Wet room floor for main bathroom finished. Some pictures:
A bit more (not a lot more!!) on my blog at the usual address
  • Like 6
Duly liked!
Did you wet or dry cut the "Union Jack" cuts in the wet room corner? And are they ceramic or porcelein?
Just shamelessly plagiarizing for when I do mine! :)
Edited by Onoff
Porcelain tiles 600 by 300mm No room for error. They were end of line sold off cheap at Topps. No spare black ones and only 1 spare white one. Yes I know I must have been mad.  It was daughters idea to use black tiles in the shower area. These tiles were chosen partly by their size meant an integer number of tiles filled the shower area.
Cut with a wet diamond wheel tile cutter. Marked out by laying the tile in place and drawing a line from the corner of the waste, to the corner of the shower former.  Drawings lines you can see on a black tile was another challenge.
Oh and this is the first time I have tiled a wet room shower.
The tiles used for the "skirting" were the same tiles but a different batch code so not an exact match though they looked pretty damned close to me.
I predict this bathroom will be finished before @Onoff finished his. :ph34r:
  • Like 2
  • Haha 1
15 minutes ago, recoveringacademic said:
OK, I'm running a book.
100:1 you finish after @Onoff  O.o
I'll have £1.00 worth of that. Let me know where to send the money :D
Nah, those odds aren't good enough to go for that :D
