114x140mm Sanding Sheets
Onoff
I've  borrowed a Makita palm sander that takes 114x140mm sanding sheets. What's  the norm with these, buy individual sheets or get it on a roll and cut your own?
And if individual sheets where best to buy them?
Cheers
That's a 1/4 size. (Standard sheet is 280x230mm)
But does that size allow for clamping (I don't know the model of sander) or do you need hook and loop for that size?
if to use the clamp you need longer then rolls is the way to go.
If for general use there is nothing wrong with Flexovit. http://www.toolstation.com/search?searchstr=33731 43484 11819 40207
9 hours ago, daiking said:
The only advantage I've found with proper sander sheets is the pre punched holes for vacuum extraction - if you're using it.
My palm sander has a hole punch plate so I can punch my own in cut sheets.
  • 1 month later...
1 minute ago, SteamyTea said:
Too late, but I always buy rolls, so you made the right decision.
Too late? Not at all, in my world I probably haven't started the job yet! xD
Actually it was for the tree house spiral stairs which are about 90% done.....the stairs that is, not the whole tree house!
