Rafters done. Entry posted by Nestor August 4, 2017 4751 views Share https://forum.buildhub.org.uk/blogs/entry/229-rafters-done/ More sharing options... Followers 2 Monday and Tuesday were fine to measure, cut and fix 52 rafters. Next is to fit 75mm horizontals and fix Isoroof and membrane. Just had quote from BPC for MVHR, is everyone happy with the kit supplied? Please PM if necessary. Thank you.
Nestor 367 Posted August 6, 2017 On 8/4/2017 at 13:28, jamiehamy said: Happy BPC customer here. On 8/4/2017 at 15:26, JamieM said: also, happy customer here Thank you both.
Nickfromwales 7062 Posted August 6, 2017 What's the detail of the end support for the ridge beam in that first pic? A lot easier than a complex gable . ( Man-shed details still to sort before ordering timber ).
Russell griffiths 3280 Posted August 8, 2017 Looking good. Are the joists at wall plate height or are you having a raised tie.
Nickfromwales 7062 Posted August 9, 2017 2 hours ago, Oz07 said: Didn't fancy fixing ceiling joists first or are the raised? Vaulted ceiling maybe?
Nickfromwales 7062 Posted August 9, 2017 Second shot shows the timber clad steel mid-section. Mentioned in the previous entry isn't it ?
Nestor 367 Posted August 10, 2017 On 8/9/2017 at 11:15, Nickfromwales said: Second shot shows the timber clad steel mid-section. Mentioned in the previous entry isn't it ? Yes, its a vaulted ceiling. 10.5m long steel ridge beam with 2 steel posts. We fixed 250mm timber to steel to fix rafters and added another 4.8m of timber ridge to the end of the gable.
Ferdinand 3086 Posted August 11, 2017 (edited) Looks good. What is that Major bit of kit at the Front? Do not recognise. And are those concrete polishers? THought for a minute you had a couple of Dune Buggies :->. Edited August 11, 2017 by Ferdinand 1
Nickfromwales 7062 Posted August 11, 2017 (edited) A couple of off-roaders . Look like fun. . Edited August 11, 2017 by Nickfromwales
Nestor 367 Posted August 11, 2017 3 hours ago, Ferdinand said: Looks good. What is that Major bit of kit at the Front? Do not recognise. And are those concrete polishers? THought for a minute you had a couple of Dune Buggies :->. The Major is a flail mower (MJ22-140) for cutting grass and the grass polishers are a pair of Manco's. Old but still great fun with only 6hp. My 80 year old father in law had a go last week. 1
14 Comments
Recommended Comments
