Roger440
    7
Everything posted by Roger440
  1. I know it makes sense at a practical level. Just not so much from a cost point of view. Plus, ive got to get someone that wants to travel this far.
  2. Handling tin sheets that size, even with the gear carries some risk. Get hit by one, you may well not live. You say a scaoffold and a cherry picker, but you still have to get it up there. Ive handled 5 metre long sheets before on vertical cladding. That was a nightmare. And we still have to keep the rockwool in situ while the tin is fitted. Your PIR suggestion is pretty much my suggestion last night. But without the rockwool. If i was sticking up PIR, why bother with the rockwool? I priced up 100mm PIR for the whole job. Its wasnt as bad as i feared. With your rockwool suggestions, do you envisage that being up against the existing roof, or with a gap/air space
  3. Following my above musings on using tin to retain rockwool, i then returned to thinking about PIR (or similar). Following Ferdinands suggestion of spay foam to secure, i could stick this to the roof, then add wires between the joists to ensure it definitely cant fall down. This would then only contact the lowesrt part of each corrugation leaving the rest open for ventilation above the insulation. More expensive than rockwool, much less than spray foam, but a fair bit of work. Hmmmm......................
  4. Thanks for the detailed reply. Much to consider You have correctly identified the core issues. Just to clarify a few points The humidity issue is soley about stopping corrosion. Sub 65% it cant happen. So that is the target. The temp is about being resonably comfortable whilst working there. Its a hobby. I have no desire to be freezing cold whilst engaging in hobby. I'll just sit on the sofa instead! Ref ugly, if its confined to the celing, inside, then i can liuve with it if i have to. Spray foam is truly ugly. I agree, rockwall is the cheapest option. As for holding it up, im not sure. Im yet to get up there to take a proper look, but the galvanised bits look to be pressed steel section, so could be nailed through if need be. However, i still need a covering to prevent fibres falling. This was where i referred to the yanks as per pic. Simply not available here. Good thinking on the PIV. Not thought about that. With regard to "rooms" inside, i replied to onoff on this. Im keen to avoid an excess of this. But clearly its a solution. Yor last bit, E, you mention cladding with tin. his is aneat solution in as much that it would be much easier to retain the insulation, potentially negating all the previous suggestions. But its not an easy task managing big sheets of to upside down. Need to ponder a safe method for that. Thanks again for your input.
  5. Im sort of partially doing that, or plan too. At the back, under the exsisting mez thats got rooms on it, i will close off as a workshop to do stuff like engine builing etc. Easy to heat, warm and dry. I also intend to have another similar area for one car that will be for welding, spraying and other properly messy jobs. But i keen for the remaining area not to be come too divided up. That restricts what you can use the space for as each "seperation" becomes a room dedicated to a particular task, which takes that space out of use for any other use. There will be 2 ramps so, along with enough room to work and sufficent height, its starting to get quite big. Plus wall create issues with approach angles etc. But your theory is sound. If i build that many "rooms" the cost will likely be quite high at which point i might just as well insulate the roof and walls anyway.
  6. I understand what you are saying. However, what i dont understand is what the nenefit is to constructing an additional internal ceiling/roof structure to carry the insulation and then leave a void above it. If there was a structure, sure. But there isnt. Well there is, it the existing roof. So leaving aside the exact process, why would i not just insulate that? And the whole building is then the heated envelope. What do i gain from your suggestion?
  7. I think you are probably right on the spray foam front. Just clutching at cheaper straws! Of course, the best starting point is a brand new modern composite panel building. Sadly, however, getting planning for such in a domestic setting is nigh on impossible. The only practical solution is to buy something that's already there, and even that's not easy on a strictly limited budget. So here we are. With a pretty reasonable building, but needs some improvements. Yes, there will be a lift or two, plus a limited mezzanine area with enclosed workshop below
  8. I currently rent a workshop that's very similar. Same roof. But smaller. With a lower roof. As it's not mine, spending big on insulation wasn't happening, thought I did seal it up, so I installed two dehumidifiers that ran 24/7. Fixed the humidity issue. However, rent covers unlimited electricity! Power consumption was a continuous 5.6kw. By volume this building is at least 50% larger. Look forward to your thought.
