We did above and below - XPS is much better than EPS but still absorbs water a bit and thus loses it’s value as thermal insulation.
Edited by Alan Ambrose
VCL goes at the bottom. Between the insulation and concrete you can put a thin polythene layer, as mentioned above to keep concrete out of the insulation, if it gets in your insulation will float up.
