Nickfromwales Posted December 7, 2018 Posted December 7, 2018 From tiling to sheep in a wink of an eye ???
Nickfromwales Posted December 7, 2018 Posted December 7, 2018 14 hours ago, Onoff said: @Nickfromwales, me again! Did you have some cunning ruse for trimming this corner without "sharp" edges. Getting close to it happening! Was it on these lines? Cheers. I think that’s about your only option. Having balls bigger than your brain is the problem here, as even I wouldn’t look forward to tiling that multi-angled extravaganza Pack the intersection with silicone so it’s oozing out of the gaps and then wipes a plenty to finish it flush. Should look reasonably seem-less then tbh. ?
newhome Posted December 7, 2018 Posted December 7, 2018 4 minutes ago, Nickfromwales said: From tiling to sheep in a wink of an eye ??? You know that’s how we roll here ? ?? Did we wake you up? ?
newhome Posted December 7, 2018 Posted December 7, 2018 Can’t you get bendy tile trim or is that a sh1t idea?
Onoff Posted December 7, 2018 Author Posted December 7, 2018 Just now, newhome said: Can’t you get bendy tile trim or is that a sh1t idea? The whole hot air gun / slit the back / bend it round something thing had crossed my mind. John the Chippy might be down this weekend so he might have an idea.
Nickfromwales Posted December 7, 2018 Posted December 7, 2018 40 minutes ago, newhome said: Can’t you get bendy tile trim or is that a sh1t idea? Stick to IT luv 2
newhome Posted December 7, 2018 Posted December 7, 2018 Just now, Nickfromwales said: Stick to IT luv Luv you too sweetie! 1
Nickfromwales Posted December 7, 2018 Posted December 7, 2018 33 minutes ago, Onoff said: The whole hot air gun / slit the back / bend it round something thing had crossed my mind. John the Chippy might be down this weekend so he might have an idea. If you think taking a heat gun to plastic tile trim will end in success, I’d recommend laying off da crack-pipe for a few days ?
newhome Posted December 7, 2018 Posted December 7, 2018 Maybe he should be looking at gluing the bit of wood he sawed off to make that awkward angle back on again
Onoff Posted December 7, 2018 Author Posted December 7, 2018 9 minutes ago, Nickfromwales said: If you think taking a heat gun to plastic tile trim will end in success, I’d recommend laying off da crack-pipe for a few days ? This cries out for a 3D printer.....matching the white though.....
Onoff Posted December 7, 2018 Author Posted December 7, 2018 45 minutes ago, newhome said: Maybe he should be looking at gluing the bit of wood he sawed off to make that awkward angle back on again You mean MULTIPLE bits... Never!
Nickfromwales Posted December 8, 2018 Posted December 8, 2018 10 hours ago, Onoff said: You mean MULTIPLE bits... Never! No retreat. No surrender ?
Onoff Posted December 8, 2018 Author Posted December 8, 2018 7 minutes ago, Nickfromwales said: No retreat. No surrender ? I posted that after a beer...in the cold light of day with a slight hangover / start of man flu it doesn't seem such a sensible boast! Pretty sure the picture framing guillotine is going to be invaluable for this detail. Other than that it's the Evolution Rage chop saw (non starter) or little plastic mitre blocks to cut this trim. Posted these before but it cuts real clean imo. 3
Pocster Posted December 8, 2018 Posted December 8, 2018 2 hours ago, Onoff said: I posted that after a beer...in the cold light of day with a slight hangover / start of man flu it doesn't seem such a sensible boast! Pretty sure the picture framing guillotine is going to be invaluable for this detail. Other than that it's the Evolution Rage chop saw (non starter) or little plastic mitre blocks to cut this trim. Posted these before but it cuts real clean imo. That’s a neat mitre !
