I'm wondering how to approach a project where I need to replace all of the 1970s/80s aluminium double glazed windows of a property in south west Surrey.  The main problem is there are lots of windows and some of them are large, and I want to do it to a reasonable thermal spec (lots of glass area = heat loss) while on a limited budget.  To give an idea, there are 11 windows and 5 doors (inc 3 sliding patio doors) - the doors are roughly 2.4m x 2m and the largest window is 3m x 1.2m.
To keep the budget under control I'm probably looking at uPVC. What might be options for suppliers?  I can of course ask the local firms around to quote, but I'm wondering if there's any good value 'IKEA' or 'DIY Kitchens' kind of fabricators who I can source the windows from and then find someone to install (I know someone who might do it). I know there's plenty of 'buy windows online' kind of places but I don't really know who are good companies beyond just random Googling, and many of the quoting tools don't say who makes the profile they're using so it's hard to gauge quality.
There used to be a window factory down the road but it's now a block of flats...
Trouble with most windows you mostly get what you pay for. Argon filled double glazing is argon filled glazing, the frame design is the difference between a a good window and a poor one. So when comparing look at the Uw that is the U value of the whole window, not just the glazing (Ug).
Also make sure the installer is filling the void around the window, ideally with an airtight foam. Lots fits window and just cover the void circumventing a decent U value.
I have used Modern UPVC Windows for both windows and doors and not had any problems. I think they are good value for product and service. I did fit them myself though.
https://www.modernupvcwindows.co.uk/
Edited by Gone West
A friend has used this company twice & has been pleased both times.  They've just fitted a long bi-fold run, separate slide or French patio doors (can't remember which) & 6 or more other doors/windows to his house extension.   They supply & fit.
https://truglaze.co.uk/  They're in Frimley Green, so probably not far from you.
Please let us all know how you get on - I have a rental property that will need new windows within months (assuming the tenant moves out, as expected).
Edited by Tony L
just chucking them in yourself might cause an issue when you come to sell it as you wont have a fensa certificate.
you can use websites like, modernupvcwindows to get an idea of what you want then an idea of cost before you get some quotes.but dont forget the installer will price in trims/foam/silicone/packers/fixing etc..
i have eurocell in my house because they are round the corner from me and noise reduction Liniar in my garage because i got them off marketplace off some crackhead. I put a crystal from the bargain bin section in wickes in my mates garden room/playhouse because it was £20.
These is a quite a bit to it and once you take your old one out you have to get the new one in by the end of the day or it gets chilly.
5 hours ago, Oz07 said:
Which are the best upvc profiles? They all claim to be! @craig
For me, Aluplast, specifically the Energeto 8000. Is it the cheapest? No.
I just screw a bit of OSB in the hole and finish it the next day, and don't do it in mid-winter.
3 hours ago, Oz07 said:
What makes a better profile?
The amount of chambers, welds, material used (polybutylene terephthalate (PBT) engineering plastics rather than steel for strengthening and thermal improvements
Edited by craig
Just looked. Glued glass to sash. Must be expensive if unit fails or gets broken? I think that would put me off
Very easy to replace, obviously not as easy as glass into the frame without glue but it's a security thing as well. Doesn't take much longer to remove the glue, clean and put new unit in with the glue. It's also an extra, not standard.
Edited by craig
What do I use when it's a cost thing?
  • Aluplast Ideal 4000 (Double)
  • Aluplast Idea 8000 (Triple)
Alternatively I would look at Rehau, Gealan or Salamander.
Edited by craig
Thanks all. Modern UPVC Windows look handy as they have a configurator thingy - as changing the setup is possible (fewer panes per window than currently) it'll be useful to experiment with. Then I have a spec I can pass around to others. I know a Proper Window Installer, I'm not going to be DIYing this.
Craig, also good to know some systems worth looking at. I'm still at early stages yet but might give you a ping when things have come together a bit more.
A few things I was wondering. Modern Windows only do double glazing for sliding doors - triple is too heavy apparently. But their glass is only U of 1.22 - and these are the biggest windows where it matters the most. Apart from going to folding doors, which I'd rather avoid, is there any way to improve the U value?
Also pondering what to do about shading on the south (street facing) side. Solar gain is brutal with these large windows. Should look at integral blinds as shutters might be complicated...
Other suggestions of suppliers to look at very much appreciated...
Do the installers glue the unit in when window fitted then or do they come factory glued?
Factory glued but also done on site when required, as sometimes you need to fix through the frame and glass needs to be supplied loose.
Double glazing at 1.2Ug, isn’t bad at all but expected Ug now for double glazed. I can only suggest getting a system that can handle the weight.
