Triassic Posted May 22, 2018 Posted May 22, 2018 I’m in the process of building my ICF basement walls and looking at the manufacturers video it shows that the services can be placed into ducts cut And foamed into the ICF. What’s not clear is whether I can simply plaster directly onto the ICF. What have others done?
Nickfromwales Posted May 22, 2018 Posted May 22, 2018 21 minutes ago, Triassic said: I’m in the process of building my ICF basement walls and looking at the manufacturers video it shows that the services can be placed into ducts cut And foamed into the ICF. What’s not clear is whether I can simply plaster directly onto the ICF. What have others done? With ICF are you not left with insulation as your final finish internally ? If so the answer is no, as you'll need a board that accepts skim as EPS / PIR won't. What do / will you have that your looking to apply plaster to ?
Bitpipe Posted May 22, 2018 Posted May 22, 2018 I remember from our own ICF research that render can be applied direct to the outside face but the internal finish needs to be PB. http://becowallform.co.uk/wp-content/uploads/BuildIt.0616.ICF_.pdf Inside, the plasterboard is dot and dabbed to the internal facings and plaster skimmed ready for final finishing.
le-cerveau Posted May 22, 2018 Posted May 22, 2018 46 minutes ago, Triassic said: plaster directly onto the ICF. In theory yes, however my contractors batenned, boarded then plastered. Easier for running cables, depends on how much space (volume) you have can afford to loose.
ragg987 Posted May 22, 2018 Posted May 22, 2018 Might depend on the ICF spec. We used Integraspec and were told it was suitable for direct plaster or render application. However we used batten and board to create a services cavity internally. Externally we rendered direct.
Triassic Posted May 22, 2018 Author Posted May 22, 2018 I’d read that you can render directly onto ICF and on one or two of the American Build forums people had posted that they had plastered directly onto the ICF.
le-cerveau Posted May 22, 2018 Posted May 22, 2018 4 minutes ago, Triassic said: I’d read that you can render directly onto ICF and on one or two of the American Build forums people had posted that they had plastered directly onto the ICF. Our external render is direct onto the ICF blocks.
mvincentd Posted May 22, 2018 Posted May 22, 2018 I did the Nudura course and that left me with the impression you could apply direct but it was very important to do a very fastidious job of roughing up (Cant recall technical term) the surface.
Mr Punter Posted May 23, 2018 Posted May 23, 2018 I have used Weber LAC with mesh for external render on ICF. It is very sticky and you can sponge over it for a sanded render finish ready for painting. I am sure you could also skim it.
