SteamyTea
    200
  1. Was it more of a case of Jack saying something ambiguous, and the rest of us thinking he is trying to take a swipe. Would not be the first time it has happened.
  2. Make a valued contribution.
  3. If it is between the leaves, then no. Loose one bit and rotate 90⁰.
  4. I would think if I had PV there would currently be days when I literally import nothing at the moment.
  5. I saw it as agreement that Craig is helpful, as us ETC. No more or less. No point scaring off a new member. We can do that later.
  6. How do you heat hot water?
  7. At around 60p a day, part of which is to bail out people that don't pay their bills, I think it is expensive. Yesterday I used 4 kWh, 3 at night, so 45p for that, 50p for the day unit, and 60p for the privilege. £1.55, a third is the rental.
  8. As do you. @jon-lee I used to make the tooling to make your reinforced concrete look prettier.
  9. Ours is covered in the scars of industrialisation and military bases. Some people think it is nice, but I doubt the live in an asbestos roofed concrete bunker, though some on here want to build in ICF.
  10. Yes, and all fancy fittings I still think that 'a house' can be built cheaply and of adequate quality. The real problem is, and self builders are the worst offender, is getting carried away. If, for example, you spend £7k on home automation, then forking out £2k on just the bathtub seems a bargain. It will still get a scum line on it the same as a £200 one.
  11. Make a T bream out of OSB. A decent adhesive, two battens either side of the T's "leg" should make it very sturdy.
  12. Starting to sound like (expletive deleted)ing witchcraft this gardening. I have heard that deflowering a virgin makes the volunteer potatoes stand to attention. Off to find a virgin for you.
  13. My usage is usually over 80%. Harder to do in summer as the usually day usage, around 1 kWh stays the same but the night usage goes down from around 10 to 14 kWh to around 2 to 3 kWh.
  14. Some Sunnyboys needed a special installer code to set them up. You ask SMA for it, they do some checks, then send you a code. Also, some SMAs can't be Sunnyboys, or Windyboys, quite different configurations, though the same inverter. You can usually plug a laptop into them and configure them, I think the connection software is on the SMA website. Finally, is it set up for the UK, they usually are set up for Germany, the SB TL4000 (may be renamed now) had a small dial that you had to set from 11 to 9 I think. Failure to do that caused all sorts of problems. There was also a problem with DC voltage on some if the smaller ones, usually got round it by oversizing the array by 20‰ to get a more consistent higher voltage. It is over a decade since I played with them, so much may have changed, but I doubt it.
  15. Evan old ones.
  16. I have no sense, nor am I common. Try suggesting it to them, there may be someone who is a bit of a realist.
  17. Would it not be cheaper, and easier all round, to just change your boiler to a smaller one. And give you a cheque for the inconvenience.
  18. @Ultima357 Have you plotted, at the hourly interval, solar power, OAT and IAT to see what is really happening. You may find that a bit of solar film cures 99% of the issue.
  19. Welcome Regarding the electrical side, Scotland has different rules to England, @ProDave, and Englishman Abroad, knows more. Our old mate Jeremy found a young, newly qualified electrician who worked at a reasonable rate because he (the sparks) needed to get wiring inspected and sign off for his CPD. Always worth asking at a local technical college who they have.
  20. If you know the mean temperature, and the standard deviation (use 6⁰C if you don't) that will be close enough.
  21. Yes. I am going to tell people that my bad habits are green, may save 0.1 kWh a year.
  22. You can also make high grade compost from coffee beans. Well that is what they claim at my local chain coffee shop.
  23. The Met Office has some historical data. The nearest station will be close enough. There is also Degreedays https://www.degreedays.net/
