps to slab, and soil investigation company and structure engineer specified raft foundation with enough steel to build a battle ship I was really interested is a insulated slabs as a few on hear have done but non of my professionals had worked with them so went with traditional.
  2. Brilliant thanks so Much I have just turned it off, really easy when you know how thanks again. Adam
  3. Hi what are the author settings
  4. Hi trying to turn off freeze stat, I have a 8.5kw ecodan latest version when you see the time the freeze stat was used and the fact that the system has Glycol I would like to turn this off on previous posts it mentions auxiliary settings but can’t find freeze stat anywhere is it a dip switch settings? Any help appreciate Adam
  5. Hi I realise this is an old post but covers my problems I am trying to turn on the Freeze stat mode on my ecodan 8.5kw asht latest version when I go into auxiliary settings I can find no mention of freeze stat the system has glycol antifreeze but when I seen this pie chart I was concerned as how much it was running any ideas how I can turn this off. Adam
  6. I also could not get a temporary habitation certificate (Renfrewshire council). Say no longer issued.
  7. Thanks for the feedback hopefully everything will work out ok for us and a holiday will be in order next year
  8. Ok I understand now. How long did the vat reclaim take.
  9. Hi Dave , we had building control out and are in the process of getting a few things sorted including a certificate for the mvhr which I self installed so congratulations on a massive step forward we haven’t done anything about the vat as I thought you needed the compleat certificate before you could claim the vat
  10. No idea of your build details but this might be a option https://www.ecomerchant.co.uk/news/paint-on-airtightness-really-are-you-kidding/
  11. Digger ! looks as if It was cut with a laser from Star Wars Enjoy your well deserved cider
  12. Hi it’s a standard (Toby ) that’s what it’s called in the west of Scotland, if you have a standard water key it will fit on to the flat bit which you need to turn a quarter turn, if you look just now the flat bit is in line with the pipe below turn it a quarter turn so it is across the pipe it usually doesn’t mater if you turn left or right but turn it clockwise , some time they are very tight but it will go.
  13. Thanks to all, I will also incorporate some sort of safety device to avoid potential problems !
  14. Hi that looks great,I was looking for the easy option but will start looking at unit options. Adam
  15. Hi all I am looking for units for raised washing machine and dryer, I found this online which would be ideal but no UK delivery due to brexit https://washtower.com/ any suppliers in uk ? Adam
