Exploring the ratios and losses between building elements
Been a bit bored as I have not been able to concentrate on anything much recently, but life is getting back to normal.
I read on here a lot about the advantages of insulation, airtightness, MVHR etc, but this misses a few points.
Form is one of them, a simple cube is a pretty good shape for thermal efficiency, and the bigger it is, the better it looks.
So I thought I would knock up a very basic spreadsheet that can be used to explore the differences between size, form, thermal properties (just U-Value), air changes an hour for a cuboid.
This is basically to just show the ratios and theoretical power transfers.
Cells B3 to B11 can be changed with the snapshot results shown in cells B13 to B17.
Below that are some data arrays that show ventilation and fabric losses, and ratios for surface area to volume and fabric to ventillation for different form factors for the cuboids.
Not sure how useful this will be to anyone, but it does put numbers to changes i.e. you can change the ACH and U-Value and see which will have the greater effect.
This is a very limited scope spreadsheet, so a lot of interpretation is needed.
It does produce some charts though.
2
18 Comments
Recommended Comments