Onoff Posted December 8, 2018 Author Posted December 8, 2018 22 minutes ago, pocster said: That’s a neat mitre ! It's a f**king nightmare. 67.5deg ffs! Luckily I've got a whole bunch of scrap trim leftover to practice on from when I re-did the pockets. 1
Onoff Posted December 8, 2018 Author Posted December 8, 2018 (edited) How many more miscalculations? I decided on an access panel, one tile wide to be able to get at the trap. Well, at least to change it by feel and with the assistance of a second person should the need ever arise. It was tight anyway with my gorilla forearms, compromised further now by the bundle of 20mm flexible conduits for the plinth lights. BUT...just realised that the access panel assumed one tile, central to panel. Now the run on the side of the bath will be "out" to those on the wall. Unless... Edited December 8, 2018 by Onoff
Onoff Posted December 8, 2018 Author Posted December 8, 2018 (edited) Back to the trim. Cutting at 67.5deg gives me this: Which is fine. Losing the post from the trim: Still doesn't look right: Playing with it: Because of the way the sides rake in: Hmm..... Edited December 8, 2018 by Onoff
Onoff Posted December 8, 2018 Author Posted December 8, 2018 (edited) Dancing from one thing to another here... Used CT1 Power Grab & Bond direct to the marine ply, no primer of any sort, this for the removable side panel. Figured easily replaceable if it does blow: This'll have another bit of tile stuck on below. There'll be a couple of super clean, diamond core drilled holes to affix it with st/st screws I WANT the top of the deck tanked. Realised I've run out of actual Aquaseal primer so as per the back of the can mixed up SBR 4:1 instead albeit Cementone brand rather than Everbuild like it says. I've used this mix on the top deck but not the sides: As I might stick the side tiles on with CT1 Power Grab & Bond I've done a little sample board to which I'll stick tiles to: Edited December 8, 2018 by Onoff
Pocster Posted December 8, 2018 Posted December 8, 2018 1 minute ago, Onoff said: Dancing from one thing to another here... Used CT1 Power Grab & Bond direct to the marine ply, no primer of any sort, this for the removable side panel. Figured easily replaceable if it does blow: This'll have another bit of tile stuck on below. There'll be a couple of super clean, diamond core drilled holes to affix it with st/st screws I WANT the top of the deck tanked. Realised I've run out of actual Aquaseal primer so as per the back of the can mixed up SBR 4:1 instead albeit Cementone brand rather than Everbuild like it says. I've used this mix on the top deck but not the sides: As I might stick the tiles on with CT1 Power Grab & Bond I've done a little sample board to which I'll stick tiles to: It’s Saturday night ! Wine and steak surely ; not tiling ??
Onoff Posted December 8, 2018 Author Posted December 8, 2018 20 minutes ago, pocster said: It’s Saturday night ! Wine and steak surely ; not tiling ?? More faffing than tiling! I've had bowl of vegetable & turmeric soup and a bottle of British Bulldog and that's it. Might dip into the crate of mixed Greene King IPA. Last night it was Spirit Of Kent 9 Hop XXX Pale Ale from Westerham Brewery.
Pocster Posted December 8, 2018 Posted December 8, 2018 28 minutes ago, Onoff said: More faffing than tiling! I've had bowl of vegetable & turmeric soup and a bottle of British Bulldog and that's it. Might dip into the crate of mixed Greene King IPA. Last night it was Spirit Of Kent 9 Hop XXX Pale Ale from Westerham Brewery. No proper food means mitring is poor ! Steak is food of the gods
Onoff Posted December 8, 2018 Author Posted December 8, 2018 20 minutes ago, pocster said: No proper food means mitring is poor ! Steak is food of the gods I've had a bag of Roysters T Bone Steak crisps if that counts? Tbh I'm pretty happy with veggie stuff but I "need" steak as in red meat (beef, kangaroo etc) every so often or I get "weird". Must satisfy some throwback dietary requirement.
newhome Posted December 8, 2018 Posted December 8, 2018 9 minutes ago, Onoff said: or I get "weird" Wondering how much weirder ....
Pocster Posted December 8, 2018 Posted December 8, 2018 12 minutes ago, Onoff said: I've had a bag of Roysters T Bone Steak crisps if that counts? Tbh I'm pretty happy with veggie stuff but I "need" steak as in red meat (beef, kangaroo etc) every so often or I get "weird". Must satisfy some throwback dietary requirement. Meat and wine can sustain you through your tiling woes .
Onoff Posted December 8, 2018 Author Posted December 8, 2018 4 minutes ago, newhome said: Wondering how much weirder .... Like I need to kill and eat something!
