Metres Above Ordnance Datum
Sjk
There's nothing in the planning regs that says that you have to add to your site levels back to an ordnance survey datum. Have a look at other local planning applications. We just use a nominal datum on the street level.  At the end of the day, the planners is just want to be confident that the as-built levels are accurate and as designed relative to this street front.
We did the same. Set up a "Temporary Bench Mark" which was just a row of nails hammered in to form a line on a fence post at the highest point on the site, from where laser level datums could be measured.
All site spot heights were then just referenced to that temporary bench mark.
19 hours ago, Sjk said:
Cheers chaps, it looks like I’ll need a pro as the measurement need to be to the cm, the gps equipment is hugely expensive.
You can easily get this precision to a local datum with a Dumpy.
