Dillsue
Everything posted by Dillsue
If you look on the ENA Connect Direct type test register there's a few grid compliant V2x chargers listed. Octopus and Indra have a few and one or 2 others but not many.....nothing from Sigenergy. If your car has V2L with 240vac outlets for camping/power tools, I beleive you can wire these to the generator inputs of Victron inverters fitted with genny inputs. Could get you up to 3kw out of the car??
- 14 replies
- 2
Thanks for that. It adds more confusion as within the setup options you can configure the inverter to run without a battery!!! Did you have any PV input when the battery failed? I'm wondering if it needs a DC input from either PV or battery to power up??
Anyone know if a solis S5 EH1P 5K-L hybrid inverter needs to have active PV connected to start up? I want to test the comms to its export meter and don't have any PV or battery connected but the unit is dead with just the grid AC connected and the on/off switch in the On position. Anyone know if these units will power up with only the grid AC connected??
Lowest profile flat roof ballasted system
Dillsue replied to Mattg4321's topic in Photovoltaics (PV)
You'd need to ask the manufacturer -
I think the building control specs I posted earlier are based on 25kg/m2. 10-11kg/m2 sounds quite light ?? -
Building control tables for C16 floor joists suggest 5x2" at 400mm centres will span 2.5m and 6x2" at 600mm centres will do similar. The 4x2" you've already got will likely carry several tons at the ends where they bear on the walls so bolting slightly deeper joists to the existing would likely be fine to prevent sag without bearing the new joists on the wall. If it were mine and the underside of the existing joists were pretty flat I'd glue and screw 2x1" to the underside of the existing joists to make a basic laminated joists. Another option would be to screw long strips of ply to the side of the existing joists. -
So that would make it a G98 compliant unit
G98 has more onerous/specific requirents than those in the harmonised standards associated with the various EU/UK directives. As an example you can get a CE/UKAS marked inverter that meets all the requirements to legitimately be sold in the EU/UK but you can't connect that to the grid without complying with the countries grid connection standards, G98/G99 for the UK
For some maybe. Out of the box our solaredge ones are higher!!!!
If your ditching G98 for sub 800watt systems how are all the safety requirements going to be specified??
Yep that's as it is....as previous page!! It will "self regulate" but those at the extremities of the flats will never get started on sunny days as the voltage will be too high. Without a stream of notifications every block of flats could have problems for years before the DNO recognises the problem and schedules in any alterations needed
Firstly, it can't be exempted as G98 covers a load of safety requirements. If they do away with G98 they'll have to write a new spec for plug in solar and that isn't gonna get done in a few months. G98 already covers sub 800watt generators and gives a few exemptions for those. Recognising plug in systems may be an additional exemption but still part of G98 Secondly, they can't dispense with notification because.....if all your neighbours installed 3.68kw solar but didn't tell the DNO then first sunny day the local voltage would rocket and push the voltage past the max limit and your inverter(when installed!) could trip. You wouldn't be happy. Imagine 50% of a block of flats installing plug in systems that the DNO didn't know about it so could bolster the local grid and/or drop the supply voltage, it would be bedlam.
That's not how it works. The right to connect generation up to 3.68kw is defined in the national terms of connection which is what legally governs everyone's connection. There's likely some exceptional situations where a DNO can object but generally everyone can connect up to 3.68kw. I put self installed on my G99 and my son in law put self installed on his G98 both accepted by our DNO Some sort of notification should exist so DNOs can manage the network. That could be a part prefilled G98 included with plug in solar so the buyer only has to fill in their address and post it. Not onerous stall to do that
Proposed changes to Permitted Development rights for small wind turbine
Dillsue replied to FarmerN's topic in Wind Generation
Similar to importing hazardous kit from un regulated sources.....the majority can probably evaluate the risks and manage accordingly, those that dont have a higher risk of "self extinction" -
There's already some exemptions within G98 for less than 800watt generators but the bulk of requirements are likely to still apply?? Most of the requirements are to ensure safety and grid stability so you wouldn't want to loose those. Definitely need to retain the notification process or you could end up with a massive install base on say a block of flats pushing the local voltage through the roof on a sunny day If you want to above 3.68kw then G99, but if you're adding to existing but staying under the 3.86kw limit for multiple G98 certified systems then I guess you submit a new G98 notification and list all the devices with a total certified limit of 3.68kw??
I'm sure the regulators do think of those but most certainly dont document those thoughts! -
I'm pretty sure that within compliant inverters there's multiple layers of disconnection so there's unlikely to be a scenario where a single failure within the inverter will keep the power on the plug -
Safety never comes with an absolute guarantee and its all managed/regulated on the basis of what is reasonable. Theres 1600 people killed on british roads each year yet were still all free to drive at potentially lethal speeds. Theres 1000s die prematurely each year due to poor urban air quality yet we can still burn oil/gas/diesel/wood in urban areas. Plug in solar, as with anything at dangerous voltage, might injure or even kill the odd person that misuses it or CHOOSES to personally import it and potentially bypass UK/EU safety regulation, but their loss is likely to be outweighed by the benefits -
A single <800w plug in solar is going to put around 3 amps into the circuit which the circuits MCB/fuse wont see. I dont know what the max a typical ring is rated for but I'd be certain there's enough difference between the max capacity and a typical 32amp MCB for the cable to safely absorb the 3 amps. I don't see why your spark was fretting about a single plug in solar and an adjacent load? Obviously if you're buying cheap stuff from non EU suppliers then you take on board the risk of using potentially unregulated stuff.....but that's as we are now with a whole load of dodgy imported stuff. Don't know where the granny charger that scorched a socket came from but the few weeks we used ours before a proper charger went in, and there weren't any problems. The plug was warm after a few hours but nowhere near damaging anything. Was the one your referring to a cheap import? -
?? Maybe I'm missing something but a faulty anything is limited to 13amp by the fuse in the plug which is way less than 2.5mm cable can carry. Any adjacent plug in solar is only offsetting what that faulty load would draw from the consumer unit but is again limited to 13amp by its plug? If plug in solar is limited to 800watt then it's hard to see a problem?? Unless....... If you plugged in multiple plug in solar units then you could have a problem if you also plug in multiple high loads, that's where the regulators might have a problem but thats the same problem Europe will already be dealing with?? -
Unless you want to join one of the export payment schemes AFAIK there's currently no requirement for MCS certification or testing for anything....products or installations?? -
The neutral needs to pass through an RCD/RCBO to monitor for earth leakage if there's an imbalance in current in the live and neutral. You don't have to break the neutral to do the monitoring although I think you can get double pole RCBOs in a single module width.
Not sure I'd want to hold the ac connection on any inverter with panels connected. I beleive the grid disconnect is via relays/contactors and I know the contacts do weld from time to time.
SEG is gov regulated so needs to be MCS installed. You'd need to notify your SEG payer if adding capacity. If you're on a Power Purchase Agreement such as Octopus Outgoing then that's between you and Octopus:) Be interesting to see how the likes of Octopus handle export from plug in solar??
From the government's Web site https://www.gov.uk/government/news/government-to-make-plug-in-solar-available-within-months "The government will work with the Energy Networks Association, DNOs and Ofgem to update the G98 distribution code and wiring regulations BS 7671 to allow UK households to connect <800W plug-in solar panels to domestic mains sockets, without the need for an electrician and with tailored safety standards" Not sure that will get sorted in time for IKEA to be flogging plug in units anytime soon??
