john k Posted August 21, 2018 Share Posted August 21, 2018 I am building a loft conversion and was wondering if I can get a grant to help with the cost of insulation. I can't find the answer to this as it seems to apply only to existing loft space or rooms. Thanks Link to comment Share on other sites More sharing options...
AliMcLeod Posted August 21, 2018 Share Posted August 21, 2018 I think the answer depends on where you live, but seem to recall that you are correct that 19 minutes ago, john k said: it seems to apply only to existing loft space or rooms. Share where you live and others from that location may be able to help. Link to comment Share on other sites More sharing options...
Square Feet Posted August 21, 2018 Share Posted August 21, 2018 I tried to get that recently for an attic conversion and came to the conclusion it was a non-starter. From the folk I spoke to it seemed that I could only get it for the horizontal part of the attic, not the sloping part of the roof. As others have said though it seems to vary enormously from one council area to the next. I just googled 'free loft insulation' plus the location and it came up with several companies. I rang a few and they all said pretty much the same thing. They also had access to old home report energy surveys so they could see what was there already which was interesting. Link to comment Share on other sites More sharing options...
ADLIan Posted August 21, 2018 Share Posted August 21, 2018 The grant aided schemes are normally for upgrading existing lofts and are often means tested. Loft conversions come under the Building Regs along with the requirement for insulation at the roof line or flat roof. I assume the thinking is if you can afford a loft conversion then you can afford the insulation to go with it. Link to comment Share on other sites More sharing options...
newhome Posted August 21, 2018 Share Posted August 21, 2018 A few years ago, I’m going to say 7 or 8, the government handed out targets for things like loft insulation. The main energy companies provided it and it was meant to be for existing lofts with not enough insulation but there were no real checks, you just said you had none and they delivered it for a small delivery fee. Thus they met their target. Cue an abundance of insulation on eBay and gumtree. The rules are much tighter now. Link to comment Share on other sites More sharing options...
Temp Posted August 21, 2018 Share Posted August 21, 2018 Sometimes you just rocked up and Homebase and found particular rolls of Insulation was cheap that week due to a subsidy from the energy co. Sadly no longer. Link to comment Share on other sites More sharing options...
Ferdinand Posted August 22, 2018 Share Posted August 22, 2018 (edited) These are available via various routes for normal lofts, but - as you say - it is usually for the simple ones, and not on the slope. AIUI. I have had several rental properties done - most recently in December 2016 iirc. Ferdinand Edited August 22, 2018 by Ferdinand Link to comment Share on other sites More sharing options...
Triassic Posted August 22, 2018 Share Posted August 22, 2018 (edited) Grants in our area are only available to those on a limited list of benefits and low income. They only cover the flat bit of the ceiling, so room in the roof walls won’t be insulated. I have a friend who is on benefits and low income and even she does not qualify for a grant. Edited August 22, 2018 by Triassic Typo Link to comment Share on other sites More sharing options...
