Mr Blobby Posted Monday at 13:45 Posted Monday at 13:45 I was surprised, and rather disappointed to find our plumber had screwed into my lovely Panasonic cylinder to fix pipes. Googling around it seems this is common practice to fix into the cylinder so I'm much calmer now. However, the clips are all loose, suggesting the screws have not threaded onto the external skin of the tank. I have a box or short wide self tappers on site that would probably have been far more effective but its too late now. Any thoughts on this?
LaChab Posted Monday at 14:04 Posted Monday at 14:04 I had an idea that Panasonic used Oso cylinders, in which case it's possibly not a good idea to use any screws as Oso use vacuum insulation, and state "no penetrations". 1
JohnMo Posted Monday at 15:42 Posted Monday at 15:42 If its foam insulation no issues, if as said a vacuum insulated one, bang goes the insulation 1
Nickfromwales Posted Monday at 23:37 Posted Monday at 23:37 9 hours ago, Mr Blobby said: Any thoughts on this? Post the manufacturers sectional detail, please, before we comment further. I fix into cylinders like this routinely.
MikeSharp01 Posted yesterday at 05:47 Posted yesterday at 05:47 6 hours ago, Nickfromwales said: I fix into cylinders like this routinely. Seems rather crude just to screw into a casing, might be more robustly done with rivnuts or some such.
JohnMo Posted yesterday at 06:22 Posted yesterday at 06:22 34 minutes ago, MikeSharp01 said: rivnuts We are talking plumbers - most don't understand priority domestic hot water - rivnut no chance. 1
Nickfromwales Posted yesterday at 06:51 Posted yesterday at 06:51 1 hour ago, MikeSharp01 said: Seems rather crude just to screw into a casing, might be more robustly done with rivnuts or some such. There’s nothing wrong with doing so, just the difference being some use a screwdriver to put a self tapping screw in, and others use a hammer. Rivnuts would require machine thread screws vs ‘what’s going to be in the van’, so that’s not likely to happen.
Mr Blobby Posted yesterday at 08:39 Author Posted yesterday at 08:39 18 hours ago, LaChab said: I had an idea that Panasonic used Oso cylinders, in which case it's possibly not a good idea to use any screws as Oso use vacuum insulation, and state "no penetrations". Thank you for this. Definitely an oso cylinder. I had never heard of vacuum insulation on a cylinder, so I'll go take a look.
SteamyTea Posted yesterday at 09:06 Posted yesterday at 09:06 24 minutes ago, Mr Blobby said: Definitely an oso cylinder Demand a replacement if it does have VIP. Why don't they just glue on some clips? I had a early production 309 turbo, the extra wires were attached onto self adhesive clips, was about the only thing that did not fall off. Except the brakes, they caught in fire. 1
JohnMo Posted yesterday at 09:27 Posted yesterday at 09:27 47 minutes ago, Mr Blobby said: Thank you for this. Definitely an oso cylinder. I had never heard of vacuum insulation on a cylinder, so I'll go take a look. If it's an A rated cylinder the vacuum insulation, any other ratings it's most likely not vacuum insulation
Mr Blobby Posted yesterday at 10:01 Author Posted yesterday at 10:01 3 hours ago, Nickfromwales said: There’s nothing wrong with doing so, just the difference being some use a screwdriver to put a self tapping screw in, and others use a hammer. Rivnuts would require machine thread screws vs ‘what’s going to be in the van’, so that’s not likely to happen. I can lift the screws on the top clamp with my fingernail, so its not doing much
Nickfromwales Posted yesterday at 11:25 Posted yesterday at 11:25 1 hour ago, Mr Blobby said: I can lift the screws on the top clamp with my fingernail, so its not doing much Fitted by a whelk then……
Mr Blobby Posted 2 hours ago Author Posted 2 hours ago (edited) On 14/07/2026 at 10:27, JohnMo said: If it's an A rated cylinder the vacuum insulation, any other ratings it's most likely not vacuum insulation It is A Rated, and it looks like it does have Vacuum insulated panels and PUR. So where inside the cylinder are the vacuum panels and who thinks they are punctured? The tank is not yet filled or heated so I can't do a temperature test to identify heat loss around the penetrations to determine if the VIP are punctured. Plumber has the hump with me ever since I told him to change the manifold 😕 I think its about to get worse. 😬 What now? Edited 2 hours ago by Mr Blobby
-rick- Posted 2 hours ago Posted 2 hours ago (edited) Call OSO and ask? I'd guess you are probably be ok as it makes more sense to me to put the VIP on the inside and PUR outer. But it's just a guess. Edit: But if the manual says no penetrations then making the plumber replace makes most sense. If you want to show flexibility then check with OSO and see what they say. If they are willing to warrant based on the screw being no longer than x then ok. No good to move forward with a void warranty. Edited 2 hours ago by -rick- 1
