I know this has been discussed on numerous occasions about leveling concrete floors and using self leveling but this can be expensive depending on the area involved and the depth. I need to raise my concrete floor about 15mm to nothing (not my fault) and over a large (ish) area and was going to use Grano dust with cement/SBR additive and SBR primed floor before starting. Has anybody else used this method before?
You can mix 5mm gravel into SLC as a filler and it works fine. Just make sure you’ve got a method of working out the levels as it doesn’t flow like SLC should.
I have just done something very similar, I mixed a mixer full of strong 3:1 sharp sand and cement, I then mixed a bag full of self levelling compound in a big bucket with a whisk , I then added the two together
it did what I wanted perfectly, why not have a play with a few different mixes to see how it works for you.
£10 for a bag is worth a couple of try’s
I think mentioned in a previous post
I used grano on an extension I built on our current home To match to the exsosting ashfelt About 25 mil down to ten It set like iron
I tiled it as one floor about six years ago Still perfect
6 hours ago, Nickfromwales said:
So it didn't set like concrete then ? ??
Fantastic stuff
years ago before the readymix screed We used to through a spade full in each mix when we where screening floors
4 hours ago, nod said:
Not seen this one before
Looks a good site
Yes it is a good site. What did you use to prime the floor before hand, SBR?
Sbr slurry
1 hour ago, nod said:
Sbr slurry
Did you put it down and put the screed on top straight away or let it dry first as I have only done while wet? TIA
