redtop Posted April 24, 2019 Posted April 24, 2019 just been quoted 2K for a 3phase supply, 1.2K for single. This is with us digging the trench. The 3 phase may be required as we will be using ASHP, plus hot tub and electric cooking, plus its on a 1 acre site so lots of outside lighting. We dont intend to actually power anything from 3phase although maybe we should look at it. Anyhow, given the low price difference any recomendations on what we should go for?
ProDave Posted April 24, 2019 Posted April 24, 2019 Yes I would choose 3 phase for that modest extra. If ever you get into hobbies that involve machining, 3 phase machines are often available cheaper than single phase.
PeterW Posted April 24, 2019 Posted April 24, 2019 Just remember that a lot of the cheap tariffs aren’t available on 3 phase so you may get stuck on a poor power deal. Also worth looking at the cost of a pair of meters and connections in side by side cabinets. Run the house loads from one, use the other to do garage, garden, lights etc. 1
scottishjohn Posted April 24, 2019 Posted April 24, 2019 I think anyone considering major PV in the future sometime , should go 3phase if installing a new supply . one could see that all houses may start to be fitted with 3 phase if we really get serious about home generation 1
scottishjohn Posted April 24, 2019 Posted April 24, 2019 (edited) 3 minutes ago, PeterW said: Just remember that a lot of the cheap tariffs aren’t available on 3 phase so you may get stuck on a poor power deal. Also worth looking at the cost of a pair of meters and connections in side by side cabinets. Run the house loads from one, use the other to do garage, garden, lights etc. correct -and it does give the possibility for the future if fitting 3 phase supply cable my garage has 3 phase supply ,but when i split it into 3 units one of them just has a single phase meter as its only a showroom +offices Edited April 24, 2019 by scottishjohn
Alexphd1 Posted April 24, 2019 Posted April 24, 2019 What you are planning to run no need for 3 phase but for the small extra I would put it in.
