Triassic Posted August 24, 2018 Posted August 24, 2018 I have a foul drain coming up in the corner of my insulated slab. Doing my final checks ready for concreting next week I realised that the pipe coming up out of the floor was too short and once the concrete was laid it did not leave enough room to slide the next coupling onto it. So I found a longer peice of pipe, pulled the short one out of the hole and slid the longer peice into place. Then doubt set in! As the coupling was hidden below the insulation how could I be sure it has stated properly? I shon a tourch down the pipe, but couldn’t see the joint, do what next? I decided the tie a peice of string to my phone and turn the video on and lower it down the pipe, after a bit of trial and error and with the aid of a small tourch tied a few inches about the phone, I had confirmation, the joint was OK. If only I could share the video, it’s a sight to behold. 1
ProDave Posted August 24, 2018 Posted August 24, 2018 Offer the pipe up so it just touches. Measure what is sticking out. Then push the pipe fully home and check the amount sticking out has reduced by about 50mm. If not, it's probably not fully home.
Triassic Posted August 24, 2018 Author Posted August 24, 2018 24 minutes ago, ProDave said: Offer the pipe up so it just touches. Measure what is sticking out. Then push the pipe fully home and check the amount sticking out has reduced by about 50mm. If not, it's probably not fully home. That’s when the doubt set in. !!
Nickfromwales Posted August 24, 2018 Posted August 24, 2018 Your phone / torch based solution is magic mate. Exactly what I would have done ( eg used your phone not mine )
Russell griffiths Posted August 24, 2018 Posted August 24, 2018 OMG I must have a really nasty streak in me i was really hoping you where going to say it fell off the string. Sorry??
Jeremy Harris Posted August 24, 2018 Posted August 24, 2018 Best gadget I've ever made, bar none, is a dirt cheap Ebay bullet camera, fitted with a ring of white LEDs around the edge and connected to a length of cable, with 12V power connector and phone that connects to any video monitor, or an adapter that plugs into a PC/tablet etc. The number of times I've used this for checking things, helping to guide cables through hidden spaces, checked for things I've dropped behind things, etc, has paid the modest cost many times over. It has been so useful that I've even made up a cable reel to stow the cable on.
