If placed directly under column, insulation would be dependent upon direct point load. You could possibly stick some aerogel underneath the post which would have minimal compression. Placement of post on a marmox thermoblock or similar would be cumbersome in terms of fixing through the block and also not sure of loading ability.
But plenty of options to insulate around steel posts with links as above and also here using aerogel:
