Toilet waste pipe placement
So when running 40 or 50mm waste in concrete what should be the correct procedure? Push fit/compresion?
  • Replies 58
  • Views 29.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Nickfromwales
    Nickfromwales
    I think they should give us our own forum
  • Last Night an ex DJ Saved My Life   "There's not a problem that he can't fix 'Cause he knows all the tricksAnd if your pan gives you trouble…"   'Cause away goes trouble down the d
  • Think your going to have to get the kango bit sharpened up. Get 2 45 bends and put them together. You might need a small length of pipe in between the 2 bends maybe 5-7 inches long to get you in the c
Posted Images
Push fit....
Ideally you need to connect above slab if possible, or use 110mm below slab and use an entry fitting to do the transition.
4 minutes ago, PeterW said:
Push fit....
OK, thanks. Its going to be a BIG decision to dig the run from the 110mm to the sink up as its going to be close to UFH pipes.
Actually digging it up just isn't going to be a safe/easy option. Just managed to find this (zoomed) image of the offending pipework.
One corner of the sink waste goes across the UFH pipe. Its the pipe that was sat in the top of that grey boss that was un-bonded.
I had this type of problem because a pipe moved after the slab was replaced. It was 110mm ducting for the water supply pipe and I used one of these to offset the entry a bit.
http://www.ebay.co.uk/itm/110mm-x-40mm-Waste-Pipe-Adaptor-/291514309082?item=291514309082&ViewItem=&nma=true&si=U4LuuKCsZavH%2BzIQ7TlciRWA2Z4%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
I'm no expert but that doesn't look right to me. I would have thought all that white pipe should be 110mm and under the slab not running through it.
Can't you just get your hand down there to clean the boss, brush on a good slug of solvent adhesive and push a bit of grey back down?
Same here, not a good layout IMHO.
Yep, and I think that's what I'm going to have to do. The runs of 50mm are fairly short and there is only a couple of solvent bends.
Of course that does assume there is solvent on the other joints!!
I guess I can try and rig some sort of pressure test up?
