Benpointer
    6
Everything posted by Benpointer
  1. I wish it were so. But according to VMZinc's website cedar and zinc are not compatible: "Acidic products and products that can generate a galvanic reaction must not be used with zinc. Run-off from non compatible products onto zinc also must be avoided. In general, products with a ph lower than 5 and higher than 7 are not compatible with zinc.” https://www.vmzinc.com/en-gb/technical-support/general-technical-recommendations/compatibility
  2. Damn and blast! I think we might be in danger of making a big mistake with our cedar clad walls above zinc roof. I've raised it with our archtect (though can't help feeling it should be the other way around 🤔)
  3. Now you've got me thinking. How am I going to get the 3 WC soil pipes, 1 shower wast and 1 bath waste to the drain outside... on a single storey floor: B&B, 200mm PIR, 75mm screed? Here's a diagram of the drain positions with some red lines lines showing how they might connect to the drain outside but each of those soil pipes and waste water drains have to go straight down through the insulation and the B&B (through a block presumably) and all the pipework is in the ventilated airspace under the B&B - where it is inaccessible forever, so I'd better hope there's never an issue with it. 😱 Have I got this right? Is there a better way to do it?
  4. We've considered that but, it's all about timing now. Will it take longer to draft, sign and deliver a S106 or to have a BNG report created and signed off by Environmental Services? Who knows!
  5. The utterly ridiculous aspect of all this is that we're going to be planting about 20 trees in our 0.85 acre plot which is currently concrete and grass - no hedges, no trees, no shrubs, nothing.
  6. Question for the BH Brains Trust: For our 170m2 single storey new build we will be putting in a floor of B&B + 200m PIR + 75mm liquid screed over UFH. We plan to have a couple of shower trays, shown dimensioned in the diagram below. Obviously we could put trays on top of the screed, and maybe we will, but if we wanted to inset the traays at floor level, do we just box off the floor in that area and not screed it, then set the tray on the VCL over the PIR? Presumably on marine ply or some water resistant strutural boards rather than straight on the PIR? (Obviously we will need to arrange for a drain to emerge through the B&B and the PIR in that area, and no UFH where the tray will be obvs.) Any suggestions gratefully received.
  7. We're going for B&B rather than raft because: a) large footprint (180m2), b) heavy clay and risk of heave, c) we've 0.75 acre to spread the spoil so no muckaway costs. Yes, it will be baltic under the B&B but with 200mm PIR who cares?
  8. Our planning application appears to have been caught by this. Our planning consultant received an email from the planning officer: "You’ll be pleased to hear I’ve assessed the application and will be recommending approval, subject to ironing out final details such as agreeing conditions/obligations... The other outstanding issue is that the Council have been informed that if a self-build BNG exemption is being claimed a Section 106 legal agreement (S106) is required to ensure it is self-build and the case officer must instruct legal accordingly. The S106 will need to be signed and sealed prior to the determination of the planning application. Therefore, I’ll need your agreement before I instruct legal to generate the S106. In addition, if you able to provide details of your solicitor that would be helpful. Also, I’m obliged to tell you there are costs to the applicant associated with this as well for the instruction and monitoring of the agreement. Whilst some previous applications using the self-build exemption did not use a S106, it is now a Council-wide approach, that I have no choice but to request such." That was two weeks ago. We provided our solicitors' details the same day. Since then we've heard nothing. I reckon every week delay costs us £500 in rent 😞
  9. @mjc55, did you explore this approach with Dorset BC? I ask because we are facing the same issue, and we're also in Dorset. Thanks
  10. You think the foundations for a 50s/60s bungalow were 'designed'? When we extended and refurbished a 1960 bungalow, having built a big, well-insulated extension we had intended to gut and radically improve the insulation of the original house. But as we started to dig up the concrete floor to put in a new insulated floor we quickly found ourselves below the original foundations, which only seemed to be 500mm deep. At that point discretion got the better of valour and we quickly repaired the floor, accepting sub-optimal flooring heat losses to avoid walls falling down or expensive under-pinning.
