markharro Posted 1 hour ago Posted 1 hour ago Looks like our electrician has only allowed for 2x double sockets here whereas red marks on the wall were showing 2 x doubles on left and 1x on right. I suspect this is an easy fix and think I know how to do it but be grateful for some guidance. Thanks.
MikeSharp01 Posted 1 hour ago Posted 1 hour ago No they have just put in the base cables. When they come to fit the socket they will add another length of cable between the sockets on the left. 1
Onoff Posted 1 hour ago Posted 1 hour ago The two cables coming down the wall will go to double sockets 1 and 3. The other length of cable taped to the two coming down the wall will link socket 1 to 2 then socket 2 to 3.
ProDave Posted 44 minutes ago Posted 44 minutes ago The beauty of timber frame with a service void. You could make it 4 doubles if you wanted, 2 in each section of wall. Just make sure he know how many before he cuts the holes in the plasterboard.
markharro Posted just now Author Posted just now Brilliant thanks thats good news. So does this look ok for 2x on left and 1x on right? and if I did want 2 x doubles on right as well just do the same with the wiring?
