I have never seen these.  If you are doing a DPC cavity tray around the perimeter you could just lap any joins, but probably not have any other than change of direction.  You could use some double sided DPC tape if you are feeling really keen.  Who specified these?  Is it a radon thing?
When you say lapped, do you mean overlapped and bonded together using a double sided butyl tape?
I thought the metal stainless supports were required for all DPC trays to ensure it does not sag and potentially come apart at the lapped joint.
given we have to have a full perimeter cavity tray, I want to be confident that it is supported under the joints
Edited by flanagaj
There won’t be any sag as you have insulation under the tray cut at an angle
so the tray is fully supported on the batts.
you could change the batts for xps or eps if you want something more rigid.
