cowboy25 Posted 3 hours ago Posted 3 hours ago So I have this table saw I use in my workshop I've had it for a few years and recently changed the blade for the first time with a nice Rutland blade after the original one was blunt as anything causing the wood to smoke and taking ages to cut. I also cleaned out the table saw whilst removing the old blade. The problem is I am using it currently to cut cls studs to the desired length for my project and the blade keeps catching/ jumping/ kicking when I use it even though I'm being quite careful to the point I don't want to use it anymore. The blade seemed ok for the first few weeks with no jumping happening but now not so much. What an I doing wrong? I never really had this problem with my old smoky blade I would have thought a new sharp blade would cause the table saw to kick less.
ProDave Posted 3 hours ago Posted 3 hours ago 33 minutes ago, cowboy25 said: The problem is I am using it currently to cut cls studs to the desired length for my project I would say wrong saw for the job. You want a chop saw for that. A table saw is normally used with a fence for cutting a length of timber down to a particular size. The complete lack of a guard over the blade does not inspire confidence. 2
Nickfromwales Posted 2 hours ago Posted 2 hours ago Stop using it for cutting CLS, and get a cheap chop/mitre saw. Dangerous as FECK!
Nickfromwales Posted 2 hours ago Posted 2 hours ago For £60 you could throw it away at the end of the job!
Mr Punter Posted 2 hours ago Posted 2 hours ago 40 minutes ago, ProDave said: The complete lack of a guard over the blade does not inspire confidence. And I think there may be a small issue with the dust extraction...
cowboy25 Posted 1 hour ago Author Posted 1 hour ago (edited) 1 hour ago, ProDave said: I would say wrong saw for the job. You want a chop saw for that. A table saw is normally used with a fence for cutting a length of timber down to a particular size. Ah ok I did have a chop saw but thought I could change to a table saw (plus jigsaw) as a 'do it all saw', didn't realise people didn't use it for what I am currently doing. I don't remember having this problem with my old blade but perhaps I wasn't cutting much cls. 51 minutes ago, Mr Punter said: And I think there may be a small issue with the dust extraction... I have the saw located at my workshop entrance so the most dust goes straight outside. Edited 1 hour ago by cowboy25
Nickfromwales Posted 1 hour ago Posted 1 hour ago 1 minute ago, cowboy25 said: Ah ok I did have a chop saw but thought I could change to a table saw (plus jigsaw) as a 'do it all saw', didn't realise people didn't use it for what I am currently doing. I don't remember having this problem with my old blade but perhaps I wasn't cutting much cls. A table saw is for sheet material, or trimming down timbers lengthways, not for cross cutting etc. You'll just hurt yourself or the saw. You'll be able to do mitres etc with a chop (mitre) saw too. 2
