flanagaj Posted Monday at 07:58 Posted Monday at 07:58 Does anyone know whether there is a cheaper alternative to the below. I was contemplating purchasing a load of stainless steel strip or even aluminium and forming them myself. Seem very expensive for what they are. https://www.fixingsstore.com/visqueen-dpc-joint-support-400-x-100mm-stainless-steel-10-pack-rs074124/p/26435
Mr Punter Posted Monday at 08:07 Posted Monday at 08:07 I have never seen these. If you are doing a DPC cavity tray around the perimeter you could just lap any joins, but probably not have any other than change of direction. You could use some double sided DPC tape if you are feeling really keen. Who specified these? Is it a radon thing? 1
flanagaj Posted Monday at 09:35 Author Posted Monday at 09:35 (edited) When you say lapped, do you mean overlapped and bonded together using a double sided butyl tape? I thought the metal stainless supports were required for all DPC trays to ensure it does not sag and potentially come apart at the lapped joint. given we have to have a full perimeter cavity tray, I want to be confident that it is supported under the joints Edited Monday at 09:37 by flanagaj
Russell griffiths Posted Monday at 12:11 Posted Monday at 12:11 There won’t be any sag as you have insulation under the tray cut at an angle so the tray is fully supported on the batts. you could change the batts for xps or eps if you want something more rigid.
Oz07 Posted Monday at 14:04 Posted Monday at 14:04 Those full trays are a nightmare the cause more problems than they solve. What are they actually doing.
