Pocster Posted 22 hours ago Posted 22 hours ago Someone lazy in our household left concrete blocks on the decking for some considerable time . On removing them get these white marks . Tried cleaning them with various things but won’t budge . This permanent or can be removed ? Some people ! Buy materials ; leave them for a bit and then cause more work . I don’t know ! Tsh !
Conor Posted 21 hours ago Posted 21 hours ago More likely a chemical reaction between the wet concrete and the boards.
Pocster Posted 21 hours ago Author Posted 21 hours ago 46 minutes ago, Onoff said: I'd try a bathroom / kitchen limescale remover. Tried that.
Pocster Posted 17 hours ago Author Posted 17 hours ago Just now, Mr Punter said: Brick acid? Do a test patch first. yeah I did think of things like that. But is a visible area so its tricky to "test" a patch......
Onoff Posted 17 hours ago Posted 17 hours ago What about Pink Stuff? Been surprised at what that shifts, calcium deposits engrained on glass etc.
Pocster Posted 17 hours ago Author Posted 17 hours ago 3 minutes ago, Onoff said: What about Pink Stuff? Been surprised at what that shifts, calcium deposits engrained on glass etc. Bit rude mate!
marshian Posted 16 hours ago Posted 16 hours ago 49 minutes ago, Pocster said: yeah I did think of things like that. But is a visible area so its tricky to "test" a patch...... Put another concrete block in a non visible area so you can test it there?
Pocster Posted 16 hours ago Author Posted 16 hours ago 1 minute ago, marshian said: Put another concrete block in a non visible area so you can test it there? 😃. yeah I think those marks were left by blocks that might have been there a bit of time.... Like 1 month ..... or 6...... or perhaps it was a yr or 2 🫠 BUT! As a long term experiment which therefore stops me fixing it now its a very plausible test!
marshian Posted 14 hours ago Posted 14 hours ago 2 hours ago, Pocster said: 😃. yeah I think those marks were left by blocks that might have been there a bit of time.... Like 1 month ..... or 6...... or perhaps it was a yr or 2 🫠 BUT! As a long term experiment which therefore stops me fixing it now its a very plausible test! Perfect solution - glad I could help 1
Russdl Posted 10 hours ago Posted 10 hours ago Not the same materials, however we had a cast iron seat on our porcelain tiles, when I moved it there were little rust marks where it had been stood. Nothing shifted those rust marks, tried everything… …and then I used a Brillo Pad, and that did it. May work for you? 1
