ToughButterCup Posted March 4, 2018 Author Posted March 4, 2018 17 minutes ago, Alexphd1 said: Imagination .... anything is possible? Just worked it out for myself. Beam on the floor on two wooden bearers Two slings in the correct (balanced) position connect pulleys (chain brake and lock) Bring in scaffold tower: bottom transom missing raise beam one transom at a time remove transoms as you go up and then replace transoms underneath the as you go up brace assembly carefully during lift twist assembly until beam is lined up place beam You got me fizzing now @Alexphd1 If you wonder why I keep coming back to BH, this thread will do... just saved me £500 (per beam) i.e £1000. (minus the nett cost of some bits of kwikstage)
Declan52 Posted March 4, 2018 Posted March 4, 2018 If you have some blank round bracing pipe you can use them instead of transoms and some couplers you can make a bay as wide or narrow as you like.
ToughButterCup Posted March 4, 2018 Author Posted March 4, 2018 1 minute ago, Declan52 said: If you have some blank round bracing pipe you can use them instead of transoms and some couplers you can make a bay as wide or narrow as you like. The cheque is in the post, @Declan52 Yer a star, man!
Declan52 Posted March 4, 2018 Posted March 4, 2018 I used more or less the same method for my 3.2m concrete heads. Setup a bay in the middle of the opening. Clamped a ledger across in the middle to attach the pulley block to. Used the pulley block and lifted the head up as much as the slack on the chain would allow. Set the head down across 2 planks then moved the pulley block up and repeated till I had the head up. Took maybe 30mins work but was a safe and controlled lift. Just make sure whatever chain/sling is rated for the weight plus all your shackles are in good condition.
Declan52 Posted March 4, 2018 Posted March 4, 2018 7 minutes ago, recoveringacademic said: The cheque is in the post, @Declan52 Yer a star, man! No bother!!
Alexphd1 Posted March 4, 2018 Posted March 4, 2018 (edited) I think if I had more than 1 beam to lift I would seriously look at hiring a genie lift again for a week. Approx £120 Inc vat. Cracking bits of kit. Edited March 4, 2018 by Alexphd1 1
Russell griffiths Posted March 4, 2018 Posted March 4, 2018 1 hour ago, PeterW said: How much do you want ..?? I’ve to 48ft at single lift plus some extras such as 2 board steps and 2 board transoms..! I will need a fair amount but I haven’t even started digging yet, so not something I really want to spend out on yet.
Construction Channel Posted March 4, 2018 Posted March 4, 2018 1 hour ago, Alexphd1 said: Cracking bits of kit. cracking but scary when they are at full height
ToughButterCup Posted March 8, 2018 Author Posted March 8, 2018 Thanks @Alexphd1; here as a direct result of your post earlier is my little mobile work platform. Thanks very much indeed. I cannot tell you how much difference having a mobile work platform makes to our work schedule, and my confidence in getting the job done. It is already clear that having mobile work platforms will have a significant impact on the build. I am going to build four. Thank you. Ian 1
Construction Channel Posted March 8, 2018 Posted March 8, 2018 16 minutes ago, recoveringacademic said: I am going to build four. 4? surely if they are mobile you only need 1, 2 max
Nestor Posted March 8, 2018 Posted March 8, 2018 21 minutes ago, recoveringacademic said: Thanks @Alexphd1; here as a direct result of your post earlier is my little mobile work platform. Thanks very much indeed. I cannot tell you how much difference having a mobile work platform makes to our work schedule, and my confidence in getting the job done. It is already clear that having mobile work platforms will have a significant impact on the build. I am going to build four. Thank you. Ian @recoveringacademic Hi Ian, what wheels did you buy, can you send me a link, thank you.