  9. It is an easy way to counter condensation, but in doing so humidity will be whatever it is outside. That's not conducive to the stuff inside sadly. Or retaining any heat.
  10. 22.5 x 12 x approx 5.5m high. So yes, just a simple box.
  11. I'm unclear why we need any airflow? On my last garage, I used composite steel cladding on walls and roof. 100% airtight. Zero condensation. Condensation only happens when warm air meets cold roof. If we insulate the roof itself, then problem fixed. Otherwise known as a warm roof I believe. In housing terms. Even if this is an industrial building. 2k of rockwool is fine. But how to keep it up there, and prevent falling fibres Spray foam is 10-15k. Not really diy-able, and even if I did, the bulk of the cost is the foam . I guess this is my fall back option and I'll just have to pay. But a rockwool based solution will be much cheaper as the material is cheap, but labour intensive to fit. But my labour is free.
  12. It will have an insulated door over it. It will only get used very occasionally if painting for example
  13. Realistically, I need to close it up. As per my earlier drivel, ideally I'd like it at 10 degrees during winter and need humidity to be sub 65%. If I leave it open, I'm not going to achieve either. I can heat myself as you suggest, but everything will still go rusty. While there will be cars, this is not a professional workshop/business, just a hobby shed. A big one. I'm installing a 3 ft diameter extract fan, so if I need to, I can change the air really quickly. Over roofing isn't going to happen. I have a tame commercial building roofer/builder. He reckons it's north of £20k to over roof. The building is 3000sqft, but the roof is 4000ft as there is a 1000ft covered yard at the front. Whilst it clearly doesn't need insulating, it would look properly shit if it was two different roofs and hieghts! So, hopefully you can see, insulating from the inside on a DIY basis is realistically my only option. Question is how???? I can't just bang rockwool up there as fibres will forever be dropping down. The yanks seem to fix the issue with a plastic sheet covered system, but it just doesn't exist in the uk. Hence trying to semi replicate with bagged rockwool
  14. It's three inch. There no closers over the windows for some reason, but yes, that was my intention. Hadn't got round to looking for a DIY option yet. Hopefully that exists. But I need to deal with the roof first as that's a thermal catastrophe.
  15. Wasn't built until 2001 so on safe ground with that.
  16. Don't know yet. If there is, I'd want to be closing it up! Otherwise I'll just lose any heat straight out. Bizzarely, the walls are cavity. I know the b&q link is old, but I believe you can still get it. But even if one side, is this going to stay dry?
  17. Holy thread resurrection! Im back. What i neglected to mention last time was i didnt quite own said building. But i do now Maybe a thread on the tired, poorly put together cottage that i need to do some serious work to is in order? But a man has to get his priorities in order doesnt he? So lets start with the shed. As always, fabric first, and before its completey full, i need to insulate the roof. Question is how. At as low a cost as possible. So far, this looks like my lowest cost option https://www.trade-point.co.uk/departments/knauf-space-blanket-loft-insulation-roll-l-4m-w-1-14m-t-200mm/182138_TP.prd Held to the roof with wires. However, my concern here is that given the roof is corrugated, am i likely to get condensation forming in the "peaks" which would then ineviatably run along the blanket till it finds a join? As you can see in the pic, currently, overnight it gets damp on the inside, then the sun comes out and it burns off. Light grey dry, dark grey damp. Thoughts? I was advised by a freind who does commercial building roofing, that they often put unbagged rockwool on top of the roof and "over roof" it, so one surmises condensation forming is unlikely, otherwise it would just get wet? Other options? The only viable one ive come up with is spray foam. Clearly that does away with the risk, but £10-15k to do it
  18. It is indeed a moot point. Its like comparing apples with elephants. Your heat demand on an oil boiler would be much lower too now you have insulated. You keep seeing this bandied about. You need a better insulated house so you can fit ASHP. Ive got a great idea. Do the insulation needed to make an ASHP work well, keep the boiler/heating you have and save even more money by not replacing a perfectly good heating system. Maybe its me, but you keep hearing on the radio. Drives me mad. Sure, on a new build with a clean sheet of paper, its a different situation. As for the noise, rather going to depend on the level of background noise. Either way, not anywhere near my house. I still regret installing a sewage treatment plant for that reason. Despite the many modifications to improve it.
