flanagaj Posted August 24 Posted August 24 Does anyone know whether there is a cheaper alternative to the below. I was contemplating purchasing a load of stainless steel strip or even aluminium and forming them myself. Seem very expensive for what they are. https://www.fixingsstore.com/visqueen-dpc-joint-support-400-x-100mm-stainless-steel-10-pack-rs074124/p/26435
Mr Punter Posted August 24 Posted August 24 I have never seen these. If you are doing a DPC cavity tray around the perimeter you could just lap any joins, but probably not have any other than change of direction. You could use some double sided DPC tape if you are feeling really keen. Who specified these? Is it a radon thing? 1
flanagaj Posted August 24 Author Posted August 24 (edited) When you say lapped, do you mean overlapped and bonded together using a double sided butyl tape? I thought the metal stainless supports were required for all DPC trays to ensure it does not sag and potentially come apart at the lapped joint. given we have to have a full perimeter cavity tray, I want to be confident that it is supported under the joints Edited August 24 by flanagaj
Russell griffiths Posted August 24 Posted August 24 There won’t be any sag as you have insulation under the tray cut at an angle so the tray is fully supported on the batts. you could change the batts for xps or eps if you want something more rigid. 1
Oz07 Posted August 24 Posted August 24 Those full trays are a nightmare the cause more problems than they solve. What are they actually doing.
flanagaj Posted Saturday at 07:09 Author Posted Saturday at 07:09 On 24/08/2026 at 15:04, Oz07 said: Those full trays are a nightmare the cause more problems than they solve. What are they actually doing. All required because of level thresholds
Oz07 Posted Saturday at 09:05 Posted Saturday at 09:05 1 hour ago, flanagaj said: All required because of level thresholds I don't think they are I've built without them in past. Once i got asked to put them in because of potential methane.