  11. Also, just taping up the TP10 should give me a sufficient SD on the inside surely?
  12. Tbf they seem to want to insist that the inside layer SD value is >= 5x the outer layer SD value. Our outer layer is likely to be 11mm OSB/3 with an SD of 2.5. So we just need a VCL with an SD of > 12.5 or more. DuPont AirGuard Reflective has an SD of 2000 so should more than be sufficient. I have put that build-up to PYC to see whether they are ok. The problem is on Ubakus that build up gives an insufficient drying reserve.🤷‍♂️
  13. We're now investigating blown cellulose (254mm), with a layer of PIR on the warm side to get us to u = 0.1. However, the Warmcell distributor (PYC) are recommending that we'll need Smartply Propassive on the inside and Medite Vent on the outside, which would add £20 per m2 to the roof cost and that's before we factor in the cost of the blown cellulose itself. Given we will also have to have a 50mm ventilation gap then 18mm ext ply above the roof to take the zinc we would end up with 3 timber board layers in the roof: Smartply Propassive, Medite Vent and 18mm ext. ply. That seems like overkill to me - not sure why we can't go with a suitable VCL below and 9mm OSB3 above the cellulose. Ubakus certainly seems to think it's ok: The alternative might have to me mineral wool between the rafters rather than cellulose, which is a shame as I like the idea of blown cellulose. (-:
  14. As a full time wheelchair user this kind of b******s really p****s me off. I came across the incredibly restrictive stuff in part M4(3) about kitchen design (worktops capable of being raised and lowered, no cupboards under a sink or hob etc.). This is rank 'ablesplaining' - able-bodied people deciding what disabled people need. Fortunately, our planning consultant and architect say we can ignore part M4(3) as we are not specifically designing a "Wheelchair User Dwelling" even though its going a be a dwelling occupied by a wheelchair user 🤔 On topic IANAE* on building regs obviously but I can't see anything in part M that says you cannot have a WC lid. I suspect it's an invention by low-lifes who think they can sell a few more shabby cut-price loos by calling them "Part M compliant". Rant over 🙂 (* I am. on the other hand, an expert on wheelchair use and I would always want a lid on a toilet.)
  15. Apols - I have tried searching BH for the answer to this but remain confused. Can I get a grant for an ASHP installation in our new self-build (in Dorset, England)? Thanks
  16. Thanks - more good advice. This thread has helped me a lot, and as you summise I have now got to a position where I have a good degree of confidence in the company concerned. The risk is not zero of course but it's no longer going to keep me awake at night.
  17. I've now spoken to the Commercial Director. She's talked me through the company structure and history, and given me as much confidence as I am ever likely to receive that this is a long-established ongoing family business in good health. So I am going to sign up. Thanks all!
  18. The classic - a timber frame. I will talk to them about risk mitigation options but I assume the up front payments are for materials so I am not sure an escrow would work.
  19. Question to @Alan Ambrose or anyone else who feels able to answer: If, following the advice above, I find the company I am considering committing a fair chunk of up front money to is: quite small, reporting regularly and on time, only has three directors who are clearly members of the same family, saw it's retained earnings fall last year by 15% and those retained earnings are only 4 or 5 times the amount I am going to commit for... By Alan's advice, I should be cautious. But... If the company in question (call it A) is owned by, and has a charge due to, an ultimate holding company (call it B) with the same three directors and that holding company's retained earnings are 80 times my required up front financial commitment, and increasing... Can I then be reassured? Can company A go bust leaving a trail of unpaid creditors while it holding company B walks away with a big fat pile of cash?
  20. Mrs P. has fallen in love with Pluck: https://www.pluck.co.uk, particularly their HPL / FENIX doors (is FENIX a brand of HPL?) Fortunately there are others who do the same doors for, hopefully, lower prices: Husk will provide this kind of door for carcasses bought from Howdens, DIY-Kitchens or even IKEA, apparently. Still in the early research stages atm. Going to see Husk in Bristol in a couple of weeks. Whatever, doors we choose we'll be looking for Blum ironmongery - very solid.
  21. Coming to this a bit late but if you're still logging in from time to time @thefoxesmaltings ... I see you used Turners and had some vaulted ceilings - if you don't mind me asking, did you insulate below, between, or above the easi-joists? And where did the vapour control layer go? We're thinking of using Turners but I just want to get my head around the roof detailing. Thanks
  22. So, I am thinking there will be a calculated u-value from, say, 100mm PIR between the joists with nothing within the joists (i.e. between the webs), then say 150mm PIR over the joists. Sure it will be less than full-fill 100+150 PIR but better than just the 150mm over the top. Presumably could be calculated for the whole roof by calculating the % area with PIR versus % of unisulated joist. For 97mm joists at 600mm centres that's 83% PIR at 0.22u and 17% 47mm joist at 2.55u = 0.6u... Then add the 11mm OSB and 150mm PIR on the top to get an overall u of 0.11. Still, it might be easier/cheaper to simply put 200mm PIR on top and forget insulating between the joists. I don't want to full-fill the easi-joists because I'd like to thread services including MVHR through them. I am mindful of making the roof look very clunky though.
  23. Wall structure is as per this diagram but we're cladding in cedar / cement boards & render rather than having a masonry skin. Either 50mm additional PIR for u = 0.12 or 100mm for u = 0.09.
  24. Oh, some pictures: Floorplan: Roof truss plan: Cross-sections:
