could make a nice feature, a walk on glass floor in the kitchen with flowing stream running underneath, perhaps some mood lighting and the odd trout nipping about.
Try your neighbour first, if not then I think they will let it flow under your house, I’ve seen it happen a few times.
  • 2 weeks later...
Hi.
Just an update. I have managed to sort this out with the owner behind me. He is giving me 4x25m behind the house and I'm giving him 3x25m down the side. I will also be losing about 20-30m2 at the entrance as I'll have to set it back to give him access.
All in all, it's worked out good.
Thank you to all of you for the help and advice.
  • Like 2
On 08/01/2019 at 17:54, recoveringacademic said:
Rats.
thats total bollocks -springs and water courses are rgularly piped
just fit correct/larger than needed pipe   surround it in solid concrete with inspection /access hole both ends of unsder ground section
they cannot object to that
I've managed to sort it out now and I'm happy with the outcome. I'm not going to argue with them about culverting the whole length as I think it'll look pretty good exposed for part of it.
