Plug in solar is here (well in a couple of weeks)
The UK government has officially legalised "plug-in" balcony solar panels, allowing renters and flat owners to generate their own green electricity. The legislation (SI 2026/848) takes effect on 27 August 2026, making the UK market look much more like Germany, where similar plug-and-play kits are highly popular.
Key Rules of the New Legislation Plug-and-Play Setup: You can mount the panels on a balcony rail, terrace, or patio and plug them straight into a standard 13A three-prong wall socket without professional electrical installation.
800W Output Cap: Systems are strictly capped at a maximum power output of 800W per household to ensure the safety of domestic wiring.Safety Certifications:
Only fully integrated, compliant kits meeting BS 7671 (Amendment 4) standards can be legally sold or used.
Location Exception: While the law allowing retailers to sell these kits applies UK-wide, the specific rules legalising direct socket-connection currently only cover Great Britain (England, Scotland, and Wales), with Northern Ireland still awaiting an equivalent regulatory update.
What This Means for Renters and Flat Owners
No Installation Costs: Because the system uses a regular mains socket and doesn't require complex roof wiring, you avoid expensive professional installation fees.
Portability: If you move properties, you can simply unplug the panels, pack them down, and take them with you to your next home.
Immediate Bill Savings: The power generated feeds directly into your home circuit, meaning appliances use your free solar energy first before drawing paid power from the National Grid.
A Note on Tenant Agreements -  While the technology itself is now legally approved for standard electrical use, you may still need permission from your landlord, local council, or building's management company to physically mount equipment on exterior balconies, railings, or communal walls.
So 800W PV plug and play kit solutions only. Does not apply to batteries only PV.
That all seems sudden.
I know we discussed it on here a few months ago, but I've not seen anything in mainsream media.
So perhaps HMG follow BH for balanced and knowledgable advice.
43 minutes ago, G and J said:
Presumably they come with a remote clamp for the meter box?
Nope. Just plug in and go AFAIK. It's all based on 800W being low enough and the safety systems within the system strong enough that no additional steps are necessary.
Straight in to nearest plug socket - done.
But only 800W max, most the time it will be a quarter of that. All without MCS, so nothing is paid for any exports.
Shows decisions can be made and quickly
How big is an 800w kit? Presumably you can only have 1 kit per house or per ring main or whatever? I am thinking of a pergola with solar on top in summer and put away for the winter to let more light in
Solar panels are 21-24% efficient depending on model. Sun outputs 1000w/m2. So you can work it out.
2x1m panel is generally around 400-450w. There are a number of 'portable' solutions that use less efficient panels so you could have more of those but they are more expensive and less durable (as a tradeoff for weight/portability).
A typical 400W panel is around 1134 x 1722mm, so that X2.
I’d have assumed even a couple of amps pushed the wrong way through old and/or one way RCBOs/RCD would have given them a problem.
Nicely inclusive though.  I can imagine the real payback being in change of attitude from apathy/impotence to yes, we can do a bit.
The electrical industry raised some concerns about this but turns out it isn't a bit deal. The devices work two way they just aren't tested/certified for it. Exception might be if the mains power is down and the panel is feeding power to the grid (but that can't happen due to the mandatory safety checks built in).
Fab.
How many homes have 2 way RCBOs/RCDS with solar currently - suspect not many. Does yours?
I liked someone's advice in a prev discussion.
Buy a German or German approved one. The quality will be good and safety thought through.
I naively assumed (isn’t that just so dangerous) that anyone exporting would have bi-directional doberries.
The dude who fitted our solar PV/inverter/battery was most precise about what we needed where so I was all ready to go through it with our sparky who before I opened my mouth told me exactly the same thing,   It made me think that everyone else knew all that and I was the only dunce lol.
Just did a Google search
Bi-directional RCBOs became officially mandated for domestic installations with generating sources on July 31, 2024, following the introduction of BS 7671:2018+A3:2024 (Amendment 3). Manufacturers began releasing compliant domestic hardware around early-to-mid 2024.
So lots and lots of installs done prior to that date, so doubt they were retrofitted.
Our install was done in 2021 way before bi directional were available.
Our installation was done in 2012 and the RCD certainly isn't bi-directional.
You and around another 1.5 million registered installs completed prior to 2024
So for pre 2024 installations is it just a 'nice to have' retrofit?
Not quite true as a large amount of installs will be fitted with BS61008 RCCB's which are all bi-directional. It's only B61009 RCBO's where the issue arises, as these are usually uni-directional unless otherwise stated. This never used to be a problem until a couple of years ago, when it suddenly became a problem. Now, it doesn't seem to be a problem anymore. It's almost like magic.
IIRC, the issue with unidirectional RCD/rcbo only occured if the inverter continued to feed power when the grid goes down -which shouldn't happen (as has been pointed out)
And then the problem resulting from that situation is that the RCD/rcbo is damaged - which would result in a dead circuit and the home owner getting it replaced with a bidirectional one
I think the bigger issue is the electricians industry bodies not wanting something where electricians aren't needed. I am fairly sure they would mandate only qualified electricians are legally allowed to plug or unplug devices if they could.
Not sure if all inverters have them but I'm pretty sure Solaredge inverters have a built in RCD so even with a faulty grid loss shutdown the in built RCD should take care of anyone zapping themselves.
I'm fairly sure all "proper" inverters now have this built in.
As for the micro inverters that are suitable for plug in solar - I'm not sure, obviously the "approved" ones will along with the shutdown hardware etc.
I'm sure it's possible to buy some cheap ones without the necessary hardware online.
But I think the main point is that even in the worst case the risk is just blowing your old RCD up with your unapproved inverter.  So you end up getting a new bi directional RCD and hopefully a proper inverter.
I don't think there is any additional risk to things catching fire or people getting shocked beyond the normal risk whenever you plug something in.  There are plenty of dodgy gizmos you can buy online that have a far higher likelihood of shock or fire than your old RCD crapping out
Also worth noting is that they're allowing one per socket circuit, so most houses can easily have 1600W of generation for under £1k (once they update g98).
Really positive news.
