Sand and Cement screed reinforcement?
bissoejosh
Assuming a non structural 85mm sand and cement screed how do I determine if I need reinforcement mesh/fibres or nothing at all?
Buildup:
Beam and Block
Sand blind / EPS
DPM
150mm Kooltherm K3
Seperation Layer
85mm Screed with UFH
Many thanks
1 hour ago, nod said:
and making sure you have a joint at each doorway
I have been thinking about this but did not realize it was a known construction option. Can the joint be formed using the same material used for floor screed edge insulation?
Sometimes they use a tool to create a slot in the screed while it is still green
Since posting I have been wondering if there is a downside. If such a slot encourages movement to occur at the slot and UFH pipes run through the slot is there a danger of local stress fatigue to the pipes at that point?
Highly unlikely given the expansion of screed per mm/C change and you’re talking about a crack or slot that is 1-2mm
at most and is then filled. At approx 10 millionths mm/degree, a 10m slab will expand less than 2mm for 20c rise which tbh would be absorbed at the edges if at all.
Some screeners will run ther trowel through the screed on each doorway
I always use a plastic screed joint
10 x100 mill Cheap as chips
They are just strips of double wall
Cut the excess pod afterwards
10 x100 mill
Something like this?
https://www.drainagesuperstore.co.uk/product/kform-k85-screed-rail.html
Or?
https://www.premiumtiletrim.co.uk/product/p-v-c-plastic-screed-expansion-joint-msr--beige-insert--by-genesis
46 minutes ago, Simplysimon said:
sorry to highjack post, if i screed prior to kit going up do i need expansion gaps? thought it would be easier to lay sand and cement rather than barrowing in through doorways.
I asked a related question about laying a ground bearing garage floor slab and was told that pouring concrete into a pool formed from a one block high perimeter wall would simplify the process. Not sure why you think such an alternative floor creation workflow influences a decision over door threshold expansion joints.
Will you be fitting UFH? I ask because I am thinking of the Grand Designs Graven Hill lady who suffered frost damage because cold weather got her UFH pipes due to a delay in creating a weathertight shell. Less of a concern for you given the current time of year.
