BotusBuild Posted yesterday at 09:23 Posted yesterday at 09:23 The new garage being built with ICF walls has an internal floor dimensions of about 5m x 6m, with the single pitch (flattish) roof sloping from one 6m side to the other. My current plan is to put in a central 5.5m(ish) beam with joists at right angles (~3m each). Q. Glulam or steel for the central 5.5m beam?
Mr Punter Posted yesterday at 09:40 Posted yesterday at 09:40 Glulam will be deeper. Price up in both.
Oz07 Posted yesterday at 10:32 Posted yesterday at 10:32 I'd be surprised if glulam is cheaper so I'd lean towards steel. I have a garage 5x5m with 45x 225 timber joists. Was looking at extending the width to 6m and I don't think you can make it work running the joists this way. I can either put a steel over garage door and run timbers 5m way, put rsj in where current 5m wall is, or you can get I beam/jji joists/posi joists to span the 6m. Would that be a solution for you?
BotusBuild Posted 20 hours ago Author Posted 20 hours ago A quick bit of research show the Glulam to be about £50-70 cheaper, but would as @Mr Punter says would be deeper. For clarity, this is an approximation of the proposed layout described above (ignore the uneven spacing of the 3m joists)
JohnMo Posted 19 hours ago Posted 19 hours ago Do you have to have a flat roof? If not simple roof rafters at a low angle, then you most likely need zero steel or glulam. You just trying hard to make it more complicated and expensive than it needs to be 1
Mr Punter Posted 19 hours ago Posted 19 hours ago It could be better as a ridge beam on a low pitched roof.
Tony L Posted 19 hours ago Posted 19 hours ago I don't have the same expertise as the other contributors to this thread, but I'd have thought buying in some ready made trusses, to give a low angle dual pitch roof would be the best solution. If you tell the truss company what your roof finish will be, they'll work out the truss spec' for you.
saveasteading Posted 19 hours ago Posted 19 hours ago Have a play with this, 5m clear span gives a few possibilities. and as it is a garage the loads can be reduced and maybe plain timber will work. That assumes that it is and always will be a garage! https://www.jamesjones.co.uk/products-and-services/engineered-timber/jji-joists/interactive-span-table 1
BotusBuild Posted 5 hours ago Author Posted 5 hours ago 13 hours ago, JohnMo said: you have to have a flat roof? Yes
BotusBuild Posted 5 hours ago Author Posted 5 hours ago 13 hours ago, saveasteading said: That assumes that it is and always will be a garage! It will 😀 and thanks
Russdl Posted 2 hours ago Posted 2 hours ago I used galvanised C section joist and timber firings for my almost flat garage roof. Maximum width of 7m reducing to 5m.
