Onoff Posted December 24, 2021 Posted December 24, 2021 2 hours ago, Adsibob said: Unfortunately according to the instruction manual, that does not have a manual override. Yes it does, p18, diagram 4.
Adsibob Posted December 24, 2021 Posted December 24, 2021 1 hour ago, Onoff said: Yes it does, p18, diagram 4. Ah, that is not what I meant by an override. I would like a PIR sensor that can either run as a PIR sensor or can be entirely overridden. The Steinel wiring sensor only be overridden to have the light remain ON. I would like a sensor that can be overridden so that the light can remain OFF even if the sensor would otherwise be triggered.
ProDave Posted December 24, 2021 Posted December 24, 2021 21 minutes ago, Adsibob said: I would like a sensor that can be overridden so that the light can remain OFF even if the sensor would otherwise be triggered. Simple light switch in series with the L feed to the PIR sensor
BobAJob Posted March 12, 2022 Posted March 12, 2022 On 24/12/2021 at 17:52, ProDave said: Simple light switch in series with the L feed to the PIR sensor Could be. We have PIR controlled outside lights but they also have a manual override on one of the light switches which will keep them on all the time. On 08/02/2022 at 16:31, saveasteading said:
saveasteading Posted March 13, 2022 Posted March 13, 2022 18 hours ago, BobAJob said: on 08/02/2022 at 16:31, saveasteading said: Not like me to say nothing. Assuming this reference is unintended.
