Timber frame self-build with family annexe, Ipswich – plans and thanks
Hi all,
I've been lurking and asking the odd question here for a while now, so first of all a big thank you to everyone who's helped us so far, especially @craig @Owain1602 , @Nickfromwales , @JohnnyB , @Nick Laslett and @zzPaulzz . The knowledge and generosity on this forum have been invaluable.
A bit of background on why we're doing this. Honestly, if it were just us, we'd be very happy staying in our little 4-bed semi for the rest of our lives. The only reason we're on this self-build journey is our disabled daughter. We want her to become as independent as possible while staying close by, so the house is designed around a self-contained annexe for her and her carer(S), attached to the main family home.
We're now at the point where we'd really welcome some fresh eyes on our plans (attached). We're building on a plot near Ipswich, with a total floor area of around 350m², including the annexe. Planning hasn't been submitted yet, so this is a good time to catch anything we've missed. Any comments, observations or "I wouldn't do it that way" are all very welcome.
Structure
We're leaning towards a timber frame with I-joist walls and roof cassettes. The main reason is natural insulation (wood fibre, cellulose or hemp), for its decrement delay and to help prevent summer overheating, which matters as much to us as winter heat loss. Speed of construction is a big plus too. We're targeting U-values of 0.13 for the walls and 0.11 for the roof and floor, with a brick outer leaf and some Millboard cladding, plus a standing seam roof (Catnic Urban) with a small flat roof section.
Foundations
Our preference is an insulated raft, but we haven't ruled out traditional trench fill with something like Marmox Thermoblock to minimise thermal bridging at the wall-floor junction. The site is sand and gravel/crag.
M&E
  • Full MVHR for the house and annexe
  • ASHP with underfloor heating on the ground floor; we're still deciding how best to heat and cool upstairs
  • Solar PV with battery storage (AC coupled with safety the priority given the timber frame)
I'll start separate threads on specific topics (foundations, frame choice, cavity barriers and so on) and link them back here, so this thread can stay as an overview.
Thanks in advance,
Jeremy
PW1629-PL03revC Proposed Floor Plans and Elevs.pdf PW1629-PL02revC Proposed Site Plan.pdf
Edited by Jeremyw
Forgot to tag someone!
Welcome.
Had a quick look and two things sprung to mind when looking at your plans:
  1. Maybe worth considering a separate door into the accessible bathroom. Obviously not sure on the particular situation your daughter is in but just seems to me that navigating from the living room to the bathroom through multiple doors in a wheelchair is suboptimal and a more direct access from the living space might be a good idea.
  2. I notice you appear to have the main staircase to your upstairs through your living area. I believe this triggers extra fire safety measures that can add a lot of cost and possibly ongoing maintenance (sprinklers/misting systems). Worth considering if that is worth it vs an alternate design that avoids the need.
Thanks Rick, really appreciate you taking the time to look.
Great minds! We went through exactly that with the architect yesterday. A direct door from the living space into Jessica's bathroom is going into the next revision, so she won't have to go through multiple doors to get there.
Good shout to flag it. My understanding of Approved Document B is that sprinklers or misting, or a fully protected stair, only come into play when there's a floor more than 4.5m above ground, i.e. three storeys or more. For a two-storey house, an open stair rising from the living area is allowed as long as:
• every first-floor habitable room has a compliant escape window (min 0.33m² clear opening, 450mm min width and height, sill no higher than 1100mm)
So I think we're OK on that one, but I'll double-check and keep an eye on the escape windows to the bedrooms. Happy to be corrected if anyone's had a different experience!
No problem. I find it good practice to work through other peoples designs as a way of helping guide my own thoughts on my future project (still a long way away).
Great!
I believe the issue is introduced when you have a kitchen within that living area. If you could seal off the kitchen from the rest of the space I think it would be ok.
Thanks Rick. I think the kitchen separation comes from the three-storey open-plan option, where you need the kitchen enclosed plus sprinklers. For two storeys, ADB just asks for a heat alarm in the kitchen where it isn't separated from the stair, along with the escape windows upstairs. Our architect is obviously comfortable with the layout.
Ok, I've gone back and double checked and I think you are probably right. It's been a while since I looked at the regs and this was a specific area that I was interested in for my own plans. So no kitchen in same room as stairs (even with upstairs escape windows) was fairly firmly etched in my memory. Not sure where I've gone wrong in the past and I'm still half thinking there's a reason it's so firmly in my mind. Curious.
Defo not a requirement here. On a similar project currently with high vaulted ceilings and an entirely open central gallery, no issues.
It doesn't cause the need for higher fire rated linings/doors does it? Been scratching my head trying to work out why I had it stuck in my head. I'm very much keen on a open plan area similar to these plans but had ruled it out. Now I'm wondering what else I've got the wrong impression about.
Nothing more than escape windows in every room upstairs, and any closed route rooms on the ground floor.
For completeness, I recommended that the client installed an automatic fire suppression system; not just for safety for the family but also for preservation of the asset.
Furthermore, “automatic fire suppression” can be either a mist system or a sprinkler system, unless a sprinkler is specifically mandated; there are certain circumstances where you must fit sprinklers and cannot fit a mist system.
Most PD’s will knee-jerk towards a sprinkler, usually through laziness, whereas a mist system is usually suffice, cheaper, more elegant, much, much easier to install and route, and causes a fraction of the damage that sprinklers will cause (these run forever, eg until you physically turn off the water, but a mist is timed output).
Being in Wales (Pembs.) I am just about to go out for prices on this. The building is quite big (400m2) and I'm a bit concerned they may go over the top. When we got prices for the fire alarm system, the local fire inspector gave me a copy of BS 5839. It became apparent that most of the quotes were for a commercial system and when you read the standard they were wrong. The fire inspector went even further and said quite categorically "I do not want to see a commercial system fitted in this building". So reviewing our automatic fire suppression system and sprinkler vs mist options I have no no information or standard (BS9251:2021) as a reference document. Even the fire authority don't have it, so how on earth they can vet what has been fitted I have no idea. Hence, when do you use each type and how do I verify what the contractors are proposing is appropriate and compliant. Oops, just though should I start another topic?
Had a quick look and not really convinced that the annex is entirely wheelchair friendly - if this is required.
Is there a 1500mm turning circle in the bedroom next to the storage?
Wheelchair users need to be able to get to a door handle - I’d normally like to see a space to the side of a door - a leading edge - so that a person in a wheelchair can get close enough to the door to open a door handle. Take a look at the front door and the door into the en-suite.
You might want to take a look a specific accessible bathroom layouts for independent and assisted use. I would normally expect to see an accessible WHB for use without having to get back onto a wheelchair.
I don’t think splitting the storage space for the door into the en-suite is a great idea - access to the door and cupboards is restricted.
Is there a current or future need for a hoist between the bedroom and the en-suite? I would normally expect to see a provision for a hoist from the bed to the bathroom.
The utility room looks very tight for independent use.
Finally - I presume an OT assessment has been carried out to determine the specific needs which have been transferred to the design?
