Dillsue
    1
Everything posted by Dillsue
  1. If your house is connected to the grid and you plug a solar inverter into the house then the solar inverter is connected to the grid and will export anything the house doesn't use to the grid. There's a lower wattage limit of <800w where all of G98 requirements dont apply but likely any plug in generator would need to meet most of the G98 requirements. I'm not sure there's anything to stop you using plug in solar right now if it meets the grid standards. If the government are thinking of changing the rules on connecting small scale solar outside the current G98 rules then they'll likely need the buy in of the ENA/DNOs with changes to specs etc. Can't see that happening anytime soon??
  2. Here's a roofing batten version. Old hollow concrete blocks set in the ground keep it all on the floor and have done for 3 winters so seem OK. Under £100 for batten, panel clamps and stainless screws.......already had the blocks, DPM and fencing wire for diagonal bracing
  3. If you read the report that @DamonHD posted, and other sources, household batteries should be pretty near the bottom of the list of domestic risks to worry about and spend £££s mitigating.
  4. That's likely to ammount to more than just a "few £" for what was shown to be a very low risk upthread. Would you do that for a tumble dryer or any other appliance, or a garaged ICE car all of which seem to pose a greater fire risk than a modern battery pack??
  5. Reminds me of peeing around with fireworks as a kid and getting chased by ripraps, helicopters and aeroplanes!
  6. Highlights suggest a very low risk from home battery systems so probably not something to be too concerned about but do your own risk assessment
  7. AFAIK everything to do with battery location and fire protection are all recommendations and there's nothing mandatory. One thing you want to understand is if your insurer stipulates anything??
  8. Might be easiest to suck it and see by bypassing the accumulator with the flow pipe and replacing the scondary pump with a straight section of pipe. Avoid sharp bends/elbows in the accumulator bypass!
  9. No idea about how NG operate but I emailed the SPEN area engineer who got a junior engineer to reply and we had a verbal agreement in a couple of days to double our existing 3.68kw G98 limit. Submitting the G99 form was just to formalise things...and take some cash off me!
  10. Stupid of me to assume the air inside the house was damp when you mentioned rusting stoves and wok. I should have realised that you might keep your stoves and wok in the garden......no wonder the stoves don't heat the house if they aren't in it. I'm done here. Adios
  11. All those damp issues will almost certainly be due to you not heating the place adequately. When you breath, wash or the plants in your avatar respire, moisture goes into the air. If the surfaces in your house are cold the moisture will condense as water and you'll get all the issues you mention. Again that's physics. All of those issues will cost you so that cost needs to be set against the cost of paying extra to heat the house.
  12. That's way lower than I though but still meaningless to @zoothornas a numeric value.
  13. A hole in a wall or an open window or door is uninsulated, everything else has an insulation value even if its low. That's physics. Your stone walls likely have a better insulation value than early double glazed windows
  14. I think that is a recurring theme
  15. Someone posted a link above to the Vailant controller manual which tells you what the moon symbol means.
  16. Flow temperature is the temperature of the water coming out of the heat pump/boiler. The "medium number setting" would be whatever temperature your system was designed to run at...did you get any paperwork when the original heat pump was put in? If you want the best efficiency you want the flow temp to be as low as possible as that is where heat pumps are most efficient. If you run low temperatures you need bigger radiators to compensate for the lower temperature. In a high heat loss house like yours you'd need some pretty big rads to be able to run the heat pump at low temperatures for best efficiency. The size of rads question has been touched on earlier in the thread!
  17. Isn't the Vaillant stat embedded in the controller which zoot is thinking of relocating.....already within the house?? Our LG is set up seemingly the same with the LG controller having a built in stat and a third party stat is wired to the outdoor unit. Isn't that similar to lots of HPs??
  18. Im sure the easiest way forward for zoot is to relocate the existing stat/controller.....all terminals are know and visible to zoot so easy to replicate with a longer piece of cable. More importantly it's all at ELV!!!! @zoothornthe stat/controller wants to be located somewhere that is representative of the house temperature. From what you've said that wants to be in your living area. If you're going to be turning off the heating upstairs then that's not the place for it, nor is the kitchen, bathroom, workshop, porch or outside! Keep it away from your woodburner and radiators.
  19. Just reread what you asked and realised that you're talking about the HW temp in your HW tank?? In that case the answer is no. The heat pump runs at different temperatures when it's heating the HW tank and when it's heating the radiators. The change in temperature is done automatically but you can set the time and temperature for both the HW and central heating.
  20. Yes it does...the hotter a radiator is the more heat it gives off. The hotter you run the water leaving the heat pump the less efficient it becomes so it uses more electricity and costs you more to run. The solution to this problem is to run the heat pump cooler and have bigger radiators.
  21. Any excess PV goes to power your neighbours and likely reduces their fossil fuel demand so a lot more to use surplus PV for other than generating export income. A definite meaningful use for it especially if it's tax payer funded via grants/subsidies
  22. Unless you've got a sizeable solar array and batteries, solar wont generate much electric in the winter when you need the electric the most to run the heat pump. You're probably better spending your money on sorting out the heating system you've already got to get the lowest running cost you can. Once you've done that you can choose how much or little you heat the place.
  23. I don't know the vailant controller but it likely you have the following options- Permantly ON with a fixed but adjustable flow temp. This allows you to set what ever temperature you want for the water leaving the heat pump. The heat pump will run continuously producing water at the temp you set. As an example you could set the heat pump to heat the water to 35 degrees and it would produce water at this temp 24/7. Timed heating blocks with adjustable room temps for each timed block. This sounds like how you've been using it with a heating block in the morning and a second block in the evening. In between these blocks your heating is off during the day and overnighf. Add a timed heating block between the morning and evening blocks and between the evening and morning blocks but set the temperature 2 degrees lower than that set in your morning and evening blocks. This will leave your system heating 24/7 but with a 2 degree set back during the day and overnight. This leaving the system ON with set back You don't need a thermostatic valve to keep your bedroom cool as you can likely use one of the valves currently on the radiator. If your system was set up correctly there should be a valve either end of the radiator. One should have a cap that stops you easily adjusting it and this was used to balance the flow through each radiator.....you shouldn't alter this valve. The other valve should have a knob on it that allows you to open and close it. Close this fully then open it a quarter of a turn and see how warm the room gets at night. Open the valve to get the rad warmer or close it to cool the rad but only change it by 1/8 turn at a time. Most people would want the room heated but cool enough to sleep so tweak it to suit what you want.
  24. And what if the "pro chap" is wrong? Thats perfectly plausible. A "professional" company told me I needed a 12kw heat pump when my calculations said 8kw was my heat loss. I put in a 7kw pump and the house has sat at 21 degrees since mid September. Not all professionals are as professional as they should be so maybe have a rethink on what people are saying in this thread, some of whom I believe are professionals. Don't forget the professionals that have managed to heat to old stone building linked to previously. Google historic England or the energy saving trust for lots more examples.....they're all professionals
  25. It's not the uninsulated nature of the rooms that's the problem, it's the way it's being heated. By that I mean the way you are trying to heat it and/or the way the system has been designed, installed and set up. That's not a snipe at you. You've said the bathroom is heated with a towel rail which typically have a very low heat output so they'll only work in a well insulated bathroom or where the bathroom is surrounded by other warm rooms. If you post the dimensions of the bathroom walls, door, window, ceiling height and how each wall is constructed I'll estimate the heat loss and compare that to the likely heat output from your towel rail.