  19. Electricity is a priority and will be available??? You sure. Given an abject failure of succesive governments to do anything remotely intelligent, and demonstrably so, id say you are wrong. Its clearly not a priority. Oil phased out? Not in my lifetime it wont be. It will be something if it is phased out to force you to be reliant on an unreliable electricity supply! Though i suppose its possible. ASHP, yes, noisy, Too noisy. But, as has been discussed is only a good option in a resonably efficent house. If you dont have one of those, not so much. There are limits to what can sensibly be achieved with existing properties.
  20. Oil. Oil. Oil Given the way things are going, especially with government, i think increased self sufficeny is where im going. Sure, fit an ASHP as well, but when its too expensive or power is not available, oil is going to look good. Indeed, until the price cap was confirmed, things were in danger of oil being the cheapest form of heating! The enviromental aspect is trumped by the requirement to have working heating when i want it. Not at the mercy of government whim/stupidity. Of course, for the boiler to work you need power. A battery will cover that, as its unlikely you will have no power for days. Well, depending where you are. Or, like me, buy a diesel genset as back up. Wildy inefficient. Unless you have a battery, then you can charge that meaning you can run the genset at its peak efficiency. Following ofgems announcements of possible interupption to supply, one feels strangely smug. The idea that there will continue to be super cheap electricity at night long term is one for the birds, so id certainly not base your decisions on that. I think at the new place, its oil, supported with a bit of solar, and possibly, subject to what i can achieve a bit of hydro.
  21. Ive got a robot mower. That gets stuck. Sadly, and predicatably, its gone wrong. Some electronic fault. Had to dispatch to the repair place.
  22. This i can understand. That is automation. Sounds like an awful lot of preplanning required, and no way would i want all that in my house, but i can see the benefits in that. Especially the opening the curtains to get my lazy arse out of bed! I still see no value in turning a light off from my phone whilst sitting on my sofa. Thats just complication for the sake of it.
  23. Dont understand this. So, you followed the rules, and he didnt, possibly, though it doesnt sound as bad in terms of rule breaking as you like to think. Let him sell it, and hopefully get a beter neighbur. Why prolong it? Plus of course, if you raise, what is essentially a dispute, you will need to declare it if you sell your house. The decision about buying is up to the buyer. If they are happy, thats their shout. I just did the same. Not a single planning or BC cert apart from the last 3 years. Do i care? No.
  24. Why dont you just get a vinyl wrap like the car people do. You can get them printed with anything. Lots of people doing fake "rustry" cars. Cheap as chips by comparison. Just found this too: https://www.ebay.co.uk/itm/165406795119?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338268676&toolid=10044&customid=CjwKCAjw7eSZBhB8EiwA60kCW5c0yr-uoZyw95AO0qgYWTSnlyg1MV53R74hw10CzlqW71xbzIbQOxoC7C4QAvD_BwE
  25. Building your own is certainly a solution. And yes, sure, i can see the parallels. Which i guess is why self building is such a small niche. Unless you are simply going for a full turnkey build, you will need to understand an awful lot of quite technical stuff if you are to end up with a resonable result. The majority of the population wont understand. Sadly, not everyone understands computers/ electronics/software. Which is where i fall over. Everything else, is, frankly a non issue. And is certainly, in part, why i seek to eliminate as far as possible. Because if i do have it, it will be a manufactured product, with the downsides you allude to. The issue with googling and the like, is they inevitably start at a level higher than me. And as you will know, online instructions almost never match the actual real world version as no one ever updates instructions. So i never make it out of the gates. Until tonight i had no idea what a raspberry PI is. Indeed, still dont really, beyond what google tells me. I have no idea what it is actually for? Or why i would want one?
