Bonner Posted August 30 Posted August 30 After saying never again, we are looking at another self build ‘opportunity’! The plot is ideal in terms of size and location but the compromise is soft clay requiring piled foundations. A full ground investigation has been done by the vendor which concludes that piling is definitely required. I know it is a piece of string question but can anyone suggest a reasonable cost difference between strip founds and ‘standard’ piles + ring beam? Looking at 220m2 two storey house with simple form factor so 110m2 rectangular footprint, timber frame and brick skin. TIA
MPx Posted August 30 Posted August 30 No recent knowledge so unlikely to help, but FWIW: In 2012 we had a pile and ring beam foundation done due to unstable ground. Not a regular shape (you need support for any internal load bearing), but approx 55 linear meters using 44x 9m piles with a ring beam and a few pins cost £27,480.75. But how much for strip foundations in 2012 to compare - no idea??? 1
Bonner Posted Sunday at 16:34 Author Posted Sunday at 16:34 Thanks. I know I will need to talk to a piling contractor in due course. Just trying to get a feel of the cost risk for valuation purposes. From fairly recent experience I can estimate the cost from ground up, just go no idea if I need to add £10k, £30k, £100k for piling.
Mr Punter Posted Sunday at 18:05 Posted Sunday at 18:05 I would think £35k extra would do it assume 300mm piles up to 6m. £20k piling £15k ground beams. You could get indicative quotes based on your ground investigation. 2
Bonner Posted Monday at 18:51 Author Posted Monday at 18:51 On 30/08/2026 at 19:05, Mr Punter said: I would think £35k extra would do it assume 300mm piles up to 6m. £20k piling £15k ground beams. You could get indicative quotes based on your ground investigation. Thanks, I would be able to live with that sort of cost. If it comes to much more the project is not viable for me. Will get in touch with a few contractors.
mjc55 Posted Tuesday at 07:42 Posted Tuesday at 07:42 But you are not going to get a fixed price for piles I suspect! Until they start inserting piles they wont really know depths so any quote would be an estimate I suspect. 2
Mr Punter Posted Tuesday at 07:50 Posted Tuesday at 07:50 5 minutes ago, mjc55 said: But you are not going to get a fixed price for piles I suspect! Until they start inserting piles they wont really know depths so any quote would be an estimate I suspect. If the ground investigation is decent they should be able to get a good idea. Also access and proximity to adjacent structures can have an impact that the piling contractor can factor in. 1
Nickfromwales Posted Tuesday at 21:34 Posted Tuesday at 21:34 13 hours ago, Mr Punter said: If the ground investigation is decent they should be able to get a good idea. Also access and proximity to adjacent structures can have an impact that the piling contractor can factor in. You can ask for this to be more 'in depth', so they charge more for the investigations and remove as much ambiguity as is practicable. 3
saveasteading Posted Tuesday at 22:21 Posted Tuesday at 22:21 On 30/08/2026 at 08:21, Bonner said: piling is definitely required. Do you have access to the borehole logs? Just a statement that piling is required is of little use. Is there hard ground at 5m depth or 50m? How soft is the clay? Does only the structure require support but not intermediate floor areas?. That said, a starting point of "about 30 or 40k" lets you start on feasibility. But there are lots of piling techniques too. By considering that and the method of construction you could be saying "allow 20k to 80k". I've probably done about 20 piled buildings and often used a different method to that suggested in initial reports. But never for clay... yours must be very soft indeed. Any chance of seeing a borehole record? And what about the house? Big/small/ conventional or huge rooms, 1 or 2 storey? 1
Gus Potter Posted Tuesday at 23:37 Posted Tuesday at 23:37 On 30/08/2026 at 08:21, Bonner said: fter saying never again, we are looking at another self build ‘opportunity’! The plot is ideal in terms of size and location but the compromise is soft clay requiring piled foundations. A full ground investigation has been done by the vendor which concludes that piling is definitely required. I know it is a piece of string question but can anyone suggest a reasonable cost difference between strip founds and ‘standard’ piles + ring beam? Looking at 220m2 two storey house with simple form factor so 110m2 rectangular footprint, timber frame and brick skin. TIA Now by now you should know that there is no way any of us that can take a punt on this. Post your geotech info, a site plan etc. You know the rules, the more info you provide the better quality response you'll get. 2
Nickfromwales Posted Wednesday at 06:27 Posted Wednesday at 06:27 6 hours ago, Gus Potter said: there is no way any of us that can take a punt on this. Indeed, and, as above, even a quote given to you will be loaded with caveats; stating that they’ll need to keep sending the pile down until it hits something robust etc. You need a creative / proactive SE who could consider all options and value engineer (and not over egg it!). 1
Bonner Posted Wednesday at 06:31 Author Posted Wednesday at 06:31 Thanks, appreciate all the comments. I will post more detail later.
saveasteading Posted Wednesday at 07:22 Posted Wednesday at 07:22 I generally used a piling company that had several technical options ( driven, auger, vibro) ( end bearing, surface friction, ground inprovement) so that they could help decide on the best solution. But this involves 2 way trust which takes time to form. And they aren't likely to suggest another method of construction with no piling. Looking forward to your info.
