markharro Posted Saturday at 17:22 Posted Saturday at 17:22 Looks like our electrician has only allowed for 2x double sockets here whereas red marks on the wall were showing 2 x doubles on left and 1x on right. I suspect this is an easy fix and think I know how to do it but be grateful for some guidance. Thanks.
MikeSharp01 Posted Saturday at 17:50 Posted Saturday at 17:50 No they have just put in the base cables. When they come to fit the socket they will add another length of cable between the sockets on the left. 1
Onoff Posted Saturday at 17:58 Posted Saturday at 17:58 The two cables coming down the wall will go to double sockets 1 and 3. The other length of cable taped to the two coming down the wall will link socket 1 to 2 then socket 2 to 3.
ProDave Posted Saturday at 18:15 Posted Saturday at 18:15 The beauty of timber frame with a service void. You could make it 4 doubles if you wanted, 2 in each section of wall. Just make sure he know how many before he cuts the holes in the plasterboard.
markharro Posted Saturday at 19:00 Author Posted Saturday at 19:00 Brilliant thanks thats good news. So does this look ok for 2x on left and 1x on right? and if I did want 2 x doubles on right as well just do the same with the wiring?
Onoff Posted Saturday at 19:03 Posted Saturday at 19:03 I'd say there's enough cable to do 2 left and 2 right. 1
Nickfromwales Posted Sunday at 00:18 Posted Sunday at 00:18 5 hours ago, Onoff said: I'd say there's enough cable to do 2 left and 2 right. There's enough to do as many as you want here, perfectly compliantly . Cables would drop into any two of these 3 'sockets' boxes, and the link cables would daisy chain to all the others, forming a ring of x number of sockets instead of just linking 1 > 3. Cables all tight to boxes to stay in cable safe zones obvs, just drawn loosely here to show how this can be done. 1
markharro Posted Sunday at 07:34 Author Posted Sunday at 07:34 thanks @Nickfromwales and others. So can I check is my amended photo showing the wiring for 3x sockets showing the wiring run correctly? I sort of need to know as intend to board over today. I may put a 4th one in but good to know if ok for 3 atm?
ProDave Posted Sunday at 07:46 Posted Sunday at 07:46 I have said before, my preference for wiring a room is a cable all the way round at socket height. That makes it easy to add any extras any time in the future. There must be at least one socket on each wall of the room to create the safe zone.
garrymartin Posted Sunday at 09:33 Posted Sunday at 09:33 1 hour ago, markharro said: I may put a 4th one in but good to know if ok for 3 atm? Yes. Perfectly OK for 3 and very easy for your electrician to make it 4 if you wanted.
markharro Posted Sunday at 12:11 Author Posted Sunday at 12:11 Ok great thanks - right I have decided to go for the 4 x doubles so this should be the final wiring. This look ok?
Nickfromwales Posted Sunday at 13:24 Posted Sunday at 13:24 1 hour ago, markharro said: Ok great thanks - right I have decided to go for the 4 x doubles so this should be the final wiring. This look ok? Yup. You’re now 18th ed lol. Go get some stickers for the van
Spinny Posted yesterday at 17:52 Posted yesterday at 17:52 If you know exactly where you want the sockets then you could potentially put metal boxes in now. Don't forget if you are fitting out for a desk, or for a network cabinet then multisocket extensions and/or surge protected power bars are available.
Nickfromwales Posted 2 hours ago Posted 2 hours ago On 03/08/2026 at 18:52, Spinny said: If you know exactly where you want the sockets then you could potentially put metal boxes in now. Don't forget if you are fitting out for a desk, or for a network cabinet then multisocket extensions and/or surge protected power bars are available. 47mm boxes screwed into the green OSB boards for current MBC project; 35mm battens, ~16mm PB + skim, so the box is bang on. Were doing 15mm PB everywhere here, so a bit shy of the painted surface, but much better than fast-fix boxes tbh. These have their place, like when clients can’t make such decisions ahead of boarding / skimming etc, but metal boxes should be used where you can.
Onoff Posted 1 hour ago Posted 1 hour ago If you must use fast fix boxes, use a multi tool to cut the hole. Then paint the cut hole in the plasterboard with PVA and let dry before fitting the boxes. It keeps the cut plasterboard edges together.
markharro Posted 16 minutes ago Author Posted 16 minutes ago Plasterboard....what's that. Real self-builders use Fermacell! But yes I've found that the multitool is the solution for the plastic boxes....needs a steady hand and concentration! Have fitted a fair few metal boxes too!
