August 5Aug 5 37 minutes ago, S2D2 said: Also worth noting is that they're allowing one per socket circuit, so most houses can easily have 1600W of generation for under £1k (once they update g98). John's copy/paste above says 800W per household. Where have you seen it per circuit?
August 5Aug 5 2 hours ago, Beelbeebub said: I think the bigger issue is the electricians industry bodies not wanting something where electricians aren't needed. I am fairly sure they would mandate only qualified electricians are legally allowed to plug or unplug devices if they could. I think this is already a thing with bigger equipment (commercial) with the use of commando style plugs being discouraged or outright prohibitied (can't remember) when they used to be the norm.
August 5Aug 5 4 minutes ago, -rick- said: John's copy/paste above says 800W per household. Where have you seen it per circuit? Source: https://www.gov.uk/government/consultations/plug-in-solar It is currently blocked by G98, but their intent seems clear.
August 5Aug 5 14 minutes ago, S2D2 said: Source: https://www.gov.uk/government/consultations/plug-in-solar It is currently blocked by G98, but their intent seems clear. Ok so it is currently 800W. They may want more but doubt this will change for quite sometime now. Politicians will call it done and move on to the next challenge.
August 5Aug 5 3 hours ago, Beelbeebub said: IIRC, the issue with unidirectional RCD/rcbo only occured if the inverter continued to feed power when the grid goes down -which shouldn't happen (as has been pointed out) And then the problem resulting from that situation is that the RCD/rcbo is damaged - which would result in a dead circuit and the home owner getting it replaced with a bidirectional one I think the bigger issue is the electricians industry bodies not wanting something where electricians aren't needed. I am fairly sure they would mandate only qualified electricians are legally allowed to plug or unplug devices if they could. The industry bodies don’t much care whether or not you’re an electrician. Only that you pay good money every year to have their little badge.
August 5Aug 5 57 minutes ago, Mattg4321 said: The industry bodies don’t much care whether or not you’re an electrician. Only that you pay good money every year to have their little badge. Quite!
August 22Aug 22 Not the 300 quid they were talking about. https://www.techradar.com/home/smart-home/first-plug-in-solar-kits-get-regulatory-green-light-in-the-uk-ahead-of-legal-lift-off-on-august-27-and-theyll-start-at-gbp699
August 22Aug 22 1 hour ago, SteamyTea said: Not the 300 quid they were talking about. Gotta milk the overexcited first adopters before the competition forces lower prices.
August 22Aug 22 3 hours ago, -rick- said: the 300 quid That's probably about the wholesale cost, so a developer might get that and include one in every new house. Have now had a look at Leroy Merlin, the B and Q of France and Spain. E449 incl vat. and that seems to be complete 440Wp. https://www.leroymerlin.es/productos/kit-solar-enchufable-lexman-4-paneles-flexibles-440w-para-balcon-pared-91827489.html Edited August 22Aug 22 by saveasteading
August 22Aug 22 Easy to find 930W for £499 on eBay. No link as I've no idea if they're UK approved. I'm sure there'll be plenty of questionable offerings at low prices soon enough
August 22Aug 22 1 hour ago, torre said: 930W for £499 on eBay I guess 440W is pretty useful near the Med, but not so great here, in winter certainly. It surprised me that there were 4 panels, so maybe that's old tech. Leroy is not the place for great value, but we'll know it is mainstream when the supermarkets sell them. I'm not comfortable buying that sort of thing on Ebay.