Alan Ambrose Posted Wednesday at 15:43 Posted Wednesday at 15:43 (edited) We had an estimation module in engineering school that asked us to do critical calcs in our head and come out with approximate answers. This allowed a very valuable sanity check on the fancier version of the calcs using accurate numbers. If the results differed by more than, say +- 50% you had a big problem. So, saying that, I just had some augur piling done. There's generally a fixed cost for design / mobilisation (i.e. getting off our arses) / testing etc and a variable cost per pile or metre, but sometimes the sales person might trade one against the other for window dressing. I was quoted £1.29K per pile / £92 per metre for 350mm diameter 14m piles and only a couple of £K for design etc. I was also responsible for the muckaway. Let me guess that you'll have 20 off 8m piles (who knows without seeing your soil investigation or knowing how heavy your house is going to be). That's £15K plus some fixed costs and the muckaway, say £20K. I'll guess that the ring beam will cost about the same as simple strip founds. So plus £20K for pile support. Sure, maybe you'll need 12m piles or longer and the cost will scale roughly linearly - nobody knows because you have not provided any info besides 'soft clay'. I bet a couple of local piling companies will be interested enough to give you a ballpark. To get an accurate quote number you need: A soil investigation with load bearing numbers and a sense of groundwater height. SE calcs of your house loads and a rough slab/founds design. The piling co will then do a pile design with a 3x safety factor and give you a reasonably firm quote. On consistent soft clay you shouldn't find anything too unexpected unless you suspect mine workings, archaeology, underground lake etc. A local BCO might give you an opinion on that too. This is what the interesting page(s) of the SI look(s) like. The N=xx result is what you're after and gives you an indication of the load bearing capacity. The SI may even give you a feel for what reasonable piling might look like, but the piling company will want to refine that calc. Edited Wednesday at 15:48 by Alan Ambrose 2
Bonner Posted Wednesday at 18:50 Author Posted Wednesday at 18:50 Well here goes, a few extracts from the report. Note it does not say piles are absolutely necessary, only recommended due to trench depth, stability and potential heave. Once again, appreciate any suggestions.
saveasteading Posted Thursday at 07:01 Posted Thursday at 07:01 That's good ground. No piling required. 1 1
Mr Punter Posted Thursday at 07:34 Posted Thursday at 07:34 Just look around for trees. Even if they are small you need to treat them as full height. Hawthorn, Oak and Willow are big drinkers! 1
saveasteading Posted Thursday at 08:07 Posted Thursday at 08:07 I'm intrigued by the term " former tree". Presumably intending that there may once have been a tree there, not a fence or bench seat. Also the phrase " highly susceptible to degradation in water". I think that means it might get muddy if wet and disturbed. I prefer plain English, which would have concerned you much less. Are there any "current" trees within 25m? Is there a slope? Why are they so concerned about seepage? Is it a very wet area? 2
-rick- Posted Thursday at 10:19 Posted Thursday at 10:19 2 hours ago, saveasteading said: I'm intrigued by the term " former tree". Presumably intending that there may once have been a tree there, not a fence or bench seat. I read it as a tree has been removed but the roots are still there (maybe or maybe not the stump also)
saveasteading Posted Thursday at 11:32 Posted Thursday at 11:32 1 hour ago, -rick- said: tree has been removed Me too, but language should be clearer and I was being flippant. But how does anyone know there was tree there last year or whether 2 or 10 years ago matters. In my opinion a normal year's weather cycle will likely allow the clay ground to come to stability.
-rick- Posted Thursday at 11:38 Posted Thursday at 11:38 3 minutes ago, saveasteading said: Me too, but language should be clearer and I was being flippant. But how does anyone know there was tree there last year or whether 2 or 10 years ago matters. In my opinion a normal year's weather cycle will likely allow the clay ground to come to stability. If the roots are still there then the ground hasn't stabilised because at some point the roots will rot away, no? I thought roots can take a few years to rot fully. It's true that the water demand from the tree will go quicker but I thought stability was about more than just water demand.
saveasteading Posted Thursday at 12:39 Posted Thursday at 12:39 53 minutes ago, -rick- said: the roots will rot away, no? Yes. But wet clay will expand back into the spaces and the amount of wood in roots is surprisingly small. as you say, it is the effect of the tree drinking the water from the clay that causes it to shrink. Then in winter or when it becomes a former tree, the clay will expand again when wet and stay that way. 57 minutes ago, -rick- said: more than just water demand. Not a lot. Obv you wouldn't build on top of right next to a dead tree trunk, and would do something about big surface roots for stability. Houses are built assuming that no inappropriate tree planting will ever occur, and you can't stop a neighbour doing it, but that is just one of life's risks. 2
Gus Potter Posted Thursday at 20:05 Posted Thursday at 20:05 On 02/09/2026 at 16:43, Alan Ambrose said: We had an estimation module in engineering school that asked Great post, very informative!
Gus Potter Posted Thursday at 20:28 Posted Thursday at 20:28 On 02/09/2026 at 19:50, Bonner said: Well here goes, The soils are just above the plasticity A line, not much to worry about. Lots of rafts get designed with an L shaped building, we design joints for this and make sure the super structure can cope with anticipated movement. The allowable bearing pressure is good at 115 kPa, a standard benchmark of 100kPa is a good comfortable reference point. Where does the water table sit? You probably need to post the full SI for the best feedback, there will other stuff buried in it that you may not have the experience to be able recognise it's importance. 1
Bonner Posted yesterday at 07:09 Author Posted yesterday at 07:09 22 hours ago, saveasteading said: I'm intrigued by the term " former tree". Presumably intending that there may once have been a tree there, not a fence or bench seat. Also the phrase " highly susceptible to degradation in water". I think that means it might get muddy if wet and disturbed. I prefer plain English, which would have concerned you much less. Are there any "current" trees within 25m? Is there a slope? Why are they so concerned about seepage? Is it a very wet area? Thanks for all the comments. The site is a former garden which has been cleared of said former (smallish) trees. It is still bordered on one side by tall conifers within 10m of the nearest foundation. Site of the house is virtually level however the back of the site slopes gradually up from 5-10 degrees. No signs of standing water but ground infiltration test was nil, presumably due to underlying clays (consent has been granted to discharge storm water to sewer). Note tests were done in January. 1
