What does it need to do?
It needs to process a few hundred bits of Larch cladding, and I suppose I'll be throwing some oak at it too.
And then it needs to be sold. Harsh I know, but that's life.
Budget £1000 ish.
Recommendations?
(Don't tell @MrsRA but I suspect that I just may want to keep it though. :ph34r: I can at least try)
Second hand 3 phase Wadkin with a rotary inverter if you haven't got 3 phase at home.
And don't try plugging it into an extension lead ...
Larch has a high silica content and is apparently bloody hard on blades.  Budget to buy a very good quality blade (or to replace cheap ones).
Whatever you get, just make sure that you can get compatible blades, cos an eBay item will prob have well worn ones. You will also need a workshop vac system; my little 150mm one generates enough waste.  God knows what a big jobbie will do!!
